[Gmsh] Gmsh units?
Like Tree8Likes
  • 1 Post By bgoeppner
  • 1 Post By ericnutsch
  • 6 Post By bgoeppner
Old   February 2, 2010, 11:04
Default Gmsh units?
Benedikt Goeppner
bgoeppner is on a distinguished road
Hi guys,
can you tell me which units gmsh is using? I couldn't find any information about this... Would be nice if I could tell gmsh to set mm as default unit...
Thanks,
Ben
sourav90 likes this.
bgoeppner is offline   Reply With Quote
Old   February 17, 2010, 14:14
Default Dimensionless or Meters
Eric Nutsch
ericnutsch is on a distinguished road
Send a message via Skype™ to ericnutsch
I believe its units are non-dimensional and depend on what your solver loads it as. For the sake of dimensional sanity, I believe most every solver uses meters. I always just use meters from the beginning, but there are some utilities to help scale your already present numbers.
For scaling inside of gmsh: (have not used)
Dilate { { expression-list }, expression } { transform-list }
In OpenFOAM you might look into transformPoints(have not used)
http://www.cfd-online.com/Forums/openfoam-meshing-gmsh/61881-gmshtofoam-gmsh2tofoam-amp-gmsh-sudden-disappear.html#post204111
In OpenFOAM's blockmesh the convertToMeters function will preform scaling.
Hope that helps!
Ramzy1990 likes this.
ericnutsch is offline   Reply With Quote
Old   March 10, 2010, 17:02
Thumbs up
Benedikt Goeppner
Just in case someone runs into the same problem: The Gmsh-default unit seems to be meters. I found two ways solving my problem to change this default-unit for usage with OpenFoam:
First option uses the Gmsh default-settings. Create your geometry, mesh everything and save the mesh. Import that mesh into your foam-case by
gmshToFoam <name.msh>
. After that use the
transformPoints
util to get your desired unit:
# cd $TO_YOUR_FOAM_CASE
# gmshToFoam untitled.msh
# transformPoints -scale '(0.001 0.001 0.001)'
Second options changes the default-settings of gmsh by
Mesh.ScalingFactor=0.001
. As I found this option, this is what I prefer as I do not have to execute two commands, just import mesh...
Hope that helps.
Old   May 18, 2022, 08:09
Default [Gmsh] Gmsh units?Reply to Thread
Jacques Berthellemy
J_Berthellemy is on a distinguished road
Hi !
I always thought I was alone responsable for choosing a coherent set of units :
USI for example
J_Berthellemy is offline   Reply With Quote
Thermophysical Property Units johanz OpenFOAM Pre-Processing 2 December 16, 2018 10:08
[Gmsh] Converting gmsh to OpenFoam Friendly OpenFOAM Meshing & Mesh Conversion 3 June 26, 2018 05:46
[Gmsh] Insatlling gmsh from the source code-issue? CFD-Lover OpenFOAM Meshing & Mesh Conversion 20 June 12, 2018 06:39
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
