Home > Forums > Open Source Meshers: Gmsh, Netgen, CGNS, ...
GmshToFoam correct face orientation
Old   November 27, 2005, 12:59
Default I think you can remesh STL sur
  #21
Billy
billy is on a distinguished road
I think you can remesh STL surface but you will still have a surface mesh. I didn't try to construct a solid mesh from that surface mesh. Maybe it can be exported to Tetgen to generate the solid mesh. I don't know because I haven't worked with Tetgen.
Yes. I use it instead of blockMesh, because it has many solid modelling tools such as extrusion of surface into solids. As you extrude the surfaces you can also extrude the 2D mesh to form 3D meshes.
There is also a dxf2geo program which might be promising but I still haven't tried this.
billy is offline   Reply With Quote
Old   November 27, 2005, 13:05
Default I also use it for post-process
  #22
Billy
I also use it for post-processing. When you open Gmsh it seems it doesn't have too many tools because the menus are so small. But after working with it I was surprised with its post-processing capabilities.
Old   November 27, 2005, 13:48
Default I've never managed to create a
  #23
Christian Hubbauer
christian67 is on a distinguished road
I've never managed to create anything else than a surface mesh with imported STL gemometry in gmsh.
For creating tet-meshes out of STL I suggest to use
"netgen" from J. Sch÷berl. You will find a link at the gmsh homepage.
Another useful command-line utility is "admesh", to fix some problems of STL files.
I think the new STL-remeshing option in gmsh might be helpful to get a better STL-surface.
Import of this surface into netgen should work.
christian67 is offline   Reply With Quote
Old   November 27, 2005, 15:26
Default 1) Where is this dxf2geo utili
  #24
unoder
1) Where is this dxf2geo utility located? I googled for it and searched in gmsh-directory. Couldn't find it.
2) Billy, how do you use gmsh for postprocessing (with Foam or with you own stuff)?
3) I have netgen - however it's too bad that I can't figure out all those advanced options and the documentation isn't finished, AFAIR. Thanks for the admesh-hint - I downloaded it and will see if I can try it out in some weeks...
Old   November 27, 2005, 16:01
Default I installed using rpm file and
  #25
Billy
I installed using rpm file and the binary is in /usr/bin/dxf2geo
I use gmsh for post-processing my own stuff. With FOAM, I use paraview for post-processing.
Old   July 27, 2015, 07:04
KateEisenhower is on a distinguished road
Hello foamers,
does anyone know if the is corrected already? Or do you still have to use the forum-version?
Best regards,
Kate
Originally Posted by adorean View Post
Try the modified gmshToFoam from this forum, see if it helps.
Ervin
KateEisenhower is offline   Reply With Quote
Thread Tools
Trackbacks are On
GmshToFoam varun Open Source Meshers: Gmsh, Netgen, CGNS, ... 4 March 13, 2012 04:24
GmshToFoam example guillaume OpenFOAM Mesh Utilities 3 February 25, 2008 21:06
correct the face handedness kk FLUENT 4 February 16, 2007 10:42
Orientation of Face Variable Macros hirokata FLUENT 0 February 17, 2006 01:12
Y+ orientation Ashish CD-adapco 1 April 22, 2003 03:58
