[Sponsors] | |||||
Christopher Hughes
Rep Power: 2 ![]() |
I have a .ccm file that was exported by STAR-CCM+ version 7.04.011. I have already ensured that within STAR-CCM+ it is a valid mesh. When I export the mesh into a .ccm file and convert it using ccm26ToFoam the program runs fine.
The problem arises when I try to use paraFoam to view the mesh. It crashes. I looked at the cellId file for the converted mesh and noticed the following FoamFile { version 2.0; format binary; class volScalarField; location "0"; object cellId; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField nonuniform List<scalar> 152559 (^@^@^@^@^@�v@^@^@^@^@^@�s@^@^@^@^@^@^Y�@^@^@^@^@` ��@^@^@^@^@^@�s@^@^@^@^@�^G�@$ �@^@^@^@^@^@�ȡ@^@^@^@^@^@]�@^@^@^@... where the nonsense symbols go on for quite awhile. The 152559 number makes sense because that is the total number of cells in the .ccm mesh. Am i exporting the .ccm file wrong or what is going on to cause this error? |
Christopher Hughes
I thought it was because I still had interfaces from the .ccm file when I tried to convert the mesh. I removed the interfaces since the source code documentation said ccm26ToFoam cannot handle them, but the same error occurs.
Kent Wardle
Rep Power: 8 ![]() |
The symbols are because the format is binary. What does checkMesh say? I have used interfaces in ccm+ and converted to openfoam with no problems* in the past. That said (*), the meshes always have had some quality issues. Post the output of checkMesh and perhaps someone can give a useful comment.
Kent Wardle
One other thing, I don't have any experience running with binary format. Perhaps the OF reader in ParaView cannot read this? I would be surprised, but that might be the case. Try to change the writeFormat to ascii in controlDict and see how things go.
Christopher Hughes
I ran checkMesh and it said the mesh was fine. I haven't tried swapping the controlDic to ascii, I'll try that.
Christopher Hughes
I changed the controlDict file as suggested and the cellId is now showing proper numbering instead of the binary jargon; however, when trying to run paraFoam the following error occurs.
--> FOAM FATAL IO ERROR: inconsistent patch and patchField types for patch type symmetryPlane and patchField type calculated file: /home/chris/OpenFOAM/chris-2.1.1/run/Supercritical/multiRegionHeater/0/p::boundaryField::.* from line 25 to line 26. From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&) in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 164. FOAM exiting Segmentation fault (core dumped) Is this an error in my .ccm file or am I not converting something else? Again checkMesh says that everything is ok, though it mentions some errors in the boundary definition specifically: Checking topology... ****Duplicate boundary patch 2 named Default of type wall. Suppressing future warnings. ***Boundary definition is in error. Cell to face addressing OK. Point usage OK. <<Found 7 neighbouring cells with multiple inbetween faces. Upper triangular ordering OK. <<Writing 14 unordered faces to set upperTriangularFace Face vertices OK. *Number of regions: 13 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology Default 3498 6948 ok (non-closed singly connected) Symmetry 532 1068 ok (non-closed singly connected) Default 9803 19382 ok (non-closed singly connected) Symmetry 532 1068 ok (non-closed singly connected) Default 3602 7156 ok (non-closed singly connected) Symmetry 548 1100 ok (non-closed singly connected) Default 6726 13356 ok (non-closed singly connected) Symmetry 532 1068 ok (non-closed singly connected) Default 3602 7156 ok (non-closed singly connected) Symmetry 548 1100 ok (non-closed singly connected) Default 13285 26512 ok (non-closed singly connected) Symmetry 7224 8828 ok (non-closed singly connected) Inlet 539 702 ok (non-closed singly connected) Outlet 539 702 ok (non-closed singly connected) Default 96 178 ok (non-closed singly connected) Inlet 12 26 ok (non-closed singly connected) Outlet 12 26 ok (non-closed singly connected) Symmetry 100 186 ok (non-closed singly connected) Default 1808 3592 ok (non-closed singly connected) Symmetry 1450 2838 ok (non-closed singly connected) Default 6513 12848 ok (non-closed singly connected) Symmetry 1352 2706 ok (non-closed singly connected) Default 1861 3698 ok (non-closed singly connected) Symmetry 1453 2844 ok (non-closed singly connected) Default 3472 6894 ok (non-closed singly connected) Symmetry 1348 2698 ok (non-closed singly connected) Default 1863 3702 ok (non-closed singly connected) Symmetry 1470 2878 ok (non-closed singly connected) Default 25377 50240 ok (non-closed singly connected) Symmetry 516 1036 ok (non-closed singly connected) The model runs in STAR-CCM+ and has no issues with the boundary. |
Christopher Hughes
I was able to fix the issue. I was trying to use a solver template that had some leftover files from the previous mesh, creating a brand new folder helped.
I also had to go back and name every single surface in the STAR-CCM+ model before transfering it to a .ccm file and converting. The openfoam converter does not like the default boundary that STAR-CCM+ uses for unnamed surfaces. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| mesh conversion Salome --> OpenFoam | vaina74 | Open Source Meshers: Gmsh, Netgen, CGNS, ... | 36 | February 26, 2013 09:33 |
| No layers in a small gap | bobburnquist | OpenFOAM Native Meshers: snappyHexMesh and Others | 2 | November 25, 2012 08:54 |
| 2D Mesh Generation Tutorial for GMSH | aeroslacker | Open Source Meshers: Gmsh, Netgen, CGNS, ... | 12 | January 19, 2012 03:52 |
| [Other] OpenFoam Mesh to Fluent Mesh, 2D | lordvon | ANSYS Meshing & Geometry | 0 | November 8, 2010 13:48 |
| Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
