[Gmsh] Modified gmshToFoam to help import hexahedral and prism elements from Gmsh
Old   April 18, 2005, 08:15
Default Modified gmshToFoam to help import hexahedral and prism elements from Gmsh
Ervin Adorean
adorean is on a distinguished road
Hi all,
I had trouble importing a 3D mesh with hexahedra and prism elements from Gmsh to OpenFOAM, so Mattijs Janssens made some modifications to gmshToFoam.C and it worked.
You can run the gmshToFoam command with the following syntax:
gmshToFoam <root> <case> filename.msh -invertPrism -invertHex
Just replace the old gmshToFoam.C file in /home/user/openFOAM/OpenFOAM-1.1/applications/utilities/mesh/conversion/gmshToFo am directory with \attach {this}
The easiest way to compile it is by running the ./Allwmake command from the /home/user/openFOAM/OpenFOAM-1.1/applications/utilities/mesh/conversion directory.
Ervin
adorean is offline   Reply With Quote
Old   April 18, 2005, 08:19
Default Sorry, the modified gmshToFoam
Ervin Adorean
Sorry, the modified gmshToFoam.C file is gmshToFoam.C
Inquiry - Prism Layer / Hexahedral Mesh (TRIMMER) miragemobile STAR-CCM+ 2 February 28, 2019 10:04
[ICEM] Mesh a pie geometry with hexahedral and prism elements mgu ANSYS Meshing & Geometry 0 January 24, 2012 13:06
