Home > Forums > OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ...
Harpoon to Foam
Old   March 9, 2005, 14:12
Default Hi, Mattijs, Will netgenNeu
  #21
Pei-Ying Hsieh
hsieh is on a distinguished road
Hi, Mattijs,
Will netgenNeutralToFoam converter be included in OpenFOAM 1.1? When will OpenFOAM 1.1 be available? I tried to download netgenNeutralToFoam converter that you posted on this tread, but, no luck.
Regards,
Pei
hsieh is offline   Reply With Quote
Old   March 9, 2005, 16:40
Default Hi Pei, maybe you could not
  #22
Manuel Garcia
garcia is on a distinguished road
Hi Pei,
maybe you could not downloaded it because the extension of the file is .unk but save that file and decompress it the usual way
tar -xzvf netgenNeutralToFoam-236.unk
manuel
garcia is offline   Reply With Quote
Old   April 11, 2005, 05:17
Default Hi Joern You are wrong abou
  #23
Richard Bardwell
sharc is on a distinguished road
Hi Joern
You are wrong about the suitability of Harpoon for serious CFD calculations. Almost all automotive companies around the world use Harpoon along with a large number of F1 teams in the motorsport arena. If you consider these types of flow calculations unimportant let me know !!
We already have formats exporting with hanging nodes, so if someone can point us in the direction of the OpenFoam mesh format, we can quickly add this file format to Harpoon.
Richard
sharc is offline   Reply With Quote
Old   April 11, 2005, 05:29
Default You can find on-line documenta
  #24
henry is on a distinguished road
You can find on-line documentation for the OpenFOAM mesh format on web-site:
http://www.opencfd.co.uk/openfoam/do...#x30-1480006.1
and also in PDF format from the web-site:
http://www.opencfd.co.uk/openfoam/doc/index.html
and this users-guide is also included in the releases in the doc directory. There are also many examples in the form of tutorials included in the releases for you to study.
henry is offline   Reply With Quote
Old   April 11, 2005, 06:18
Default Hi Richard, I used the term
  #25
Joern Beilke
JBeilke is on a distinguished road
Hi Richard,
I used the term "serious scientific work" and this is not the same as doing serious, important and urgent engineering work, at least for me ;-)
Jörn
JBeilke is offline   Reply With Quote
Old   April 11, 2005, 06:33
Default Hi Richard, As you know, an
  #26
Hrvoje Jasak
Hi Richard,
As you know, any new meshing interface for Foam would be a very welcome development. I have written the Foam mesh classes and most converters - please give me a shout if I can be of assistance.
Regards,
Hrv
Hrvoje Jasak
Old   May 12, 2005, 04:53
Default Has anyone managed to get a Ha
  #27
Mattijs Janssens
mattijs is on a distinguished road
Has anyone managed to get a Harpoon mesh into OpenFOAM? I am a bit stuck with a mesh with embedded refinement:
- the Star files are written in binary which the converter cannot read
- the Fluent ,,
- the Gambit file uses cellshapes so cannot represent embedded refinement.
mattijs is offline   Reply With Quote
Old   May 12, 2005, 06:38
Default What if you read the files int
  #28
Joern Beilke
What if you read the files into star and then export them again. You also might contact Richard Bardwell and ask him if he has already implemented the native FOAM support in Harpoon.
If the mesh is not too big I might do the conversion for you.
Old   May 12, 2005, 06:51
Default Hi Joern, tried this (read
  #29
Mattijs Janssens
Hi Joern,
tried this (read them into Star, export them as .ccm and run ccmToFoam)
So what are the exact commands you use in Prostar/OpenFOAM?
Old   May 12, 2005, 08:30
Default You can not export the ccm for
  #30
Joern Beilke
You can not export the ccm format from prostar. If you want to get the ccm format you have to export the .ngeom file from prostar (command "ngeom"), read this into ccm+ and export the .ccm file from there.
I would simply read the files into prostar (ifile "file.inp") and follow the procedure described in the manual.
At wich point do you have problems? I never tried to do it myself (from Harpoon to FOAM) but it should work.
Old   May 12, 2005, 09:21
Default Hi Joern, thanks. The probl
  #31
Mattijs Janssens
Hi Joern,
thanks. The problem is that I do not have Prostar or CCM or Harpoon myself so the 'loop' is rather long. I'll see if we can do your export trick.
Can Harpoon export in Star ascii format?
Old   May 13, 2005, 03:24
Default Hi Mattijs Would an ascii v
  #32
Richard Bardwell
Hi Mattijs
Would an ascii version of the Star format help get to OpenFoam? Would the translator be able to read the couples?
Most of the formats in Harpoon have their ascii equivalent but we do not export them just for speed and space on the disk issues
Old   May 13, 2005, 03:41
Default Maybe. The files have to confo
  #33
Mattijs Janssens
Maybe. The files have to conform to the section in the User Guide (6.4.2), exporting from Prostar (so be compact, have no shells in them and a few other conditions).
Old   March 7, 2006, 10:43
Default Are there any experience to im
  #34
chris book
chris1980 is on a distinguished road
Are there any experience to import Harpoon meshes? Does it work (well)?
I am looking for a good mesher which can deal with OpenFoam.
There are lot of problems with the different mesh converts so what prefered mesh format (star,gambit ...) for Foam?
chris1980 is offline   Reply With Quote
Old   March 7, 2006, 12:06
Default Hi, Chris, When I contacted
  #35
Pei-Ying Hsieh
Hi, Chris,
When I contacted a Harpoon sales rep few months ago, they were working on direct OpenFOAM export from Harpoon (no conversion required). Hopefully, it will be released soon. I am looking forward to testing it myself.
Pei
Old   March 8, 2006, 04:38
Default Hi guys, I think the Harpoo
  #36
Mattijs Janssens
Hi guys,
I think the Harpoon guys need some more pushing. I haven't seen any OpenFOAM export in the last release and haven't heard from them for a few months as well.
Old   March 8, 2006, 08:07
Default I agree with Mattijs, this
  #37
stefan
stefanke is on a distinguished road
this is the information I get yesterday from Richard Bardwell:
We have done some work on an export to OpenFOAM. We can only justify
completeing the export if we receive an order from someone who wants it
As yet we have not received such an order
If you buy Harpoon, we will put it in
-> I am sure that a lof of people use Harpoon already so push them to support OpenFoam!
I think the more people are asking for Foam support the more Sharc will implement this feature!
stefanke is offline   Reply With Quote
Old   March 8, 2006, 08:51
Default Hi, For me, I use interFOAM
  #38
Pei-Ying Hsieh
For me, I use interFOAM most of the time, which requires good quality Hex elements. It is not clear to me how good harpoon is without testing it first.
Will it be easier if the Harpoon people add the fluent/CFX/Star-CD ascii export (it only has binary export now and OpenFOAM cannot read it), then, it can be converted to OpenFOAM from fluent/gambit format?
Old   March 8, 2006, 18:33
Default I think that Richard wanted to
  #39
Joern Beilke
I think that Richard wanted to add the ASCII export of the StarCD format some time ago. This should work fine for OpenFOAM.
Old   March 9, 2006, 04:08
Default I thought the Star/Fluent ASCI
  #40
Richard Bardwell
I thought the Star/Fluent ASCII exports would not have the hanging faces maintained when converted to OpenFOAM. Can someone verify this?
Thread Tools
Trackbacks are On
Did you try Harpoon? HSeldon Main CFD Forum 3 November 27, 2006 05:50
Harpoon CFD-Junior Main CFD Forum 0 June 23, 2005 07:40
Harpoon/CFX5 Oko CFX 8 May 19, 2005 18:53
Harpoon CFD-junior Main CFD Forum 0 May 4, 2005 09:21
