Internal patches with fluentMeshToFoam
Hello World.
Due to a radius in one of my computational domains I forced an element-change in the surrounding of the radius. I used tetrahedron-elements to model the radius and used hexahedron-elements at the rest. At the intersection of the two element-areas I had to define some faces in GAMBIT to make the distinction between the two areas possible. Have a look at the image. I have marked the patches of concern. http://www.cfd-online.com/OpenFOAM_D...ges/1/9711.jpg How can I tread these internal patches in OpenFOAM? Unfortunately OpenFOAM does not recognize the mesh as 2D or 3D. Maybe this is due to difficulties with the empty BC's I used for these internal patches ... Do you have any ideas? |
Hi Sebastian!
You're trying
Hi Sebastian!
You're trying to employ the axial-symmetry of your case? In that case 1. make a 2D-mesh (with rectangles and triangles) 2. convert it to OF (the elements become bricks and prisms) 3. Use http://openfoamwiki.net/index.php/Contrib_MakeAxialMesh to make an axialsymmetric mesh Bernhard |
Hello Bernhard.
Yes, this i
Hello Bernhard.
Yes, this is exactly what I want to do! This sounds like a very good idea. I will try this at once. I created the first mesh in GAMBIT with three different volumes I did not connect. May this be a problem regarding the internal patches? (Just in case I have to go back to the first approach ...) |
So, back again - so soon ... :
So, back again - so soon ... :-(
I have done as suggested by Bernhard. I created the 2D-geometry with GAMBIT, converted to OpenFOAM (fluentMeshToFoam) and used the MakeAxialMesh tool. When running the paraFoam I get this message: FOAM FATAL ERROR : wedge frontAndBackPlanes plane aligns with a coordinate plane. So, I think there went something wrong with collapseEdge, which I used with arguments 0 180. But I'm not sure what they mean ... Want to have a look at the case? Here it is: http://www.familie-gatzka.de/sega/DO...AxiMesh.tar.gz Thanks! |
Hi Sebastian!
I can't repro
Hi Sebastian!
I can't reproduce your problem because the tar-file is corrupted (when extracting I only get a partial copy of the msh-file). Mesh-utilities write the resulting mesh to the NEXT time-step. Are you sure you copied everything from 1e-6/polyMesh to constant/polyMesh before proceeding to the next step? Bernhard |
Hi Bernhard.
Well, I did NO
Hi Bernhard.
Well, I did NOT copy the resulting mesh. I actually wondered what the additional timestep directory was used for ... http://www.cfd-online.com/OpenFOAM_D...part/happy.gif (Maybe you should mention it in your usage wiki ... just for the beginner) Will try it later. Thanks so far! |
Well, maybe you could modify t
Well, maybe you could modify the Wiki-page accordingly ....
Hello, again.
I still have
Hello, again.
I still have some questions regarding this problem. After running the makeAxialMesh tool, there are the frontAndBackPatches and two other patches frontAndBackPatches_pos and ..._neg. To get rid of them is to use the collapseEdge tool? So, I copied the new mesh into the constant directory and used collapseEdge. But what arguements should I use? In the usage wiki you say something like this: For an application like this, you would want to use collapseEdges with a very small length scale argument and an angle argument near 180 degrees What is the length scale argument? The length of the whole edge? And what is the 180 degrees good for? Especially if I want an angle of 2.5 degrees? Hope you can help me. Thanks so far & have a nice day. |
The collapseEdges-utility remo
The collapseEdges-utility removes edges that are ridiculously small. Like the edges on the "axis" patch.
Concerning the arguments: type "collapseEdges -h" and you will be enlightened frontAndBackPatches are the "old" patches. If you look at the new boundary-file the sizhe of that is 0 after makeAxialMesh because all those faces either go to frontAndBackPatches_pos/neg. You'll have to add those patches to the boundaries in the field-file |
Ok, Thank you Bernhard.
Now,
Now, I got it regarding the frontAndBackPatches_pos/neg. I created new BC for the positive and negatice wedge faces and deleted the old entry. The mesh looks good, but still I can't get the meaning of collapseEdges. Running the collapseEdges -h gives me the familiar output: Usage: collapseEdges <root> <case> <edge> <merge> --> FOAM FATAL ERROR : Wrong number of arguments, expected 4 found 0 Invalid option: -h But I'm still not enlighted. Using the collapseEdge like "collapseEdge . . 30e-3 5" (30e-3 is the length of domain) gives a whole crowd of messages like this: Cell:2516 uses faces:6(4975 38275 41439 60756 4498 4973) of which too many are marked for removal: 41439 60756 4498 4973 and at the end: Morphing ... Collapsing 0 small edges Collapsing 0 in line edges Max face area:0.896123 Collapse area factor:1e-09 Collapse area:8.96123e-10 Collapsing 0 small high aspect ratio faces Writing collapsed mesh to time 1e-06 End Now I can use the funkySetFields to initialize my two phase problem and started to calculate with interFoam. Strange to me, the simulation is running FAR to fast, but the interface is not moving at all. I know the physical behavious from a similar case. So, the mesh "looks" good but due to the fact that the interface is not moving I think there is still something wrong. If you want to have a look. This time the file should not be corrupt: http://therealsega.th.funpic.de/open...AxiMesh.tar.gz |
Hi guys,
I want to re-open the discussion between Sebastian and Bernhard. I am using makeAxialMesh with some slight modifications to be able to compile it under my OF-1.6.x. makeAxialMesh -axis ... -wedge ... -> runs without problems, grid look fine collapseEdges 0.001 170 -> runs without problem, I got the following output Create time Create polyMesh for time = 0 Merging: edges with length less than 0.001 meters edges split by a point with edges in line to within 170 degrees Collapsing 101 small edges Morphing ... Collapsing 0 small edges Collapsing 0 in line edges Max face area:0.00250237718349 Collapse area factor:1e-09 Collapse area:2.50237718349e-12 Collapsing 0 small high aspect ratio faces Writing collapsed mesh to time 0.05 End when I run the checkMesh on the new grid with the collapsed edges I get the following output Mesh stats points: 2121 internal points: 0 faces: 4010 internal faces: 1890 cells: 1000 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 900 prisms: 100 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology frontAndBackPlane 0 0 ok (empty) InOutlet 20 42 ok (non-closed singly connected) center 0 0 ok (empty) pipe_wall 100 202 ok (non-closed singly connected) frontAndBackPlane_pos1000 1111 ok (non-closed singly connected) frontAndBackPlane_neg1000 1111 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 0 4.03063173324e-05) (5 0.5 0.0436596936827) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 1) ***Number of edges not aligned with or perpendicular to non-empty directions: 2020 <<Writing 2121 points on non-aligned edges to set nonAlignedEdges Boundary openness (5.05184045313e-19 -8.16550549354e-16 -5.37567505446e-16) OK. Max cell openness = 1.65706464942e-16 OK. Max aspect ratio = 22.9255856257 OK. Minumum face area = 0.000109048468415. Maximum face area = 0.00250237718349. Face area magnitudes OK. Min volume = 5.45242342075e-06. Max volume = 0.000103596044993. Total volume = 0.0545242342067. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.330801283002 OK. Failed 1 mesh checks. so somehow it seems that the collapseEdges didnt work properly with my options on my case. Or is this another problem?! Any ideas? cheers, Florian |
1 Attachment(s)
Hi Bernhard,
I did a checkMesh on the grid and here is the output Mesh stats points: 2222 internal points: 0 faces: 4110 internal faces: 1890 cells: 1000 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 1000 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology frontAndBackPlane 0 0 ok (empty) InOutlet 20 44 ok (non-closed singly connected) center 100 202 ok (non-closed singly connected) pipe_wall 100 202 ok (non-closed singly connected) frontAndBackPlane_pos1000 1111 ok (non-closed singly connected) frontAndBackPlane_neg1000 1111 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 0 4.03063173324e-05) (5 0.5 0.0436596936827) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 1) ***Number of edges not aligned with or perpendicular to non-empty directions: 2020 <<Writing 2222 points on non-aligned edges to set nonAlignedEdges Boundary openness (5.07768106926e-19 -8.16550549354e-16 -5.37567505446e-16) OK. Max cell openness = 1.65706464942e-16 OK. Max aspect ratio = 22.9255856257 OK. ***Zero or negative face area detected. Minimum area: 0 <<Writing 100 zero area faces to set zeroAreaFaces Min volume = 7.47743760209e-06. Max volume = 0.000103596044993. Total volume = 0.0561517870683. Cell volumes OK. Mesh non-orthogonality Max: 76.4964690725 average: 12.7337115278 *Number of severely non-orthogonal faces: 32. Non-orthogonality check OK. <<Writing 32 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 83 faces are incorrectly oriented. <<Writing 83 faces with incorrect orientation to set wrongOrientedFaces ***Max skewness = 7.40663060245, 84 highly skew faces detected which may impair the quality of the results <<Writing 84 skew faces to set skewFaces Failed 4 mesh checks. I am not sure about the first error message, for the second I guess its just collapsed faces from the axis patch, the third one I am again not sure about it, and the last one i guess is just that i have needle-like volumes. so I guess I have to use collapseEdges, just with the proper option settings.... I attached the original polyMesh directory after I converted from fluent .cas to OF format. If you would have a minute to have a look at it, would be really nice and helpful,.... maybe there is something wrong with the original grid :confused: thanks and best, Florian |
