[Gmsh] gmsh and big geometry
Like Tree1Likes
  • 1 Post By Andrea_85
Old   November 2, 2011, 11:03
Default gmsh and big geometry
Andrea Ferrari
Andrea_85 is on a distinguished road
Hi all,
I'm using gmsh to construct an stl surface to use after with snappy. Is there a maximum number of points/lines/surfaces that GMSH can handle? actually i'm trying to create the .stl from the .geo file directly from shell (to be sure is not a graphical issue). My geo file calls the CheeseHole function 40.000 times and there should be about 320.000 points and 480.000 lines. I'm running on a cluster with 256GB of memory and, at the moment, 1 hour is not enough to create the stl file (actually it is blocked in "Reading 'myFile.geo'...). So, is it normal having such problem with big geometry? or might be something else?
thanks a lot
andrea
djamel likes this.
Andrea_85 is offline   Reply With Quote
drag value not stable even within small geometry changes krzychu111 OpenFOAM Running, Solving & CFD 4 November 27, 2018 09:07
[Gmsh] GMSH : structured mesh issue bibiboom OpenFOAM Meshing & Mesh Conversion 0 May 17, 2017 18:49
Geometry units/what is the real-life size of geometry GV-aero OpenFOAM 2 May 5, 2016 00:20
mesh export to gmsh format Kelomari enGrid 0 September 22, 2015 19:35
GMSH: Volume of two intersecting cubes shangzung Main CFD Forum 1 October 10, 2009 09:34
