[Commercial meshers] fluent mesh to foam
Old   May 24, 2013, 19:47
Default fluent mesh to foam
Luca
LM4112 is on a distinguished road
Dear all
I am trying to convert a fluent mesh to foam but I get the following error:
FINISHED LEXING
dimension of grid: 3
Creating shapes for 3-D cells
Building patch-less mesh...Killed
I've managed to convert the mesh of the same model but after increasing the number of elements (from 100,000 to 15 millions) I get this problem. Thanks in advance
Luca
LM4112 is offline   Reply With Quote
Old   May 25, 2013, 07:35
Retired Super Moderator
Bruno Santos
Greetings Luca,
15 million? OK, a few questions:
  1. How much RAM does your machine have?
  2. Which architecture are you using? More specifically, if you're using 32 or 64bit. You can check by running:
    uname -m
    i686 means 32 bit, x86_64 means 64 bit.
  3. Which mesh conversion utility are you using? fluentMeshToFoam or fluent3DMeshToFoam?
Best regards,
Bruno
Old   May 25, 2013, 09:40
Luca
Dear Bruno
The system has 8 GB of RAM and is 64bit. The utility that I used is fluentMeshToFoam
best regards,
Luca
Old   May 25, 2013, 10:29
Bruno Santos
Hi Luca,
OK, then it's not a problem of using 32bit only.
I forgot to also ask in the previous post:
  • Was the mesh generated in Fluent on the same machine? If not, how much RAM does the other machine have?
  • 15 million... is it in cells or points?
  • And is the mesh mostly hexahedral or tetrahedral or polyhedral?
I ask this because I suspect that 8GB is not enough for converting this mesh, given that the mesh is converted and built on memory, not simply converted from one file to the other .
For example (if my memory hasn't fail me), a simple test with blockMesh, for creating a simple cube shaped domain, using an hexahedral mesh with 8 million cells, it needed around 8GB of RAM. And this was just for the mesh... it didn't even have the fields!
If the mesh were tetrahedral, perhaps it could go up to 16 million cells, but I'm not sure.
Best regards,
Bruno
Old   May 25, 2013, 10:35
Luca
The mesh was generated on the same machine and it counts 15 million of cells (full hexa). Then I guess I don't have enought RAM. I will try to d the conversion with the cluster that I will use for the simulations. Thanks a lot for the help
best regards,
Luca
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
