Home > Forums > Open Source Meshers: Gmsh, Netgen, CGNS, ...
symmetryPlane from UNV file from Salome
Old   March 22, 2012, 17:23
Default symmetryPlane from UNV file from Salome
Chaz
chaz is on a distinguished road
I am unable to figure out how to set boundaries to by type symmetryPlane when using a mesh imported from Salome. I am:
1. making the mesh in Salome, exporting with groups to UNV
2. using an ./Allrun script in order to run ideasUnvToFoam
3. splitMeshRegions -cellZones -overwrite
All the boundaries are type patch. I am unable to change them and successfully run openfoam by manually changing the generated files. I have explored running changepatch on the patch of interest, but it has not worked. I have run this before step 3 and after step 3 above. How do you run a symmetric model from a UNV in openfoam?
Thank you
chaz is offline   Reply With Quote
Old   March 27, 2012, 03:52
Ofc
Ofc is on a distinguished road
After you specified your boundary in Salome (create groups from geometry) you can export your mesh to .unv and run ideasUnvToFoam. Then open constant/Polymesh/boundaries and set the boundary type to symmetryPlane. Do the same in all /0 dict files. Then it should work.
Ofc is offline   Reply With Quote
Old   March 28, 2012, 18:19
Chaz
I was able to solve this first by setting the boundary to type 'slip' in the system/fluidregionfolder/changeDictionaryDict for chtMultiRegionFoam. I think this has the same effect of creating a symmetry boundary as assigning it to be symmetryPlane.
I have not tried Ofc's recommendation (yet).
symmetryplane salome unv
Thread Tools
Trackbacks are On
2.0.x on Mac OSX niklas OpenFOAM Installation on Windows, Mac and other Unsupported Platforms 74 March 28, 2012 16:46
mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 12 December 12, 2011 05:16
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Paraview command not found hardy OpenFOAM Paraview & paraFoam 7 September 18, 2008 04:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
