Home > Forums > Open Source Meshers: Gmsh, Netgen, CGNS, ...
Polymesh cells file missing
Old   October 26, 2008, 04:42
Default Hi everybody I'm a new OF user
fabrizio
fabrizio is on a distinguished road
Hi everybody I'm a new OF user, I have a problem and I hope someone can help me.
I have to import the results of my OF analysis in Calculix, but the operation fails because in the Polymesh directory the file 'cells' is missing.
I've created the mesh in NetGen, converted with netgenNeutralToFoam but the 'cells' files isn't created. The OF simulation works fine. I've read the manual, I know how a cell is defined, but I can't build this file.
Is there a way to create the 'cell' file?
Thank you very much
Fabrizio
fabrizio is offline   Reply With Quote
Old   October 27, 2008, 03:41
Default The proper solution is to fix
Mark Olesen
olesen will become famous soon enough
The proper solution is to fix Calculix to read the owner/neighbour files. The cells file is a remnant from a much older OpenFOAM format.
olesen is offline   Reply With Quote
Old   October 27, 2008, 10:40
Default Hi Mark thank for your advice.
fabrizio
Hi Mark thank for your advice. Can you tell me the structure of cells file?I need to create this file because fixing Calculix to read owner and neighbour is quite difficult, and I'm not a master in modifying Calulix source.
Thank you
Fabrizio
Old   October 27, 2008, 12:23
Default Sorry, I don't know it off-han
Mark Olesen
Sorry, I don't know it off-hand, but since it's a cellList (I think ... check the polyMesh source) it shouldn't be hard to create.
Old   October 27, 2008, 16:22
Default Had this lying around http
Mattijs Janssens
mattijs is on a distinguished road
writeCellsFile.tgz
mattijs is offline   Reply With Quote
Old   October 28, 2008, 04:38
Default Hi Mattijs thank you very
fabrizio
Hi Mattijs
thank you very much
I hope this works, it would be very important for me!
Tonight I'll try to run this file, and I'll let you know what I obtain.
Thank you again
Fabrizio
Old   October 28, 2008, 08:59
Default Hi Mattijs I don't know ho
fabrizio
Hi Mattijs
I don't know how to use this file, I'm not a master in C programming...
I try with the command
gcc writeCellsFile.C
but I obtain a lot of errors concerning missing libraries, that should be installed if OpenFoam works correctly.
Thanks for help
Fabrizio
Old   October 28, 2008, 09:14
Default Try the 'wmake' and 'wclean' c
Mark Olesen
Try the 'wmake' and 'wclean' commands. These are OpenFOAM-specific.
Old   October 29, 2008, 04:38
Default Perfect it works! Thank you
fabrizio
Perfect it works!
Thank you very much!
Nox I'm able to create the cell file, but I have another problem: when I type
cgx -foam <root> <case>
I obtain this error:
element type tet4 not supported
Now I'll try to change the element type of my mesh, do you know what is the right tipe?
Thank you again
Fabrizio
Old   October 29, 2008, 05:13
Default You'll have to check on the ca
Mark Olesen
You'll have to check on the calculix mailing list/forum.
Old   October 30, 2008, 06:03
Default Hi I think the problem should
  #11
fabrizio
Hi I think the problem should be solved also in OpenFoam. When I type
elem-type:tet4 not installed.
I think this is due to the fact that OpenFoam names tethraedral element as "tet4", while Calculix names it as "C3D4", recognized as "type3" elements.
Is it possible to assign a different name to an element type in OpenFoam?
If possible, what should I modify?
Thanks to all again
Fabrizio
Old   October 30, 2008, 07:09
Default If calculix wants to call it s
  #12
Mark Olesen
If calculix wants to call it something else, that is their business. I wouldn't start changing OpenFOAM - there is lots that might break.
If you are writing ASCII format, then simply sed s/tet4/C3d4/g on the file.
Old   October 30, 2008, 07:47
Default Thank you for your reply. W
  #13
fabrizio
What file (files) should I modify?
Old   October 30, 2008, 08:15
Default Your 'cells' file of course!
  #14
Mark Olesen
Old   October 30, 2008, 09:39
Default There is no information about
  #15
fabrizio
There is no information about element type in cells file...
It only is a list of cells in this way:
4(a b c d)
4 stands for the number of nodes necessary to build the element, and a b c d are the points labels.
That's why I thought I should modify some in OpenFoam...but I don't know what!
Thanks
Fabrizio
Old   October 30, 2008, 10:07
Default Before you can change the outp
  #16
Mark Olesen
Before you can change the output, you really need to know what calculix is expecting to read. Is there not a calculix mailing list or forum where you can find some help?
Thread Tools
Trackbacks are On
Missing mplibOPENMPI file in OF 141 schmidt_d OpenFOAM Bugs 0 August 22, 2007 15:47
region missing in .cmdb meshing file, 11 Preview 5 Davo CFX 0 December 24, 2006 06:47
PolyMesh Question tj22 OpenFOAM Paraview & paraFoam 8 June 21, 2006 08:15
Missing info from CFX 10 help file ? Pete CFX 4 April 19, 2006 13:42
Missing file nfoxley OpenFOAM Pre-Processing 2 March 31, 2006 08:57
