Home > Forums > OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ...
FluentMeshToFoam no set written
Old   May 24, 2007, 18:14
Default Hi, When I do fluentMeshToF
Kian Mehravaran
kian is on a distinguished road
When I do
fluentMeshToFoam . cyl cylin.msh
I get this message at the end:
Default patch type set to empty
Checking mesh
Writing mesh
Only one cell group: no set written
End
where cylin.msh is a 2-D mesh, exported from Gambit for Fluent 5/6, and cyl is the icoFoam cavity case copied under a new directory.
I have tried a simple 3-D block as well, with no avail.
On the other hand, I've been able to do foamMeshToFluent successfully. However, the resulting .msh file is only recognized in Fluent and cannot be imported to Gambit. Please note that I don't want to export Foam mesh to Gambit, I only mentioned this, since it could help to find a remedy to the first issue.
I have searched the forums and haven't been able to locate an answer. Any advice is appreciated.
Kian
kian is offline   Reply With Quote
Old   May 25, 2007, 07:16
Default Hi Kian! Your mesh has been
Assistant Moderator
Bernhard Gschaider
Hi Kian!
Your mesh has been written, so you can use it. "Only one cell group: no set written " means that in Gambit you 'only' defined one fluid zone and therefor no additional information was written. (You only need the additonal fluid zones for special applications)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   May 25, 2007, 12:04
Default Hello Bernhard, Thank you for
Kian Mehravaran
Hello Bernhard,
Thank you for your reply. I was so convinced that there is no output! I am happy now
Vielen dank und schönes Wochenende
Thread Tools
Trackbacks are On
What information in written in phi henning OpenFOAM Running, Solving & CFD 1 October 9, 2008 14:03
I need a paper which is written by pantankar sv myyouth FLUENT 0 May 29, 2006 01:14
F(1) over-written error Olof Liungman Phoenics 5 October 27, 2005 13:52
Dictionaries written by FoamX Mattijs Janssens (Mattijs) OpenFOAM Pre-Processing 1 January 3, 2005 14:44
to kill a job with files written Ossi CD-adapco 3 November 29, 2002 06:19
