[Commercial meshers] foam Mesh to Fluent
Like Tree2Likes
  • 1 Post By Tobi
  • 1 Post By robboflea
Old   October 19, 2009, 16:25
Default foam Mesh to Fluent
tachyon_me is on a distinguished road
I'm trying to get foam mesh converted to fluent with
foamMeshToFluent
I'm not sure how to get this correct ... my fluent mesh is missing all the cellZone information. So I dont have any additional fluid/porous zones in the mesh converted in fluent format ..
Any help appreciated .. thanks
tachyon_me is offline   Reply With Quote
Old   October 21, 2009, 02:59
toto
ronaldo is on a distinguished road
Hi tachyon_me,
let me know ! It is 2D or 3D?
ronaldo is offline   Reply With Quote
Old   October 21, 2009, 10:16
Thanks, it's 3d mesh. I was able to get them after splitting the mesh based on cellzones. Let me also know if there are quick and better way of doing ....
Old   October 22, 2009, 02:06
toto
use fluent3DMeshToFoam and let me know ...
Old   October 22, 2009, 07:02
Gijsbert Wierink
gwierink is on a distinguished road
fluentMeshToFoam myMesh.msh -writeSets -writeZones -scale 0.001
also works most of the time for me (for a mesh called myMesh.msh in mm).
Cheers, Gijs
gwierink is offline   Reply With Quote
Old   October 22, 2009, 10:26
Thanks , Thats helpful...
But In my case I would like to convert SnappyHexMesh "FOAM Mesh" to fluent format while keeping all cellZone as separate fluid zones in fluent...
I guess for this matter I cant do
foamMeshToFluent -time 4 -writeSets -writeZones
But otherwise if you would like to convert fluent mesh to foam the command suggested by Wierink works without a problem ...
Old   September 9, 2011, 06:39
Default hello every one
Jignesh
jignesh_thaker2007 is on a distinguished road
Send a message via Yahoo to jignesh_thaker2007
hi
how i run my openfoam case in to fluent. because when i apply foamDataToFluent then it only convert .dat file but how i generate case file?
plz tel me
jignesh_thaker2007 is offline   Reply With Quote
Old   January 27, 2012, 06:43
Tibor Nyers
Toorop is on a distinguished road
as I see, the problem of exporting the correct region names from a foamMesh to fluentMesh is still present in foamMeshToFluent command. The whole domain is exported, all the regions, but without any distinctive label, merged under the same placeholder / default region name.
How can one overcome this limitation?
How does the splitting method works that is mentioned earlier? I came up with this one:
splitMeshRegions -cellZonesOnly -makeCellZones -overwrite
I can make cellSets based on the regions, but it wont help foamMeshToFluent and I cannot see any special flag for the command.
Toorop is offline   Reply With Quote
Old   October 20, 2014, 22:39
Kan
nwpukaka is on a distinguished road
Originally Posted by Toorop View Post
Hi Tibor:
Are you now able to solve this limitation for foamMeshtoFluent?
nwpukaka is offline   Reply With Quote
Old   September 16, 2015, 14:02
R. P.
Rophys is on a distinguished road
I manage to export a mesh from fluent to OpenFoam; however, when I check the mesh (command checkMesh), I have 5 failures (see below). In addition, when I initialized the case I received a warming (see below). Anybody knows how to solve this problem?
Thanks.
CheckMesh
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            4298112
    internal faces:   4207320
    cells:            1417572
    faces per cell:   6
    boundary patches: 5
    point zones:      0
    face zones:       1
    cell zones:       1
Overall number of cells of each type:
    hexahedra:     1417572
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
 ****Problem with boundary patch 0 named Inlet of type patch. The patch should start on face no 4207320 and the patch specifies 4229394.
Possibly consecutive patches have this same problem. Suppressing future warnings.
 ***Boundary definition is in error.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    Inlet               9945     10132    ok (non-closed singly connected)
    Sym                 39780    40512    ok (non-closed singly connected)
    Outlet              7527     7683     ok (non-closed singly connected)
    Inlet2              11466    11692    ok (non-closed singly connected)
    Wall                22074    22397    ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-0.3000000142 -3.024070027e-14 -3.241690292e-09) (0.6500000309 0.800000038 0.800000038)
    Mesh (non-empty, non-wedge) directions (1 1 1)
 ***Boundary openness (1.281722558e-05 0.01952710315 0.01952386798) possible hole in boundary description.
 ***Open cells found, max cell openness: 0.9711407906, number of open cells 4602
  <<Writing 4602 non closed cells to set nonClosedCells
  <<Writing 89739 cells with high aspect ratio to set highAspectRatioCells
    Minimum face area = 3.116805768e-07. Maximum face area = 0.0001277530998.  Face area magnitudes OK.
 ***Zero or negative cell volume detected.  Minimum negative volume: -2.707374999e-08, Number of negative volume cells: 89739
  <<Writing 89739 zero volume cells to set zeroVolumeCells
    Mesh non-orthogonality Max: 179.8440355 average: 35.79636703
 ***Number of non-orthogonality errors: 265395.
  <<Writing 265395 non-orthogonal faces to set nonOrthoFaces
 ***Error in face pyramids: 538434 faces are incorrectly oriented.
  <<Writing 273039 faces with incorrect orientation to set wrongOrientedFaces
    Max skewness = 1.793962489 OK.
    Coupled point location match (average 0) OK.
Failed 5 mesh checks.
End
Create time
Time = 0
Mesh stats
    faces:            4298112
    cells:            1417572
    faces per cell:   6
    boundary patches: 5
    point zones:      0
    face zones:       1
    cell zones:       1
    hexahedra:     1417572
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
    Point usage OK.
    Face vertices OK.
End
Warning during the initialization
--> FOAM Warning :
    From function List<tetIndices> polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label)
    in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570
    No base point for face 544557, 4(4 192002 192003 6), produces a valid tet decomposition.
Rophys is offline   Reply With Quote
Old   February 2, 2017, 06:10
Tobi's Avatar
Tobias Holzmann
Dear all,
it is a bit terrible to read through this thread because everybody is talking about different things. The thread starter mentioned that he wants to convert an OpenFOAM mesh to a fluent mesh and not vice versa. Based on that, he had problems in converting the cell zone information. Thats simply because in the foamMeshToFluent application this is not considered. I am also looking for some modification to get the cellZone information. Does anyone has done this already or can provide a *.msh file with cellZones (simple cube with two cellZones and 100 cells) in ascii format? If yes, I can make a workaround and solve the problem.
wflores624 likes this.
Keep foaming,
Tobias Holzmann
Old   March 16, 2017, 04:12
robboflea is on a distinguished road
Dear Tobi,
I came across this post and I thought I could post a mesh. It would be great if you could provide the CFD communitiy a workaround
Thanks for the help!
Rob
Tobi likes this.
robboflea is offline   Reply With Quote
Old   March 16, 2017, 04:18
Tobi's Avatar
Tobias Holzmann
Dear Robert,
my colleague does not need it anymore and I have a lot of things to do. I will check it out - maybe during the weekend but I cannot promise it. If I will succeed, I will kindly ask Henry Weller to patch the application. Thanks for your help.
Keep foaming,
Tobias Holzmann
Old   March 20, 2017, 08:48
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Originally Posted by Tobi View Post
Dear Robert,
Is there any way to know about mesh format that openfoam uses. If there is any information and someone willing to provide multi-region sample meshes then i might write down tool to convert openfoam to fluent.
The reason is that FVUS-wildkatze solver can convert from Fluent and from starccm to its format.
FVUS can also write in fluent format (i need to check if current version has but i know that there is code to write fluent file somewhere so its not a big deal).
This opens up possiblity of openfoam users to use FVUS too, so it does interest me.
arjun is offline   Reply With Quote
Old   March 20, 2017, 09:15
Tobi's Avatar
Tobias Holzmann
You can just check out the foam converters. I think you will find all necessary information there. If you have a foamToFluentMeshExtend converter, please let the community know. I have not time to investigate into that right now.
Keep foaming,
Tobias Holzmann
Old   April 21, 2017, 05:24
KaLium's Avatar
Kal-El
KaLium is on a distinguished road
I don't know how to fix this, but you can go around it.
use foamToEnsightParts. You can import the part to fluent (file -> import -> Ensight)
KaLium is offline   Reply With Quote
Old   September 16, 2019, 12:47
Lukas Fischer
lukasf is on a distinguished road
Use
foamMeshToFluent
within the OpenFOAM case directory.
It will create a folder fluentInterface in which you will find the OF mesh in fluent format.
This command works with OpenFOAM 4.1.
lukasf is offline   Reply With Quote
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
