Home > Forums > OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ...
Why is there no option to importexport binary fluent files to OF
Old   January 18, 2009, 14:41
Default Always saving these files as A
BastiL
bastil is on a distinguished road
Always saving these files as ASCII is annoying and uses lots of memory for large models. Are there planes to add binary support?
BastiL
bastil is offline   Reply With Quote
Old   January 18, 2009, 15:55
Default The beauty of open source is t
Hrvoje Jasak
The beauty of open source is that you can write it yourself, right?
Hrv
Hrvoje Jasak
Old   January 18, 2009, 18:40
Default ..at least if I am able to do.
BastiL
..at least if I am able to do... ;-)
Old   January 19, 2009, 09:57
Default Here's some advice (this is ho
Hrvoje Jasak
Here's some advice (this is how I would do it if I had to do it again - my first go with flex is not too impressive).
Fluent uses a well-structured language for its input-output: it is called Schemeand it corresponds to Lisp syntax. My advice would be to load Fluent files into a public domain version of Scheme interpreter (which will also take care of binary/ascii, I think) and then query the Scheme database for the components you need. Extracting the data needed to build the mesh is identical to existing converters, so you will be able to copy that.
Good luck, please keep me posted on the progress,
Hrv
Hrvoje Jasak
Old   January 19, 2009, 15:25
Default Thanks Hrv, I have done som
BastiL
Thanks Hrv,
I have done some scripting in scheme and some parsing of FLUENT-Files in Python. However, interpreting of binary data is totally new to me. I have guile availabe and can read the mesh into there but do not know how to do this from of c++ and how to "search the database". I will start taking a look at the existing code.
BastiL
Old   January 27, 2009, 11:50
Default After consideration I tried to
BastiL
After consideration I tried to extend the existing code. Maybe this is not the best but for me fastest way to try first.
Regards BastiL
Old   February 17, 2009, 14:37
Default Ok... I see the problems with
BastiL
Ok...
I see the problems with flex in combination with binary files. I will consider alternatives. Doing it in Scheme as proposed by Hrv would mean integration of some Scheme code. I will consider.
Regards
Thread Tools
Trackbacks are On
Fluent binary mesh FOAM spv24 OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 1 November 19, 2008 02:23
Decoding of Binary FLUENT Case-Files BastiL FLUENT 1 May 25, 2008 06:10
Can I use the binary files for ia64 and x86_64 CPU in Linux OS mamaly60 OpenFOAM Installation 4 October 24, 2007 22:20
Fluent/UNS binary file format reference Federico FLUENT 0 October 11, 2001 04:50
Binary files stored by Fluent Jackson FLUENT 1 April 2, 2000 21:58
