[Technical] mesh quality requirement
Like Tree1Likes
  • 1 Post By avila.vc
Old   February 9, 2016, 07:59
Default mesh quality requirement
stefano zinna
giordy is on a distinguished road
Hi All,
Do you know if there is a general guidlines for quality reuirement in openfoam. Something like: mesh should have orthogonality less than..., aspect ratio less than ... etc..
I know that it is case dependent but i am looking for a "first guess" guidlines.
regards,
Stefano
giordy is offline   Reply With Quote
Old   February 9, 2016, 09:34
gereksiz
clktp is on a distinguished road
I also wonder how accurate the checkMesh of OF.
clktp is offline   Reply With Quote
Old   March 19, 2016, 14:43
Vinícius da Costa Ávila
avila.vc is on a distinguished road
Hi, I am no expert, but as you said, it depends HIGHLY on the solvers you use.
Also, OF has a standard limiting values for mesh quality with checkMesh (these standard values are mostly for reference, since they can be changed by the user).
Standar values used in OF ($WM_PROJECT_DIR/src/OpenFOAM/meshes/primitiveMesh/
primitiveMeshCheck/primitiveMeshCheck.C)
• Foam::scalar Foam:rimitiveMesh::closedThreshold_ = 1.0e-6;
• Foam::scalar Foam:rimitiveMesh::aspectThreshold_ = 1000;
• Foam::scalar Foam:rimitiveMesh::nonOrthThreshold_ = 70; // deg
• Foam::scalar Foam:rimitiveMesh::skewThreshold_ = 4;
• Foam::scalar Foam:rimitiveMesh:lanarCosAngle_ = 1.0e-6;
For example, for a case I'm used running: tutorial bubbleColumn with RAS turbulence models, I am able to run big meshes (more than a million cells) with the standard numerical solvers (fvSchemes and fvSolution) and Co=1.0 even with not very good meshes (but still within checkMesh quality limits) and I get accurate results.
In my (brief) experience I would recommend as a start point:
Aspect ratio: max 5-10
nonOrtho.: max 50-60
skewness: max 1-2.5
Then, I recommend mesh convergence studies to be made. So it will ensure your solution is mesh independent.
giordy likes this.
Vinícius dC.A.
avila.vc is offline   Reply With Quote
[snappyHexMesh] very bad quality snapped mesh federicabi OpenFOAM Meshing & Mesh Conversion 18 September 26, 2018 10:33
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
[snappyHexMesh] Improving mesh quality + inlet too coarse MartinBlx OpenFOAM Meshing & Mesh Conversion 5 August 2, 2015 22:09
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
mesh quality and independency..!?? michelle CFX 0 October 15, 2007 05:50
