[CAD formats] Convert from ASCII CAD (stp sat jgs) to foam
Like Tree1Likes
  • 1 Post By akidess
Old   November 12, 2015, 11:13
Default Convert from ASCII CAD (stp sat jgs) to foam
Bogdan Osyka
Bogdan90 is on a distinguished road
Hi, I am really new to OpanFoam and I am struggling to find any information on how to convert a mesh from ASCII CAD to foam.
I have my mesh as a ASCII CAD file in three different formats (.stp, .sat, .jgs) and need to convert it to foam in order to run my simulation on it.
I also found a link on mesh conversion in openfoam:
http://www.openfoam.org/features/mesh-conversion.php
however I did not manage to run those converters on any of my files. Will appreciate any help.
Thanx in advance
Bogdan90 is offline   Reply With Quote
Old   August 13, 2018, 21:44
fede32's Avatar
Federico Agustín Caccia
fede32 is on a distinguished road
Hi, did you solve it? Can you share some explanation? I have the same problen right now. Thanks!
fede32 is offline   Reply With Quote
Old   August 14, 2018, 02:27
akidess's Avatar
Anton Kidess
CAD is not a mesh format. Either you export STL, or you use a mesher that can import CAD data, such as Salome, ANSA, Pointwise, ...
fede32 likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
[CAD formats] Can OpenFOAM convert foam mesh to stl? liying02ts OpenFOAM Meshing & Mesh Conversion 10 December 30, 2018 10:03
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 04:20
[snappyHexMesh] Problem with parallel run of snappyHexMesh Lorenzo92 OpenFOAM Meshing & Mesh Conversion 5 April 15, 2016 04:12
How to convert the CAD file to FDS format? PIN Main CFD Forum 6 November 9, 2015 01:54
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
