Home > Forums > OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ...
Mesh Generation and Case Set up
Old   October 20, 2004, 17:50
Default Hello I wanted to r
Vatant (Vatant)
Hello
I wanted to run Foam on a model generated by Fluent(Gambit - Fluent *.msh file)
I opened up a new Folder with a case name and copied concerned source files..something like turbFoam.c and related files.
I ran 'fluentMeshtoFoam root case' but it could not read controlDict File. So I created constant and system folders in the case folder manually.
I then tried running Fluentmesh conversion and it created polymesh and other files.
I would like to know, how to generate the initial mesh fields p,Rho, U etc in the '0/' folder with dimensions and specified fields..
Also, "meshDescription" file in the polyMesh was not created by the 'fluentMeshtoFoam' Utility. How can I scale the grid to mm ? should I run blockMesh after fluent to Foam Mesh conversion ?
Regards,
VatanT.
Old   October 21, 2004, 04:10
Default You can create a new case or
Mattijs Janssens (Mattijs)
You can create a new case or copy an existing one in FoamX. This will take care of setting it up for the desired application (icoFoam, turbFoam, etc.).
The only thing different for your case would be the mesh generation phase where you don't run blockMesh but a mesh converter instead.
To scale a mesh use scalePoints which takes root,case and three scaling factors. Just use
scalePoints -
to see the arguments.
Mattijs
Old   August 11, 2005, 02:50
Default how did you know th escalePoin
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
how did you know th escalePoints,
where can i get the similar information
regards
ztdep is offline   Reply With Quote
Old   August 11, 2005, 04:04
Default Take a look in the utilities d
henry is on a distinguished road
Take a look in the utilities directory.
henry is offline   Reply With Quote
Old   November 8, 2005, 20:03
Default I'm on version 1.2 and it seem
Philippe Monnier
philippe is on a distinguished road
I'm on version 1.2 and it seems that the utility scalePoints is gone, can't find it in FoamX or as a function in console. So how can I scale my imported mesh?
Thanks.
philippe is offline   Reply With Quote
Old   November 8, 2005, 20:10
Default Try something like: transfo
Hrvoje Jasak
Try something like:
transformPoints <root> <case> -scale "(1e-3 1e-3 1e-3)"
Enjoy,
Hrv
Hrvoje Jasak
Old   March 12, 2009, 04:20
Default Hello! I'd like to create a s
Hansjoerg Seybold
hansjoerg is on a distinguished road
Hello!
I'd like to create a simple but HUGE(~500^3) block structured mesh from voxel tomography data.
(file of binary values 0,1, cubic blocks)
I tried to create a blockmesh dict with a script but I run out of memory when using blockmesh.
Also the mesh finally has to be decomposed for multiple CPU.
Does anybody have a idea how i can handle this problem.
thanks
hansjoerg
hansjoerg is offline   Reply With Quote
Thread Tools
Trackbacks are On
3d Mesh Generation Bala Murugan FLUENT 1 May 7, 2008 01:13
Mesh Generation phil Main CFD Forum 0 September 16, 2003 06:54
RE. Mesh Generation Help Patel Amit R. FLUENT 0 July 12, 2003 02:03
Mesh Generation Dhananjay FLUENT 8 May 14, 2002 10:55
