November 10, 2012, 06:12 |
from ICEM to Pointwise
Haris Hameed
Rep Power: 16 |
hi, i want to export surface grid from ICEM to pointwise.. i am using CGNS format to do this.. but the problem is when i open the file in pointwise it converts my structured grid to unstrutured mesh. i have tried to use other formats but the result is same. i have checkd that its pointwise that diagonalize my surface mesh on import. need help in this regard
November 10, 2012, 09:31 |
Try PLOT3D format
Rick Matus
Rep Power: 17 |
Haris:
Try using the PLOT3D format. Pointwise will only keep the quad cells for a truly structured format. Most likely the other formats you are using are writing quad grids, but in an unstructured format. Also, be aware you can import surface grids either as grid or database. (Or both if you want, but that is two separate operations.) If that does not work, let me know. Rick |
November 10, 2012, 13:35 |
Haris Hameed
Rep Power: 16 |
but i only have surface grid in icem... and for plot3d format it says "Solver Plot3d supports multiblock mesh" so how to export surface grid in plot3d format
i have surface mesh in icem and i also want to import it as grid in pointwise not database |
November 12, 2012, 17:01 |
Looks like there is a 2D PLOT3D export option
Rick Matus
Rep Power: 17 |
It looks like you can select whether you are exporting a 2D or 3D PLOT3D file from ICEM, but I have not used it in years so can't say whether that works for exporting a 3D surface grid.
The format Pointwise is looking for is in Appendix III.1 of the Pointwise User Manual. |
August 13, 2018, 13:37 |
Paul
Rep Power: 8 |
I can't even read the mesh in Pointwise. I only have the option in ICEM to save as .uns. How can I save in other format? Regards, Paul |
August 14, 2018, 18:04 |
Try CGNS
Rick Matus
Rep Power: 17 |
Paul:
Pointwise can import grids in CGNS format, which ICEM can export, so I would recommend giving that a try. |
grid, icem, pointwise |
Display Modes | |
[ICEM] The ICEM Guide for CFX Users | JuPa | ANSYS Meshing & Geometry | 11 | September 4, 2017 09:43 |
[Commercial meshers] Pointwise to Foam - cyclic BC points order | Pj. | OpenFOAM Meshing & Mesh Conversion | 5 | August 14, 2016 04:47 |
[ICEM] Different meshes from ICEM and GAMBIT | Mojtaba.a | ANSYS Meshing & Geometry | 9 | March 30, 2013 02:42 |
[Commercial meshers] Native OpenFOAM interface in Pointwise | cnsidero | OpenFOAM Meshing & Mesh Conversion | 41 | May 20, 2012 18:30 |
Native OpenFOAM interface in Pointwise | Chris Sideroff | Main CFD Forum | 0 | January 16, 2009 12:37 |
