March 5, 2009, 10:17 |
Star4ToFoam error
Kasper Skriver
Hi
I'm having problems using star4ToFoam tool to import .cel and .vrt file to OpenFOAM format. Please see below terminal output. Anybody have any ideas on how to solve this? Best regards Kasper Skriver ksk@ksk-laptop:~/OpenFOAM/ksk-1.5/hex/hex_flow$ star4ToFoam hex /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.5 | | \ / A nd | Web: http://www.OpenFOAM.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : star4ToFoam hex Date : Mar 05 2009 Time : 11:15:01 Host : ksk-laptop PID : 6761 Case : /home/ksk/OpenFOAM/ksk-1.5/hex/hex_flow nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // no constant/boundaryRegion information available no constant/cellTable information available Number of points = 1999543 Number of fluids = 478208 Number of baffles = 0 Ignored solids = 0 Ignored shells = 0 Number of patches = 5 (including extra for missing) patch 0 (region 1: inle) type: 'patch' name: inle_1 patch 1 (region 2: inle) type: 'patch' name: inle_2 patch 2 (region 3: inle) type: 'patch' name: inle_3 patch 3 (region 4: outl) type: 'patch' name: outl_4 patch 4 (region 0: none) type: 'patch' name: Default_Boundary_Region Creating a polyMesh Maximum possible number of faces in mesh: 5350893 Number of internal faces: 2646535 There are 57823 faces to be patched and 6419 specified - collect missed boundaries to final patch Missing faces added to patch after face 2652954: cell 0 face 8 (original cell 1) face: 6(1483044 1323496 890368 890252 890250 1392776) cell 1 face 7 (original cell 2) face: 5(948366 948363 948359 948358 948362) cell 2 face 7 (original cell 3) face: 6(1230242 1078451 1078449 948392 948363 948366) cell 3 face 7 (original cell 4) face: 6(1230241 1004383 1004386 1078441 1078451 1230242) ... Added 51404 unmatched faces Number of boundary faces: 6419 Total number of faces: 2704358 Number of interfaces: 0 Default patch type set to empty cellZone 0 (size: 226350) name: #0 Foam::error::printStack(Foam:stream&) in "/home/ksk/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/home/ksk/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xb7fdf420] #3 Foam:Sstream::write(Foam::word const&) in "/home/ksk/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::operator<<(Foam:stream&, Foam::word const&) in "/home/ksk/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #5 Foam::cellTable::addCellZones(Foam::polyMesh&, Foam::List<int> const&) const in "/home/ksk/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libconversion.so" #6 Foam::meshReader::addCellZones(Foam::polyMesh&) const in "/home/ksk/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libconversion.so" #7 Foam::meshReader::mesh(Foam::objectRegistry const&) in "/home/ksk/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libconversion.so" #8 main in "/home/ksk/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/star4ToFoam" #9 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #10 __gxx_personality_v0 in "/home/ksk/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/star4ToFoam" Segmentation fault ksk@ksk-laptop:~/OpenFOAM/ksk-1.5/hex/hex_flow$ |
March 6, 2009, 02:28 |
#2 | |
Mark Olesen
Rep Power: 40 |
commit d6b201bbb5a495b5b2d8507727071c2215519e61 Author: andy <andy> Date: Wed Sep 24 15:50:43 2008 +0100 meshTables: bugfix and cleanup - fixed segfault due to missing ++ in namesList() - use more of the new dictionary functionality |
March 6, 2009, 06:08 |
Hi Mark,
thanks for answer
Kasper Skriver
Hi Mark,
thanks for answering and helping out. I am not familiar with the bugfix repository. How do I use this info you give me? I am finding this page http://www.opencfd.co.uk/openfoam/download.html but can't get access to git:// I suppose that I should execute this: git clone git://repo.or.cz/OpenFOAM-1.5.x.git in a terminal and locate the commit specified. But what then? BR Kasper Skriver |
March 6, 2009, 06:25 |
1. clone from the repo.or.cz l
Mark Olesen
Rep Power: 40 |
1. clone from the repo.or.cz location (I believe http transport works too). This gets you the latest version with all of the bugfixes. This is what you should be using.
2. I would recommend making your own local branch (eg, 'kasper') based on the remote repository (origin/master). This lets you make local modifications, but still benefit from the bugfixes. 3. Remake as usual (Allwmake) and go grab lunch. Later on, you can do a periodic 'git fetch' to update your tracked version of the repo.or.cz repository and use 'git merge' and recompile via Allwmake at your own leisure. BTW: the learning curve with git is a bit steep (more especially if you haven't used an scm before), but there are a few git video tutorials kicking about that help. The Randal Schwartz google tech talk is really good for a bit of information of what is going on behind the scenes. The time invested there will help. |
Display Modes | |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
