Home > Forums > OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ...
Harpoon to Foam
Old   March 9, 2006, 08:32
Default Well, I have written the code
  #41
Hrvoje Jasak
Well, I have written the code which reads the Star couples and creates the proper cells. This is a part of the starToFoam converter and everything should just work.
If you really want to do us a favour, you can dump the faces raw because I'm sure Harpoon needs to mess about with the native format to create Star couples in the first place. The easies mesh format I can imagine would be:
1) list of vertices
2) list of faces in terms of vertices; I don't care if they are polygons
3) there's options, whichever is easier for you:
- list of cells in terms of faces, i.e. all faces that belong to a cell, or
- "left" and "right" cell for each faces (for boundary ones, only one is required).
If you can provide this info, I cna take it from there.
Regards,
Hrv
Hrvoje Jasak
Old   March 21, 2006, 08:49
Default The Fluent export would be the
  #42
Richard Bardwell
sharc is on a distinguished road
The Fluent export would be the most useful.
It is probably quicker to finish off the FOAM export I started. Can I send you some files to test? If so, what email address should I use?
sharc is offline   Reply With Quote
Old   March 21, 2006, 08:54
Default No probs - if needed, I will a
  #43
Hrvoje Jasak
No probs - if needed, I will add the stuff into the Fluent export as well. The best E-mail is h dot jasak at wikki dot co dot uk.
Thanks,
Hrv
Hrvoje Jasak
Old   March 23, 2006, 11:12
Default Thanks to Hrvoje checking our
  #44
Richard Bardwell
Thanks to Hrvoje checking our meshes, the next release of Harpoon will have a OpenFoam direct export. This will be available in the next couple of weeks to download from www.sharc.co.uk
Old   March 28, 2006, 07:49
Default Hi, Richard, Could you ple
  #45
Pei-Ying Hsieh
hsieh is on a distinguished road
Hi, Richard,
Could you please post here when the new release of Harpoon with OpenFOAM export is available? I am interested in trying it. Thanks!
Pei
hsieh is offline   Reply With Quote
Old   March 30, 2006, 02:40
Default Pei Will do. I have run som
  #46
Richard Bardwell
Pei
Will do. I have run some tests on it and it looks ok but would need more testing. Version will not be ready until end of next week at the earliest
Richard
Old   April 12, 2006, 03:49
Default All Version v2.0(e) is now
  #47
Richard Bardwell
All
Version v2.0(e) is now available for download. Run with the command line option -foam to allow OpenFoam export
Richard
Old   April 13, 2006, 16:08
Default Hi, Richard, Can you explai
  #48
Pei-Ying Hsieh
Hi, Richard,
Can you explain how to export OpenFOAM using command line option? I am using Windows version and I cannot find a window for entering commands.
Thanks!
Pei
Old   April 13, 2006, 18:10
Default Just start the executable: "ha
  #49
stefan
stefanke is on a distinguished road
Just start the executable: "harpoon -foam"
stefanke is offline   Reply With Quote
Old   April 20, 2006, 21:47
Default Hi, Richard, I encountered
  #50
Pei-Ying Hsieh
Hi, Richard,
I encountered a couple of problems when trying out Harpoon. The most serious one is that, after exporting the mesh to OpenFOAM format, these files (boundary/cells/points/faces) are not usable. When I tried to open the files, I got "this file is binary...". This occurred to both the 32 bit windows version and the 64 bit Linux version.
I am wondering how this can be resolved.
Pei
Old   April 21, 2006, 03:20
Default Harpoon is not ready for OpenF
  #51
stefan
Harpoon is not ready for OpenFoam 1.3. But with OpenFoam 1.2 it should work!
Old   April 21, 2006, 05:58
Default Whats wrong with binary files?
  #52
Eugene de Villiers
eugene is on a distinguished road
Whats wrong with binary files? What does checkMesh say?
The OF 1.3 mesh constructors are backward compatible with 1.2 formats so there should be no issue.
eugene is offline   Reply With Quote
Old   April 21, 2006, 06:08
Default I have tested the new Harpoon
  #53
stefan
I have tested the new Harpoon release and there was always the same problem with OF 1.3 (same failure as described above). With OF 1.2 all works fine.
So it has definitly something to do with the version of OF and/or the way how the meshes are created in Harpoon so OF is able to read them.
Old   April 21, 2006, 10:42
Default Could you mail me a small exam
  #54
Eugene de Villiers
Could you mail me a small example mesh from harpoon please?
Old   May 17, 2006, 08:27
Default I have found out why the harpo
  #55
Eugene de Villiers
I have found out why the harpoon exported mesh does not work under OF1.3.
The boundary file has been written in DOS format and the handling of the DOS characters have changed between 1.2 and 1.3.
To fix the problem execute the following command:
dos2unix -n[list=1] <newboundaryfile>
This works on the test case I received. Could someone please confirm the fix.
Old   June 19, 2006, 08:12
Default The problem is probably that y
  #56
Richard Bardwell
The problem is probably that you are using the single precision version. Harpoon exports the data in double precision
Old   June 19, 2006, 08:20
Default Use the ASCII export. Should b
  #57
Richard Bardwell
Use the ASCII export. Should be fine
Old   June 19, 2006, 09:03
Default the harpoon export works fine
  #58
stefan
the harpoon export works fine with OF1.2 and OF1.3 but as Eugene has already mentioned one have to convert the boundary file (ASCII) from the dos to unix format!
I think the following 2 options were very useful in order to use harpoon with OpenFOAM:
- boundary file in unix format (instead of dos)
- save the exported files as boundary, cells, faces, points and not as xxx.boundary etc.
Old   March 25, 2008, 19:38
Default I am trying to use Harpoon as
  #59
Alexandre Pereira
alexandrepereira is on a distinguished road
I am trying to use Harpoon as a mesher for OpenFOAM... i am now using OF 1.4.1 under Ubuntu 7.10 32 bits...
Anyone has experience running Harpoon unde Linux x32 Kernel 2.6.x?
I can start the gui... and i can mesh geometries, but once i try to export in any format, OpenFoam, Fluent, CFX5, shell states that it cannot get Global nears... and no export file is created...
Any hint on what might be happening?
Thanks for your time
Alex
alexandrepereira is offline   Reply With Quote
Thread Tools
Trackbacks are On
Did you try Harpoon? HSeldon Main CFD Forum 3 November 27, 2006 05:50
Harpoon CFD-Junior Main CFD Forum 0 June 23, 2005 07:40
Harpoon/CFX5 Oko CFX 8 May 19, 2005 18:53
Harpoon CFD-junior Main CFD Forum 0 May 4, 2005 09:21
