-   OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... (http://www.cfd-online.com/Forums/openfoam-meshing-other/)
-   -   Non-Orthogonal faces problem- Pointwise export to OpenFOAM (http://www.cfd-online.com/Forums/openfoam-meshing-other/117544-non-orthogonal-faces-problem-pointwise-export-openfoam.html)
Milad06 May 10, 2013 08:00
Hi guys,
I am working on a complicated terrain. I have used pointwise to mesh the geometry and when I export to OpenFOAM it gives me warning about non-orthogonal faces. I have created almost 60M cells in one block and my terrain is the bottom of this cube. around 9000 non-orthogonal faces are found. Any idea how to solve this problem? :confused: how do you reduce non-orthogonal faces in your cases? Of course I can run the case but the results are not reasonable. In addition, I have used structured mesh.
BR
Milad
kiddmax February 11, 2014 13:03
Hi Milad,
Did you find the solution? I have the same problem.
Thank you very much!
Best regards,
Ye
