[Commercial meshers] gambit mesh to Foam problem |
May 19, 2013, 04:04 |
Arjang Behnoud
Hi everyone,
I've generated mesh for a cylinder in gambit. i divide the cylinder into 5 partitions like blockMesh dictionary in openFoam.I assigned name and type just for inlet,outlet and surrounding faces of cylinder in gambit but do nothing for internal faces. I import mesh to my case in openFoam and consider defaultFaces for internal faces of cylinder in boundary dictionary in polyMesh like below: defaultFaces { type empty; nfaces 20836; startFace 171740; } but when I run the solver, some error are appeared in terminal and Foam abort. the error file is attached. any help is appreciated. arjang. |
May 19, 2013, 05:26 |
Sasan Ghomi
Hi my friend ,
I don't know what is the origin of your problem but I should say that openfoam doesn't know an internalFace as a boundary face . So defaultFaces are not internalfaces . I think you created a 2D mesh in gambit. Best regards, Sasan. |
[Commercial meshers] Problem with Mesh conversion Gambit msh Foam | Rachid BANNARI (Bannari) | OpenFOAM Meshing & Mesh Conversion | 25 | September 11, 2011 07:58 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
