[CGNS] Computing a cellcentered scalarField from a vertexcentered scalarField |
August 30, 2005, 09:30 |
Martin Beaudoin
Rep Power: 22 |
I am in the process on finalizing a CGNS to OpenFoam converter. So far, I was able to convert structured and unstructured meshes, including the Boundary Conditions, from the CGNS file format to OpenFoam. I am also able to convert a CGNS vertex-centered scalar field as an OpenFoam pointScalarField, save it on disk and visualize the scalar field using paraFoam. So far so good, OpenFoam is really a great package, very well written. Now, I need to compute a cell-centered scalarField (volScalarField) from the vertex-centered scalar field stored in a pointScalarField, and quite frankly, I am stuck... Basically, I need to interpolate the pointScalarField at the cell centres, but I am not really sure which OpenFoam API is better suited for doing this. A quick pointer would really be appreciated. Regards, Martin |
August 30, 2005, 10:02 |
Hmm, we haven't got one of tho
Hrvoje Jasak
Rep Power: 33 |
Hmm, we haven't got one of those at the moment. I suspect what you are after is something like the volPointInterpolation class:
src/OpenFOAM/interpolations/volPointInterpolation/volPointInterpolation.H but going in the oppisite direction. If you feel adventurous, you could have a go at writing one yourself and I'm prepared to give you a hand. Incidentally, is there a good way of doing point-to-cell interpolation or do you just want inverse distance weighting - there may be issues with conservation. Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
August 30, 2005, 13:50 |
Thanks Hrvoje,
Right now,
Martin Beaudoin
Rep Power: 22 |
Thanks Hrvoje,
Right now, I would settle for a simple inverse distance weighting interpolation. Since this feature is not available right now, I will give it a shot myself, and try to come up with something similar to volPointInterpolation. I will keep you posted. As a matter of fact, it would be very easy to use the VTK interpolation algorithms for such a task... I have already written some interpolation stuff using the VTK API... Pretty straightforward once you are familiar with the VTK data model.. Have you ever considered using the VTK libraries with OpenFoam for something other than visualization? Thanks again for your help! Martin |
August 31, 2005, 11:29 |
Hi Martin,
I have done the
Hrvoje Jasak
Rep Power: 33 |
Hi Martin,
I have done the pointVolInterpolation class you wanted - please send me an E-mail and I'll pass it over. It's quite fun actually, much easier than the other way around because you don't need to worry about the boundary corrections :-) Hrv
September 6, 2005, 06:08 |
Martin Beaudoin, Would it be p
Håkan Nilsson
Rep Power: 18 |
Martin Beaudoin, Would it be possible to take part of your CGNStoFoam converter? I have a grid with boundary conditions in CGNS format and would just like to convert it to OpenFoam. I don't need any more functionality right now.
January 16, 2006, 10:55 |
Hallo Martin,
could you mak
Oliver Borm
Rep Power: 17 |
Hallo Martin,
could you make the cgnsToFoam utility available for the public? Thanks Oliver |
May 29, 2006, 17:12 |
Hello Martin,
I am just get
Daniel Einstein
Rep Power: 17 |
Hello Martin,
I am just getting started with OpenFOAM and wondered what progress you made with your CGNS--> FOAM converter and whether it was publically available? Regards, Dan |
June 5, 2006, 12:43 |
Hello Daniel,
I am currentl
Martin Beaudoin
Rep Power: 22 |
Hello Daniel,
I am currently in the process of testing a new C++ wrapper over the latest CGNS standard MLL library. That wrapper was developed by a colleague of mine. I still need to integrate this new code to the two converters we have developed, cgnsToFOAM and foamToCGNS. I have the go ahead to release the code publicly for both converters, so it is basically just a matter of integrating the new code, testing and cleaning up the source code a little bit (lots of french comments.. ) , and of course, writing a quick doc. As soon as I can release the source code, I will probably publish it somewhere on the Wiki, and post a message here. So watch this space... Martin |
June 14, 2006, 11:02 |
Hello Hrvoje,
I can see tha
#9 |
anne dejoan
Rep Power: 17 |
Hello Hrvoje,
I can see that you wrote a pointVolInterpolation class tool. I would be interested to get it, if possible, so that I could read a turbulent point field issued from another code and run it with OpenFoam. Please, let me know if it is possible, Thanks You, Anne |
June 14, 2006, 12:12 |
Just E-mailed: enjoy.
Hrv
#10 |
Hrvoje Jasak
Rep Power: 33 |
Hrv
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
CFD algorithm design with reconfigurable computing | Beatríz Navarro | CFX | 4 | June 27, 2006 04:39 |
CFD algorithm design with reconfigurable computing | Beatríz Navarro | Main CFD Forum | 1 | June 25, 2006 14:25 |
CFD algorithm design with reconfigurable computing | Beatríz Navarro | Fidelity CFD | 0 | June 24, 2006 18:23 |
CFD algorithm design with reconfigurable computing | Beatríz Navarro | FLUENT | 0 | June 24, 2006 18:22 |
