Home > Forums > OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ...
GambitToFoam segmentation fault
Old   July 27, 2013, 08:35
Default GambitToFoam segmentation fault
Yuri Frey
yurifrey is on a distinguished road
Hello!
I have a problem converting a mesh from Gambit. When I type:
gambitToFoam ... .neu
I get a segmentation fault. I found several topics describing the same problem and the answer was to save the mesh as a fluent mesh in .msh. This way I have no problem converting it, but in my domain I have a porous zone and I am not able to select "POROUS" when I work in gambit with fluent 5/6 solver.
What is the best way to solve the problem?
Thank you,
Yuri
yurifrey is offline   Reply With Quote
Old   August 3, 2013, 07:29
mohsen kh
m5m5kh is on a distinguished road
hi
If you want to simulate a porous case you must choose your standard solver first for example simplePorousFoam ( for steady laminar or turbulent flow) then in your case directory and your constant folder file you must specify your porosity and transfer properties.
I suggest you to read this article. I think it is useful for you
http://www.tfd.chalmers.se/~hani/kur...ukurReport.pdf
good luck
m5m5kh is offline   Reply With Quote
Old   August 3, 2013, 07:36
Wink
mohsen kh
dear Yuri
I have a same simulation and I want to specify just a region of my case as a porous medium.someone told me i must use topoSetDict and I have a problem myself. I hope you learn more and give me a hint for my problem
Thread Tools
Trackbacks are On
Segmentation Fault w/ compiled OF 2.2.0 - motorBike example sudo OpenFOAM Running, Solving & CFD 3 April 2, 2013 17:27
segmentation fault when installing OF-2.1.1 on a cluster Rebecca513 OpenFOAM Installation 9 July 31, 2012 15:06
Segmentation Fault Shawn_A OpenFOAM Running, Solving & CFD 6 October 31, 2011 15:38
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 3 June 10, 2011 09:30
GambitToFoam segmentation fault hoerl OpenFOAM Installation 3 November 20, 2006 06:47
