Home > Forums > OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ...
Importing a hex core mesh from Gambit
Old   September 15, 2006, 03:54
Default Hi! Is there any posibility to
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hi! Is there any posibility to import a mesh generated with Gambit with "hex core"? There are some discussions about hanging nodes, and the conclusion as I red was that OpenFOAM should be able to handle such grids.
Attached, there is a small mesh as a nonworking example. If I try to import it, I get the following:
dragosm@lap08:~/OpenFOAM/dragosm-1.3/run/hangingNodes> fluentMeshToFoam ./ case hangingNodes.msh
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.3 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : fluentMeshToFoam ./ case hangingNodes.msh
Date : Sep 15 2006
Time : 10:58:27
Host : lap08
PID : 8660
Root : /fsd/soft/OpenFOAM/dragosm-1.3/run/hangingNodes/
Case : case
Nprocs : 1
Create time
Dimension of grid: 3
Number of points: 2677
Reading points
number of faces: 21024
Reading mixed faces
Reading mixed faces
Reading uniform faces
Found unknown block
Embedded blocks in comment or unknown
Found end of section in unknown
Number of cells: 9282
Reading mixed cells
Reading zone data
Reading zone data
Reading zone data
FINISHED LEXING
dimension of grid: 3
Creating shapes for 3-D cells
--> FOAM FATAL ERROR : Cannot find match for face 1.
Model: hex model face: 4(0 1 5 4) Mesh faces:
6
4(2552 2554 2558 2556)
4(2554 1463 1465 2558)
4(2556 2558 1465 1464)
3(1464 1462 2556)
3(2552 2556 1462)
3(2552 1462 2554)
Matched points: 8(2552 -1 -1 2556 2554 -1 -1 2558)
From function create3DCellShape(const label cellIndex, const labelList& faceLabels, const labelListList& faces, const labelList& owner, const labelList& neighbour, const label fluentCellModelID)
in file create3DCellShape.C at line 281.
FOAM aborting
Foam::error::printStack(Foam:stream&)
Foam::error::abort()
fluentMeshToFoam [0x409570]
fluentMeshToFoam [0x40e6a9]
__libc_start_main
__gxx_personality_v0
Aborted
Any chance to get the mesh in OpenFOAM?
Dragos
dmoroian is offline   Reply With Quote
Thread Tools
Trackbacks are On
problem importing mesh to gambit richard FLUENT 0 January 6, 2009 01:58
Importing Mesh file to Gambit Sri FLUENT 0 February 28, 2007 11:26
Importing a hex core mesh from Gambit dmoroian OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 6 September 18, 2006 02:45
gambit mesh generation for core annular flow anand FLUENT 0 November 17, 2005 03:33
Importing Patran mesh into Gambit Trac FLUENT 1 September 29, 2005 10:32
