[Commercial meshers] mesh conversion from ansys mesher to openfoam
Like Tree1Likes
  • 1 Post By akidess
Old   November 4, 2015, 05:08
Default mesh conversion from ansys mesher to openfoam
Dusan Konkoly
Dusan1224 is on a distinguished road
hi, i made tetrahedral mesh include influence layer in ansys meshing and tried to convert into openfoam, but this message appeared. its not my first mesh conversion from ansys, some of them converted good, so i need to know, if is the geometry of mesh wrong ,or whare could be posibly problem?
ps. i used comands fluentMeshToFoam, and also tried ansysToFoam, and both times it wrote me same error:
--> FOAM FATAL IO ERROR:
wrong token type - expected word, found on line 25 the label 800
file: /home/supermicro/Dusan_K/cfd/openfoam/ref_zak_podlaha_2D_C/system/controlDict.startFrom at line 25.
From function operator>>(Istream&, word&)
in file primitives/strings/word/wordIO.C at line 74.
FOAM exiting
Dusan1224 is offline   Reply With Quote
Old   November 4, 2015, 05:21
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
Did you read the message? You have something weird in your controlDict for the entry startFrom. At the very least you should have uploaded your controlDict here.
Dusan1224 likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   November 5, 2015, 03:41
Dusan Konkoly
Thx a lot. I used this "template" many times without problem, so i didnt even think there could be error. i checked the document, and starting time was changed from "latestTime" to "800" ( from previos simulation) . but i didnt think this could cause to error while import mesh
[Other] [Request] OpenFOAM mesh to 2D Ansys fluent mesh anon_q OpenFOAM Community Contributions 6 July 3, 2023 05:24
[Commercial meshers] Mesh conversion .gtm to OpenFOAM ansab OpenFOAM Meshing & Mesh Conversion 2 December 6, 2016 13:48
[ANSYS Meshing] Assigning different mesh densities for different parts in ANSYS ICEMCFD Tetra Mesher johnnydrama7 ANSYS Meshing & Geometry 0 September 19, 2016 13:10
