Home > Forums > Open Source Meshers: Gmsh, Netgen, CGNS, ...
gmsh and boundary layers
Old   November 17, 2010, 18:01
Default gmsh and boundary layers
Kanuk
kanuk is on a distinguished road
I'm trying to run a test case of a 2-D airfoil (similar to the airFoil2D tutorial case). I am using gmsh as a meshing tool and followed the directions in http://openfoamwiki.net/index.php/2D...ial_using_GMSH.
Originally, I had been using an unstructured mesh (tets) and got good visual results, but I am trying to validate the case, so I have now meshed with a structured grid using a couple of boundary layers (primary and secondary). The problem is that once I specify all faces and volumes in the .geo file, mesh it (with no problems), convert it using gmshToFoam, I get very, very unstable behavior in my solution, even though my grid is refined. I have checked my 0/U, 0/p, 0/nut, 0/nuTilda, polyMesh/boundary and system/controlDict files, and nothing seems to be wrong. I think the problem is with my "interfaces" patch in the .msh file... I don't know for sure but I specified the boundary layers (which are labeled interfaces in gmsh) as "empty" in the above files, which seems correct to me.
Also, when running gmshToFoam I get the following error (see below). Why am I getting a faceZone_1??
Skipping tag at line 144939
Patch 0 gets name back
Patch 1 gets name interfaces
Patch 2 gets name airfoil
Patch 3 gets name front
Patch 4 gets name inlet
Patch 5 gets name outlet
--> FOAM Warning :
From function polyMesh:olyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 576
Found 57744 undefined faces in mesh; adding to default patch.
Finding faces of patch 0
Finding faces of patch 1
Finding faces of patch 2
Finding faces of patch 3
Finding faces of patch 4
Finding faces of patch 5
FaceZones:
Zone Size
1 879
Writing zone 0 to cellZone airvol and cellSet
Writing zone 1 to faceZone faceZone_1 and faceSet
End
As of this point, I am stumped, but will keep trying to find the solution. Anyone out there successfully ran a case with boundary layers?? Any help is really appreciated!
kanuk is offline   Reply With Quote
Old   November 30, 2010, 09:17
T.D. is on a distinguished road
--> FOAM Warning :
FaceZones:
Zone Size
1 879
End
you need to change the patches names in the constant/PolyMesh/boundary file to that of "back" "interfaces" "airfoil" "front" etc...
Good Luck
T.D. is offline   Reply With Quote
Old   November 30, 2010, 15:11
Kanuk
Thanks for your reply, T.D. After struggling with this for awhile, I realized the errors in my computations were entirely due to large aspect ratios of the elements. I have corrected this issue and things seem to work just fine.
Old   January 21, 2011, 13:01
Claudio
claco is on a distinguished road
--> FOAM Warning :
FaceZones:
Zone Size
1 879
End
Dear kanuk,
Can You please explain me how can I build boundary layers in GMSH environment?
Thank You in advance.
Claudio Comis
claco is offline   Reply With Quote
Old   January 21, 2011, 16:12
Kanuk
I'm not sure if I did it correctly, but it worked....
What I did was created a pseudo surface of thickness T around the surface I needed the boundary layer on, then treated this as its own surface.
Make use of the "transfinite line" operator, along with "using progression" (to get the y+) and lastly, "transfinite surface"....
The gmsh user guide should be very helpful with this.
Cheers
Dave
Old   February 17, 2011, 08:35
Claudio
Cheers
Dave
Dear Sirs,
I have a great problem.
I have build the geometry of a simple wind tunnel, with a bump located
on the bottom. I built a boundary layer; the other part of the 3D (a 2D extrude mesh) mesh is a structured mesh.
I succeeded in doing that, but a terrible problem remains: there is an
unwanted intersection between the boundary layer mesh and the rest of
the structured mesh.
I cannot find the proper commands to prevent this intersection.
I would like to made the structured mesh starting from the edges where the boundary layers end.
I enclose the simple .geo file along with a screen shot.
I hope You can Help me, or forward this e-mail to someone can resolve
this simple (and at the same time difficult) problem.
file.geo
lc = 0.5;
dx = 2.0;
dy = 1.0;
dz = 5.0;
dy_bl = 0.05;
nx = 100;
ny1 = 10;//0.9;//(dy/(2*dy_bl))*ny2;
ny2 = 100;
nz = 1;
//cx = dx/nx;
//cy = dy/ny;
//cz = (cx + cy)/2;
Point(1) = {0.0,0.0,0.0,lc};
Point(2) = {0,dy,0.0,lc};
Point(3) = {dx,dy,0.0,lc};
Point(4) = {dx,0,0.0,lc};
Point(5) = {dx,0,0.0,lc};
Point(6) = {dx/2,0,0.0,lc};
Point(7) = {dx/2-0.2,0,0.0,lc};
Point(8) = {dx/2-0.05,dy/8,0.0,lc};
Point(9) = {dx/2+0.05,dy/8,0.0,lc};
Point(10) = {dx/2+0.2,0,0.0,lc};
Point(11) = {0,dy_bl,0.0,lc};
Point(12) = {dx,dy_bl,0.0,lc};
Point(13) = {0,dy-dy_bl,0.0,lc};
Point(14) = {dx,dy-dy_bl,0.0,lc};
Line(2) = {2,3};
Line(3) = {14,12};
Line(5) = {11,13};
Line(1) = {1,11};
Line(6) = {12,4};
Line(7) = {13,2};
Line(8) = {3,14};
Spline(4) = {4,10,9,8,7,1};
Line Loop(5) = {1,5,7,2,8,3,6,4};
Plane Surface(6) = {5};
old = Geometry.ExtrudeReturnLateralEntities;
Printf("lateral entities = %g", old);
Geometry.ExtrudeReturnLateralEntities = 0;
e1[]= Extrude {0,0,1.000000} {Surface{6}; Layers{1}; Recombine;};
cells[0] = 0;
heights[0] = 0.01;
For i In {1:5}
cells[i] = 1;
heights[i] = heights[i-1] * 1.2;
EndFor
tmp[] = Extrude {Surface{49}; Layers{cells[],heights[]}; Recombine;};
Printf("top surface = %g", tmp[0]);
Extrude {Surface{19}; Layers{cells[],heights[]}; Recombine;};
Geometry.ExtrudeReturnLateralEntities = old;
// Top surface
//Physical Surface(33) = {15};
// Bottom surface
//Physical Surface(34) = {23};
// Left surface
//Physical Surface(35) = {19};
// Right surface
//Physical Surface(36) = {27};
// Front surface
//Physical Surface(37) = {28};
// Back surface
//Physical Surface(38) = {6};
// Box volume
//Physical Volume (39) = {32};
Transfinite Line {1,8} = (ny1) + 1 Using Progression 1;
Transfinite Line {7,6} = (ny1) + 1 Using Progression 1;
Transfinite Line {5,3} = (ny2) + 1 Using Progression 1.0;
Transfinite Line {2,4} = nx + 1 Using Progression 1.0;
//Transfinite Line {1,3} = ny + 1 Using Progression 1.0;
//Transfinite Line {14,18,13,22} = nz + 1 Using Progression 1.0;
Transfinite Surface {6} = {3,2,1,4};
Recombine Surface {6};
//Transfinite Surface {27} = {5,14,2,3};
//Transfinite Surface {15} = {5,3,4,6};
//Transfinite Surface {28} = {6,10,14,5};
//Transfinite Surface {23} = {14,2,1,10};
//Transfinite Surface {19} = {6,10,1,4};
//Surface Loop(1000) = {14:28:2}; // the sphere (only need for internal mesh)
Surface Loop(1001) = {72};//tmp[{0:14:2}]}; // The outside of the BL
Surface Loop(1002) = {21,25,29,33,6,37,41,45,49,50}; // the box (entire farfield surface loop)
//Volume(1000) = {1000}; /// inside the sphere
//Volume(1) = {1002, 1001}; /// FarField
Mesh.Algorithm3D = 4;
Mesh.Smoothing = 100;
Mesh.Optimize=1;
Mesh.OptimizeNetgen=1;
Claudio Comis
Old   May 2, 2011, 02:52
MSarkar
msarkar is on a distinguished road
Hi All,
I am a new user of Gmsh. I created the geo file and meshed it using Gmsh GUI. From mesh option, I change the element size factor to create finer mesh, e.g I used element size factor 0.05, 0.03, and 0.01. However, I did not get any explanations about element size factor. Could you please explain what is that element size factor in gmsh and how it controls element size? If element size factor is 0.01, is that mean target element size is 0.01?
Any help will be very much appreciated.
msarkar is offline   Reply With Quote
Old   May 2, 2011, 12:51
Kanuk
I'm not sure about "element size factor" but you normally specify the element characteristic length. If you say the characteristic length is 0.01 then the meshing program keeps all elements small enough to fit inside a sphere (or in 2-D a circle) of diameter 0.01. At least this is my interpretation...
Old   May 4, 2011, 02:37
MSarkar
Thank you kanuk for your reply.
If anyone has any idea about "element size factor" in Gmsh, please let me know.
Old   May 9, 2011, 07:21
Default Boundary Layer and Gmsh
MSarkar
Hi All,
I am using Gmsh to generate mesh. I want to create boundary layer around ellipse. I created four dummy surfaces (each of one quarter of ellipse) around the ellipse and tried to create boundary layer using transfinite line and surface. However, it did not work, gave error: Surface 30 cannot be meshed using transfinite algo. Could anyone tell me how to create boundary layer / structured mesh around ellipse using Gmsh?
Thanks
M.S.
Old   August 14, 2015, 05:02
KateEisenhower is on a distinguished road
Originally Posted by msarkar View Post
Hi All,
Thanks
M.S.
I know msarkar posted this question years ago. Anyways, mayhaps it will help other users.
If this error message occurs, very often it is because you didn't specify all lines defining the surface as transfinite lines.
Best regards,
Kate
KateEisenhower is offline   Reply With Quote
Old   August 14, 2015, 12:35
tareqkh's Avatar
Khamlaj
tareqkh is on a distinguished road
Hi All,
Thanks
M.S.
Hello Msarkar,
Could you please share the dimensions of your model? That would make things easier.
Regards,
Tareq
tareqkh is offline   Reply With Quote
Thread Tools
Trackbacks are On
2D Mesh Generation Tutorial for GMSH aeroslacker Open Source Meshers: Gmsh, Netgen, CGNS, ... 12 January 19, 2012 04:52
Default Faces on Boundary Layer axel Open Source Meshers: Gmsh, Netgen, CGNS, ... 8 February 17, 2011 08:47
GMSH and the creation of a boundary layer pa-ma Main CFD Forum 0 October 11, 2010 11:15
Import problem ARC Open Source Meshers: Gmsh, Netgen, CGNS, ... 0 February 27, 2010 11:56
Taging boundary faces with gmsh hamdaoui Main CFD Forum 0 October 9, 2007 13:02
