[Other] Update on poles with OpenFOAM/Pointwise export |
April 13, 2009, 15:58 |
Chris Sideroff
Rep Power: 22 |
We have corrected the export of domains with poles where by Pointwise was previously unable to collapse the hex cells with zero faces (along the pole) into prisms.
I checked it using the mesh that su_junwei posted in the original thread (http://www.cfd-online.com/Forums/ope...tml#post193292)and checkMesh reports everything ok. Here's the summary: Code:
Mesh stats points: 6882 faces: 12736 internal faces: 5853 cells: 3135 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 0 Number of cells of each type: hexahedra: 2914 prisms: 221 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Topological cell zip-up check OK. Face vertices OK. Face-face connectivity OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface back 3135 3552 ok (not multiply connected) barrier 362 724 ok (not multiply connected) front 3135 3552 ok (not multiply connected) inlet 15 31 ok (not multiply connected) outlet 15 31 ok (not multiply connected) wall 221 444 ok (not multiply connected) |
[OpenFOAM.org] Compiling OpenFOAM 5.0 on the Titan Supercomputer | wildfire230 | OpenFOAM Installation | 20 | May 6, 2020 07:30 |
[foam-extend.org] foam-extend-4.0 gcc errors & maybe paraFoam | powerline332 | OpenFOAM Installation | 3 | May 24, 2018 21:16 |
A CFX-POST error (ver 14.5.7) | wangyflp88 | CFX | 2 | July 22, 2017 00:17 |
Unable to install OpenFOAM 1.6-ext | Maimouna | OpenFOAM Installation | 23 | May 8, 2014 05:47 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
