Hello dear FOAM users.
I am
I am a beginner at foam (but i have some experience with fluent etc.) and I have a few questions. 1. Is there anyway I can convert my .msh file which includes an interface? I have read that it is not possible but I cant be the only one with this problem so I figured maybe there is a solution anyway? 2. What solver should I use? I have lowspeed turbulent flow past a blunt body, so my guess is simpleFoam? 3. What boundary conditions should i use if I in fluent used[inside brackets is my guess]: velocity inlet[inlet] pressure farfiel[outlet] wall (for the blunt body) [wall] top and bottow boundary wall [moving wall with the same speed as inlet] ? Thank you very much /ham |
Hello Marcus!
@1:
If your
Hello Marcus!
@1: If your "interface" (Gambit nomenclature) is one patch which "looks" at both sides simply change it's type in Gambit to "interior" and write the .msh. fluentMeshToFoam can then handle it (see discussion elsewhere). Depending on what you want to do with the interface you'll have to manipulate (splitMesh etc) the mesh. If it's two patches that happen to be in the same place, each "seeing" only one side (and the meshes on the patches possibly non-conforming) then you can change the mesh type to "wall", convert the .msh. From then on it depends on what you want to do with that mesh. PS: If you don't have a Gambit handy you can change the types of boundaries in the msh-file with a text editor http://www.cfd-online.com/OpenFOAM_D...part/happy.gif (I've done that, but never for interfaces) |
Hello Berhard,
I take advan
Hello Berhard,
I take advantage of this new topic on fluent mesh convertors to ask you if you could help me in the following: I want to convert a .msh file into a foam. while doing it the fluentMeshTofoam does not recognize the patch "periodic" in the .msh. So, I declared it differently and convert the file. The I modified the "boundary" file in the polymesh directory and declared them as cyclic. However when running it (with icoFoam) I have the error: -> FOAM FATAL ERROR : face 0 and 216 areas do not match by 3.49993% -- possible face ordering problem From function cyclicFvPatch::makeWeights(scalarField& w) const in file fvMesh/fvPatches/derivedFvPatches/cyclicFvPatch/cyclicFvPatch.C at line 58. So I used after this couplPatch but it didn't write any new polymesh directory. Well, perhaps you can help ? Thanks you Anne |
Thank you
I will try this.
Thank you
I will try this. /Marcus |
Hi Anne!
3.49% seems to be
Hi Anne!
3.49% seems to be an awful lot. I can't be bothered to look at the sources now, but if I remember it corrrectly cyclic boundary conditiions in OF assume, that the boundaries are either translatory related or that they share a rotation axis that goes through (0,0,0). But I may be wrong. The interesting thing is: What did coupleMesh say (I assume it didn't say "Writing morphed mesh to time ....") |
Hi Bernhard,
First, thanks
Hi Bernhard,
First, thanks to help me ! Here is the following message returned by couplPatch ---------------- Mesh has coupled patches . Doing dummy mesh morph to correct face ordering ... --> FOAM Serious Error : From function cyclicPolyPatch::geometricOrder in file meshes/polyMesh/polyPatches/derivedPolyPatches/cyclicPolyPatch/cyclicPolyPatch.C at line 541 patch:inlet : Patch inlet gets decomposed in two zones ofinequal size: 432 and 0 This means that the patch is either not two separate regions or one region where the angle between the different regions is not sufficiently sharp. Please use topological matching or adapt the featureCos() setting Continuing with incorrect face ordering from now on! --> FOAM Serious Error : From function cyclicPolyPatch::geometricOrder in file meshes/polyMesh/polyPatches/derivedPolyPatches/cyclicPolyPatch/cyclicPolyPatch.C at line 541 patch:outlet : Patch outlet gets decomposed in two zones ofinequal size: 432 and 0 This means that the patch is either not two separate regions or one region where the angle between the different regions is not sufficiently sharp. Please use topological matching or adapt the featureCos() setting Continuing with incorrect face ordering from now on! Mesh ordering ok. Nothing changed. End ------------------------------------- So couplePatch, indeed, does not write anything. However, I have checked with fluent that the two periodic conditions were superimposed (in the first tests they were not). The problem is also that the "periodic" declaration from the .msh file is not recognised by fluenToMeshFoam so that I modify it to another type BC and apply the fluentToMesh converter and thus have the problem of 3.9% etc .. Thanks, Anne |
Hi Anne!
I assume that the
Hi Anne!
I assume that the inlet and the outlet patch are to be coupled. Let's open the UserGuide at Page U-141 and look at the definition of the cyclic patch there. What it says in essence is that the coupled patches are topologically separate, but have to be in one "logical Patch" (see figure 6.4 for further enlightenment). So what you do is use the createPatch utility to create a new patch named goingRound from the patches inlet and outlet (their sizes become zero during that operation). The patch goingRound is then defined as cyclic. |
Hello again,
I need a littl
Hello again,
I need a little help on how to use createpatchDict file. I have copied one in my system directory but I am confused on how to declare correctely the patches I want to couple. The creatPatchDict looks like: ------------------------------------------- patches ( { // Name of new patch name leftRight0; // Type of new patch type cyclic; // How to construct: either 'patches' or 'set' constructFrom patches; // If constructFrom = patches : names of patches patches (half0 half1); // If constructFrom = set : name of faceSet set f0; } { name bottom; type patch; constructFrom set; patches (half0 half1); set bottomFaces; } ); ---------------------------- The patches I want to couple are named: inlet and outlet, suppose I call getround the new patch, what I did is: replace leftright0 by getrond replace half0 by inlet replace half1 by outlet But it is not the way to do it in view of my message erro. Thanks again, Anne |
HI Bernhard,
I have finally
HI Bernhard,
I have finally succeeded in applying createPatch but I am not sure it is the good way because I still have an error when running an application olver on my geometry. First: I commented in createPatch Dict all the lines related to "set" so that it looks like: ---------------------- patches ( { // Name of new patch name leftRight0; // Type of new patch type cyclic; // How to construct: either 'patches' or 'set' constructFrom patches; // If constructFrom = patches : names of patches patches (inlet outlet); // If constructFrom = set : name of faceSet // set f0; } // { // name bottom; // type patch; // constructFrom set; // patches (half0 half1); // set bottomFaces; // } ); -------------------------------------- so it creates me a new polymesh directory but when I run the application icoFoam on my case I still have the error message: ------------------------ --> FOAM FATAL ERROR : face 0 and 216 areas do not match by 3.49993% -- possible face ordering problem From function cyclicFvPatch::makeWeights(scalarField& w) const in file fvMesh/fvPatches/derivedFvPatches/cyclicFvPatch/cyclicFvPatch.C at l ine 58. FOAM aborting Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) Foam::error::abort() Foam::cyclicFvPatch::makeWeights(Foam::Field<doubl e>&) const Foam::surfaceInterpolation::makeWeights() const Foam::surfaceInterpolation::weights() const Foam::fvMesh::constructAndClear() const Foam::regIOobject::write(Foam::IOstream::streamFor mat, Foam::IOstream::versionNu mber, Foam::IOstream::compressionType) const __libc_start_main __gxx_personality_v0 Aborted ------------------------------------------- Is there abything to do with the comments I have done ? when keeping the "set" related lines, I couldn't run createaPatch. I don know if you can help me ... anyway, thanks Anne |
Using splitMesh
what is:
fac
Using splitMesh
what is: faceSet? is it the name/numbering of the faces where the split is beeing made? what is master and slavePatch? A partial printout of the .msh file(where interface1 and interface2 are the faces where the split should be: (0 "Zones:") (45 (2 fluid fluid)()) (45 (3 wall plate)()) (45 (4 wall lowerwall)()) (45 (5 wall upperwall)()) (45 (6 pressure-outlet pressure.outlet.5)()) (45 (7 vel-inlet velocity.inlet.4)()) (45 (8 interior interface2)()) (45 (9 interior interface1)()) (45 (11 interior default-interior)()) Thank you! /Marcus |
Hi Anne.
Problem could be,
Hi Anne.
Problem could be, that when you use createMesh it takes the mesh from constant (which implicitly is time 0) but writes the modified mesh to 0+dt (dt from the controlDict), for instance the directory 0.005 (there should be a polyMesh-directory in there). When you start the solver he usually (depends on the controlDict) reads the mesh from time 0 (which he finds in constant) and ignores the new mesh in 0.005. Have you moved the 0.005/polyMesh-directory to constant and then removed the 0.005-directory? |
Hi Marcus!
For OpenFOAM a f
Hi Marcus!
For OpenFOAM a faceSet is a set of faces ;) They have no special meaning and are used for "adminstrative" purposes The fluentMeshToFoam-converter creates a faceSet for every interior-boundary he finds (in your case there should be a subdirectory sets in the polyMesh directory with two files interface1 and interface2 in them). master- and slavePatch are needed for sliding meshes. If you don't do that it is sufficient to think of them as "patch on one side of the interface" and "patch on the other side of the interface" |
Hi!
Thanks, now I understan
Hi!
Thanks, now I understand. But the problem is that fluentMeshToFoam doesnot work due to an error, which I thought was the reason I needed splitMesh in the first place. (did that make sense?) Maybe I had this all wrong then. So I should first successfully convert the .msh, then I should run splitMesh? Thanks for teaching a rookiehttp://www.cfd-online.com/OpenFOAM_D...part/happy.gif /Marcus |
Hi Marcus!
First converter,
Hi Marcus!
First converter, then split mesh: Yep. SplitMesh needs an OpenFOAM-native mesh which only the converter can provide. What was the error message of the converter? |
Good morning.
The error was
Good morning.
The error was: dimension of grid: 2 Grid is 2-D. Extruding in z-direction by: 67.8823 Creating shapes for 2-D cells Creating patch for zone: 3 start: 1 end: 100 type: wall name: plate Creating patch for zone: 4 start: 101 end: 140 type: wall name: new_upperwall Creating patch for zone: 5 start: 141 end: 180 type: wall name: upperwall Creating patch for zone: 6 start: 181 end: 220 type: pressure-outlet name: pressure_outlet.5 Creating patch for zone: 7 start: 221 end: 260 type: velocity-inlet name: velocity_inlet.4 Creating patch for zone: 8 start: 261 end: 938 type: interior name: interface2 Patch 8 contains solid or internal faces. Not added to boundary Adding to internal boundaries Creating patch for zone: 9 start: 939 end: 1204 type: interior name: interface1 Patch 9 contains solid or internal faces. Not added to boundary Adding to internal boundaries Creating patch for zone: 11 start: 1205 end: 77551 type: interior name: default-interior Patch 11 contains solid or internal faces. Not added to boundary Not adding to internal boundaries Creating patch for front and back planes Default patch type set to empty --> FOAM FATAL ERROR : Trying to specify a boundary face 4(16 30 35302 35288) on the face on cell 11659 which is either an internal face or already belongs to some other patch. This is face 0 of patch 0 named plate. From function polyMesh::polyMesh ( const IOobject& io, const pointField& points, const cellShapeList& cellsAsShapes, const faceListList& boundaryFaces, const wordList& boundaryPatchTypes, const wordList& boundaryPatchNames, const word& defaultBoundaryPatchType ) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 481. FOAM aborting Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) Foam::error::abort() Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Field<foam::vector<double> > const&, Foam::List<foam::cellshape> const&, Foam::List<foam::list<foam::face> > const&, Foam::List<foam::word> const&, Foam::List<foam::word> const&, Foam::word const&, Foam::List<foam::word> const&) fluentMeshToFoam [0x8057b3b] __libc_start_main __gxx_personality_v0 Aborted I believe Ive seen similar error somewhere here. Checking it out... thanx |
This message says you have man
This message says you have managed to specify 2 boundary conditions on the same face. This is an error and it should be fixed: a face can belong to only one patch.
If you cannot fix it in any other way, read the mesh into Fluent and write it aout again (ascii!) - Fluent will quietly fix the error for you. I suspect you've built the mesh using Gambit, right? As usual, nothing wrong with the Fluent mesh converter... Hrv |
Okey,
Yes, I built the mesh u
Okey,
Yes, I built the mesh using Gambit. The mesh has(should have) two boundaries on two different, but infinitely close to each other, faces. (I did this on purpose for some grid-intensity reasons which maybe isnt important) Anyway, I will try to fix it following your recommendations. Thanks |
Hmm, I dont know what to do no
Hmm, I dont know what to do now. Have tried a few things without success.
What I normally would do is to redo the mesh some other way that hopefully would not generate this error. But since I am doing this to learn rather than doing it to get some results I will not give up yet. Is there anyone who can have a closer look on my mesh? I send it by email(3300kB). I would be so greatful. /Marcus |
OK, send it over here, I will
OK, send it over here, I will convert it for you (just to prove the point) - you can get my E-mail address from the signature.
Hrv |
| All times are GMT -4. The time now is 19:00. |
