April 9, 2010, 15:37 |
Gmsh pipes on a cylinder
john Welker
I'm trying to use Gmsh construct a simple geometry consisting of a large cylinder with a few pipes entering and exiting the curved surface of the cylinder. This is very simple to do using Gambit but Does gmsh have a way to make points or draw circles etc on the curved surface of the cylinder. It also seems to lack tha ability to split volumes or too calculate the intersections of volumes.
May 19, 2010, 06:27 |
Benedikt Goeppner
Hi John,
I'm sorry that I can't help you there. However, I'm also interested in the solution for this kind of problem as I had the same situation some months ago... I finally used netgen but it'd be still nice to know how I could have done this with gmsh... So if you find an answer I'd appreciate if you post it here... Greetings, Ben |
gmsh cylinder |
[Gmsh] 3D Free surface flow past circular cylinder meshing using GMSH | arieljeds | OpenFOAM Meshing & Mesh Conversion | 7 | January 14, 2017 12:57 |
[Gmsh] Cylinder from Gmsh to OpenFoam | satkinson | OpenFOAM Meshing & Mesh Conversion | 0 | September 21, 2015 07:49 |
[Gmsh] Gmsh to Openfoam cylinder | satkinson | OpenFOAM Meshing & Mesh Conversion | 0 | September 17, 2015 12:31 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
