[Netgen] Error message when exporting to OpenFOAM 1.5 + format
Old   May 16, 2011, 04:05
Default Error message when exporting to OpenFOAM 1.5 + format
almir is on a distinguished road
I have a problem when I´m want to export the mesh to OpenFOAM 1.5+ format. Im using Netgen 4.9.13 for Windows. The programm brings me always the message:
Write OpenFOAM 1.5+ Mesh Files....
Export Error: Invalid mesh.... Aborting!
Export mesh to file .... DONE!
First I have tested the Netgen with a small testpart and a excerpt from the my part i need this part maybe was 30cm long and the export funktion worked great. The part I wont to make my reserches is 1.5m long, maybe thats the problem???
greets
almir is offline   Reply With Quote
Old   May 18, 2011, 14:23
Philippose Rajan
philippose will become famous soon enough
A Good Evening to you !!
Hmmmm.... I use this export function almost every day, so I know that it is definitely working...
Question from my side is..... did Netgen successfully mesh the geometry you were trying to export into OpenFOAM? For the OpenFOAM export to work, you need to have the 3D Tet mesh too..... It does not work with just a 2D mesh.
Also, you can only export linear elements.... if you asked Netgen to create second order elements, the export will not work.
Hope this helps you come further :-)!
Have a nice day!
Philippose
philippose is offline   Reply With Quote
Old   May 25, 2011, 04:30
hi,
now i have solved my problem.
My geometry was to complicated, there were to many small curves. This curves have no influence flow, but for the programm there was to many to calculate, which i don´t need.
greets
[Commercial meshers] About the Commercial and Closed Source Meshers discussed here wyldckat OpenFOAM Meshing & Mesh Conversion 3 July 22, 2020 22:09
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 08:51
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 06:15
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 04:48
OpenFOAM Version 1.5 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 July 14, 2008 18:22
