Home > Forums > OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ...
Importing a mesh from Gambit Interior faces that are walls
Old   May 28, 2010, 13:41
farhagim is on a distinguished road
Hello guys,
I am new user in OpenFoam. I need to import the Gambit file or Fluent mesh to OpenFoam. I used the fluentMeshToFoam & gambitToFoam command , but I got this error. Can anybody help me?
To be clear, I save the .msh & neu file in ASCI format. but I have some interior boundary ( not interior wall...I used it for making the Mesh). Is it problem? does OF know the interior boundary....I dont want OF to convert it to wall boundary.
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 1.6-f802ff2d6c5a
Exec : gambitToFoam test2.neu
Date : May 28 2010
Time : 13:34:06
Host : ip11
PID : 28755
Case : /home/farhangi/OpenFOAM/farhangi-1.6/run/tutorials/multiphase/interFoam/laminar/test
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Title: test2
Written by Gambit version 2.4.6
File written on 27 May 2010 16:36:04
number of points: 5100
number of cells: 5000
number of patches: 1
Reading nodal coordinates
Reading cells
Reading cell streams
Reading cell stream labels
Finished reading cell stream labels
Reading patches
patch 0: name: wall
Finished lexing
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/farhangi/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/home/farhangi/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 __restore_rt at sigaction.c:0
#3 main in "/home/farhangi/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/gambitToFoam"
#4 __libc_start_main in "/lib64/libc.so.6"
#5 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Segmentation fault
PlZ Help me.
thanks
farhagim is offline   Reply With Quote
Old   August 26, 2011, 02:28
Default Hello Everyone
  #82
Jignesh
jignesh_thaker2007 is on a distinguished road
Send a message via Yahoo to jignesh_thaker2007
Hello Friends
I m new user of openfoam so i solved tutorial of OF. now i m trying to solve complicated problem. so the geometry is very difficult to construct in OF. so far i use gambit for making geometry.
Right now i construct geometry in gambit & also I completed mesh in Gambit so now for processing & post processing i use OF. but i m in trouble how to convert .msh file of gambit in OF format?
Which command will i use? gabitToFoam or FluentMeshToFoam?
so please help me to solve this problem.
i m waiting 4 ur reply
jignesh_thaker2007 is offline   Reply With Quote
Old   August 26, 2011, 03:21
Elvis
elvis will become famous soon enough
What about fluent3DMeshToFoam ?
I have no personal experience (sorry), but maybe fluent3DMeshToFoam is the better solution to convert your .msh to Openfoam.
If I am not wrong fluent3DMeshToFoam is the latest devoloped converter
elvis is offline   Reply With Quote
Old   August 31, 2011, 02:07
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
if you don't generate a mesh with hanging nodes (tetra-hexcore), then you can use fluentMeshToFoam
if you generate a mesh with hanging nodes (tetra-hexcore), you need to convert some cells with utility tpoly (not OF utilty, but Fluent utility), then you can use fluent3DMeshToFoam
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   September 11, 2011, 03:27
Default hello everyone
  #85
Jignesh
hi
i m new user of openfoam201 i phase one difficulty when i solved cavity tutorials then i cant found such like fluent after achieving conversion limit, the program didn't stop. but when it reach end time it stop.
but i want to stop my program when it go beyond the conversion limit so what can i do for that?
plz help me
Thread Tools
Trackbacks are On
Importing a hex core mesh from Gambit dmoroian OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 0 September 15, 2006 03:54
Defining boundary conditions on interior faces melanie OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 9 August 10, 2006 09:52
Internal/Interior walls in Gambit/Tgrid Riaan FLUENT 0 March 31, 2006 22:16
interior and internal faces jx FLUENT 0 January 8, 2004 09:29
define faces within GAMBIT in imported mesh Elmar FLUENT 0 February 25, 2001 08:10
