May 8, 2013, 13:19 |
Merge Hexa ICEM
Ignacio
Rep Power: 13 |
I have been trying to figure out how to merge two pieces of a cube which have different sizes of Hexa meshes. I don't manage to do it, all I get is the same size of cell at each side when I do "merge". Does anybody know how to do this? Do you know if it's better to do split the bodies and then "stitch" them using OpenFOAM? Thanks a lot for any kind of answer |
May 8, 2013, 15:43 |
for that case, you can create interface (non conformal) between two meshes. Otherwise merge operation of hexa to hexa blocking is not recommended in ICEM and for that meshes should be same at the interface.
[ICEM] ICE Mesh in ICEM - Block merge | AA29 | ANSYS Meshing & Geometry | 19 | March 23, 2018 06:08 |
[ICEM] Hybrid mesh hexa and tetra on ICEM | PeterDaniel | ANSYS Meshing & Geometry | 0 | October 22, 2013 12:22 |
How to merge special mesh in ICEM CFD? | hadesmajesty | ANSYS Meshing & Geometry | 2 | July 27, 2013 16:02 |
[ICEM] Problem when I try to merge hexa & prism | pipolaki | ANSYS Meshing & Geometry | 7 | December 4, 2012 08:44 |
ICEM hexa mesh built with v10 deformed in v11 (degenerated edges) | cfxicem | ANSYS Meshing & Geometry | 1 | October 14, 2009 15:06 |
