[mesh manipulation] Issue with stitchMesh for parallel case |
June 12, 2023, 11:42 |
Marcus
Rep Power: 3 |
Hi all,
I am working on a porous media project where I would like to simulate a smaller volume from my initial STL with an upstream developing region, a simplified schematic is shown. As the project progresses, the STL file size would increase dramatically (1.5Tb) so I am avoiding cropping and repairing the geometry in a GUI. Currently the way I am doing this is using snappyHexMesh where the initial blockMesh bounding box is smaller than the original STL. Then I create a separate blockMesh such that at the end of the block, the mesh size matches the minimum mesh size that snappyHexMesh can produce. Then I use mergeMesh to combine these cases together as suggested by a simple tutorial from https://openfoamwiki.net/index.php/S...vaned_diffuser. As recommended I use stitchMesh to get rid of the connecting patches and I delete the patches from the boundary file in constant folder. This method works fine when running simpleFoam in serial however, when decomposing the mesh to run in parallel, I obtain the following error Cell 432contains face labels out of range: 6(2341 2342 2343 2344 441136 -1) Max face index = 452878 A couple of troubleshooting points 1. Mesh looks fine before and after stitchMesh in ParaView and the connecting patch is not present. 2. decomposePar works for both mesh prior and after mergeMesh. It seems that the issue is with stitchMesh 3. I have tried stitchMesh -partial and changing the master and slave patch with no improvements. 4. The parallel simulation runs without deleting the patches in boundary file however, it is incorrect as the boundary condition is imposed when it shouldn’t Any help on this would be appreciated and if there is a better way of cropping the STL and adding the developing region I would love to hear it. Please let me know if there are any files that may be helpful. Thanks, Marcus Current Workflow after creating both individual mesh. OpenFOAM v2106 on a HPC cluster. Code:
mergeMeshes porousMedia entrance -overwrite stitchMesh -partial maxX0 minX -overwrite *edit boundary file* decomposePar -force Code:
9 ( minX { type patch; nFaces 0; startFace 14126904; } maxX { type patch; nFaces 6902; startFace 14126904; } minY { type symmetryPlane; inGroups 1(symmetryPlane); nFaces 18039; startFace 14133806; } maxY { type symmetryPlane; inGroups 1(symmetryPlane); nFaces 13381; startFace 14151845; } minZ { type symmetryPlane; inGroups 1(symmetryPlane); nFaces 13933; startFace 14165226; } maxZ { type symmetryPlane; inGroups 1(symmetryPlane); nFaces 12940; startFace 14179159; } PorousMedia { type wall; inGroups 1(wall); nFaces 1651435; startFace 14192099; } minX0 { type patch; nFaces 576; startFace 15843534; } maxX0 { type patch; nFaces 111962; startFace 15844110; } ) Code:
7 ( maxX { type patch; nFaces 6902; startFace 14126904; } minY { type symmetryPlane; inGroups 1(symmetryPlane); nFaces 18039; startFace 14133806; } maxY { type symmetryPlane; inGroups 1(symmetryPlane); nFaces 13381; startFace 14151845; } minZ { type symmetryPlane; inGroups 1(symmetryPlane); nFaces 13933; startFace 14165226; } maxZ { type symmetryPlane; inGroups 1(symmetryPlane); nFaces 12940; startFace 14179159; } PorousMedia { type wall; inGroups 1(wall); nFaces 1651435; startFace 14192099; } minX0 { type patch; nFaces 576; startFace 15843534; } ) |
June 13, 2023, 07:47 |
Rep Power: 5 |
Hey!
I never used stitchMesh, but I can suggest an alternative. You could try to create ACMI patches between the two meshes after merging them. There have been a couple of threads about this recently, I think it is worth a try |
Pressure instabilities with interDyMFoam for the floatingObject case | nbadano | OpenFOAM Running, Solving & CFD | 15 | October 15, 2021 06:35 |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 15:13 |
Reporting a bug in Allrun script on wingMotion case | i.sabahi | OpenFOAM Bugs | 0 | June 10, 2018 09:00 |
[mesh manipulation] stitchMesh: multiple meshes | GerhardHolzinger | OpenFOAM Meshing & Mesh Conversion | 3 | August 25, 2017 12:43 |
Error reading new case | montag dp | FLUENT | 5 | September 15, 2011 06:00 |
