Home > Forums > Open Source Meshers: Gmsh, Netgen, CGNS, ...
SalomeNetgenOpenFoam
Old   August 2, 2007, 03:39
Default Can you send a small test file
  #21
Mattijs Janssens
mattijs is on a distinguished road
mattijs is offline   Reply With Quote
Old   August 3, 2007, 02:40
Default Good day, I installed SALOM
  #22
Ruben I. Mukhamadeev
benru is on a distinguished road
Good day,
I installed SALOME, generated geometry, generated mesh (netgen), saved mesh as mesh.unv. Could you explain, how get this mesh from OpenFOAM - so my attempts try to use neutralNetgenToFoam lead to error:
--> FOAM FATAL IO ERROR : Attempt to get back from bad stream
file: mesh.unv at line 1.
From function void Istream::getBack(token& t)
in file db/IOstreams/IOstreams/Istream.C at line 44.
FOAM exiting
What's wrong - may be, it's need to use another types of mesh or something else ?
benru is offline   Reply With Quote
Old   August 3, 2007, 02:53
Default and if i try to use ideasUnvTo
  #23
and if i try to use ideasUnvToFoam i get:
--> FOAM FATAL ERROR : Cannot open file "mesh.unv"
From function ideasUnvToFoam
in file ideasUnvToFoam.C at line 504.
FOAM exiting
Need Help !
Old   August 3, 2007, 03:21
Default Dear Ruben, did you have te
  #24
sradl's Avatar
Stefan Radl
sradl is on a distinguished road
Dear Ruben,
did you have tets or hexes in your mesh?
if you send me your mesh.unv file, I can try it with my modification of the converter.
br
Stefan Radl
email:
stefan <dot> radl <at> tugraz <dot> at
sradl is offline   Reply With Quote
Old   August 3, 2007, 08:49
Default Stefan, thanks for your answer
  #25
Stefan, thanks for your answer ! Mesh has tets, and i have just sent mesh file to you.
Ruben
Old   August 6, 2007, 03:13
Default Stefan, Thanks a Lot for your
  #26
Stefan, Thanks a Lot for your Help !
Old   March 23, 2009, 14:53
Default prism conversion error?
  #27
Michael Jaworski
mike_jaworski is on a distinguished road
Hello Foamers,
I wanted to ask whether these issues have been fixed in the 1.5(-dev) version of OpenFOAM yet or not.
I have used SALOME to create a mesh which I hoped to use in 2D with "empty" patches on front and back. It is prismatic (or should be) and made following the process shown in this tutorial: http://www.caelinux.org/wiki/index.p...ELinux_2008.29
I keep getting an error with the ideasUnvToFoam converter with these meshes that says:
*snip*
Writing boundary faces to STL file boundaryFaces.stl
Constructing mesh with non-default patches of size:
Faces 1404
Interior 16
OutsideWalls 47
Trying to specify a boundary face 3(397 398 396) on the face on cell 144 which is either an internal face or already belongs to some other patch. This is face 702 of patch 0 named Faces.
From function polyMesh:olyMesh
const IOobject& io,
const pointField& points,
const cellShapeList& cellsAsShapes,
const faceListList& boundaryFaces,
const wordList& boundaryPatchTypes,
const wordList& boundaryPatchNames,
const word& defaultBoundaryPatchType
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 487.
FOAM aborting
Aborted
*snip*
Has anyone seen this issue? Was this part of the patching that is described in this thread?
Best regards,
Mike J.
mike_jaworski is offline   Reply With Quote
Thread Tools
Trackbacks are On
SalomeNetgenOpenFoam nico OpenFOAM Running, Solving & CFD 3 December 10, 2005 16:32
SalomeNetgenOpenFoam nico OpenFOAM Pre-Processing 0 December 8, 2005 12:56
