Home > Forums > OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ...
star-ccm mesh to O\/F
Like Tree10Likes
Old   September 18, 2012, 14:38
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Alright... if you had checked the last link I posted, you would have seen the respective command for openSUSE... OK, it's not very similar, but the idea is still there.
Anyway, assuming you're the administrator of the machine:
su -
#the command above will ask for the password of administrator
zypper install -t pattern devel_C_C++
#after installing, run:
exit
Then try build "libccmio" once again.
Old   September 19, 2012, 04:19
emirust is on a distinguished road
Hey all!
Will the procedure in post 27, with the file in post 29 work on OpenFoam 2.1.1 ?
Thanks!
emirust is offline   Reply With Quote
Old   September 19, 2012, 16:57
Bruno Santos
Greetings emirust,
I haven't tested with 2.1.1, but I think it should work.
I don't have time to test it now, so why don't you test it and tell us if it worked or not!?
Best regards,
Bruno
Old   September 20, 2012, 12:18
Hey all!
I followed the procedure and built it on OF 2.1.1. Works well!
Thanks for the easy way wyldckat!
E.
Old   May 7, 2013, 05:31
Slamer
Slamer is on a distinguished road
I am not able to compile it with OpenFOAM 2.2.0
I compile it with :
sudo bash
sudo wmake
and I get this error :
Making dependency list for source file ccm26ToFoam.C
SOURCE=ccm26ToFoam.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam220/src/finiteVolume/lnInclude -I/opt/openfoam220/src/meshTools/lnInclude -I/opt/ThirdParty-2.2.0/libccmio-2.6.1 -I/opt/ThirdParty-2.2.0/libccmio-2.6.1/lnInclude -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/ccm26ToFoam.o
ccm26ToFoam.C: In function ‘int main(int, char**)’:
ccm26ToFoam.C:954:17: erreur: no matching function for call to ‘Foam::wallPolyPatch::wallPolyPatch(const Foam::word&, int&, Foam::label&, Foam::label&, const Foam::polyBoundaryMesh&)’
ccm26ToFoam.C:954:17: note: candidates are:
/opt/openfoam220/src/OpenFOAM/lnInclude/wallPolyPatch.H:97:9: note: Foam::wallPolyPatch::wallPolyPatch(const Foam::wallPolyPatch&, const Foam::polyBoundaryMesh&, Foam::label, const labelUList&, Foam::label)
/opt/openfoam220/src/OpenFOAM/lnInclude/wallPolyPatch.H:97:9: note:   no known conversion for argument 1 from ‘const Foam::word’ to ‘const Foam::wallPolyPatch&’
/opt/openfoam220/src/OpenFOAM/lnInclude/wallPolyPatch.H:87:9: note: Foam::wallPolyPatch::wallPolyPatch(const Foam::wallPolyPatch&, const Foam::polyBoundaryMesh&, Foam::label, Foam::label, Foam::label)
/opt/openfoam220/src/OpenFOAM/lnInclude/wallPolyPatch.H:87:9: note:   no known conversion for argument 1 from ‘const Foam::word’ to ‘const Foam::wallPolyPatch&’
/opt/openfoam220/src/OpenFOAM/lnInclude/wallPolyPatch.H:83:9: note: Foam::wallPolyPatch::wallPolyPatch(const Foam::wallPolyPatch&, const Foam::polyBoundaryMesh&)
/opt/openfoam220/src/OpenFOAM/lnInclude/wallPolyPatch.H:83:9: note:   candidate expects 2 arguments, 5 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/wallPolyPatch.H:73:9: note: Foam::wallPolyPatch::wallPolyPatch(const Foam::word&, const Foam::dictionary&, Foam::label, const Foam::polyBoundaryMesh&, const Foam::word&)
/opt/openfoam220/src/OpenFOAM/lnInclude/wallPolyPatch.H:73:9: note:   no known conversion for argument 4 from ‘Foam::label {aka int}’ to ‘const Foam::polyBoundaryMesh&’
/opt/openfoam220/src/OpenFOAM/lnInclude/wallPolyPatch.H:62:9: note: Foam::wallPolyPatch::wallPolyPatch(const Foam::word&, Foam::label, Foam::label, Foam::label, const Foam::polyBoundaryMesh&, const Foam::word&)
/opt/openfoam220/src/OpenFOAM/lnInclude/wallPolyPatch.H:62:9: note:   candidate expects 6 arguments, 5 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/wallPolyPatch.H:49:7: note: Foam::wallPolyPatch::wallPolyPatch(const Foam::wallPolyPatch&)
/opt/openfoam220/src/OpenFOAM/lnInclude/wallPolyPatch.H:49:7: note:   candidate expects 1 argument, 5 provided
ccm26ToFoam.C:966:17: erreur: no matching function for call to ‘Foam::symmetryPolyPatch::symmetryPolyPatch(const Foam::word&, int&, Foam::label&, Foam::label&, const Foam::polyBoundaryMesh&)’
ccm26ToFoam.C:966:17: note: candidates are:
/opt/openfoam220/src/OpenFOAM/lnInclude/symmetryPolyPatch.H:97:9: note: Foam::symmetryPolyPatch::symmetryPolyPatch(const Foam::symmetryPolyPatch&, const Foam::polyBoundaryMesh&, Foam::label, const labelUList&, Foam::label)
/opt/openfoam220/src/OpenFOAM/lnInclude/symmetryPolyPatch.H:97:9: note:   no known conversion for argument 1 from ‘const Foam::word’ to ‘const Foam::symmetryPolyPatch&’
/opt/openfoam220/src/OpenFOAM/lnInclude/symmetryPolyPatch.H:87:9: note: Foam::symmetryPolyPatch::symmetryPolyPatch(const Foam::symmetryPolyPatch&, const Foam::polyBoundaryMesh&, Foam::label, Foam::label, Foam::label)
/opt/openfoam220/src/OpenFOAM/lnInclude/symmetryPolyPatch.H:87:9: note:   no known conversion for argument 1 from ‘const Foam::word’ to ‘const Foam::symmetryPolyPatch&’
/opt/openfoam220/src/OpenFOAM/lnInclude/symmetryPolyPatch.H:83:9: note: Foam::symmetryPolyPatch::symmetryPolyPatch(const Foam::symmetryPolyPatch&, const Foam::polyBoundaryMesh&)
/opt/openfoam220/src/OpenFOAM/lnInclude/symmetryPolyPatch.H:83:9: note:   candidate expects 2 arguments, 5 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/symmetryPolyPatch.H:73:9: note: Foam::symmetryPolyPatch::symmetryPolyPatch(const Foam::word&, const Foam::dictionary&, Foam::label, const Foam::polyBoundaryMesh&, const Foam::word&)
/opt/openfoam220/src/OpenFOAM/lnInclude/symmetryPolyPatch.H:73:9: note:   no known conversion for argument 4 from ‘Foam::label {aka int}’ to ‘const Foam::polyBoundaryMesh&’
/opt/openfoam220/src/OpenFOAM/lnInclude/symmetryPolyPatch.H:62:9: note: Foam::symmetryPolyPatch::symmetryPolyPatch(const Foam::word&, Foam::label, Foam::label, Foam::label, const Foam::polyBoundaryMesh&, const Foam::word&)
/opt/openfoam220/src/OpenFOAM/lnInclude/symmetryPolyPatch.H:62:9: note:   candidate expects 6 arguments, 5 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/symmetryPolyPatch.H:49:7: note: Foam::symmetryPolyPatch::symmetryPolyPatch(const Foam::symmetryPolyPatch&)
/opt/openfoam220/src/OpenFOAM/lnInclude/symmetryPolyPatch.H:49:7: note:   candidate expects 1 argument, 5 provided
ccm26ToFoam.C:979:17: erreur: no matching function for call to ‘Foam::emptyPolyPatch::emptyPolyPatch(const Foam::word&, int&, Foam::label&, Foam::label&, const Foam::polyBoundaryMesh&)’
ccm26ToFoam.C:979:17: note: candidates are:
/opt/openfoam220/src/OpenFOAM/lnInclude/emptyPolyPatch.H:97:9: note: Foam::emptyPolyPatch::emptyPolyPatch(const Foam::emptyPolyPatch&, const Foam::polyBoundaryMesh&, Foam::label, const labelUList&, Foam::label)
/opt/openfoam220/src/OpenFOAM/lnInclude/emptyPolyPatch.H:97:9: note:   no known conversion for argument 1 from ‘const Foam::word’ to ‘const Foam::emptyPolyPatch&’
/opt/openfoam220/src/OpenFOAM/lnInclude/emptyPolyPatch.H:87:9: note: Foam::emptyPolyPatch::emptyPolyPatch(const Foam::emptyPolyPatch&, const Foam::polyBoundaryMesh&, Foam::label, Foam::label, Foam::label)
/opt/openfoam220/src/OpenFOAM/lnInclude/emptyPolyPatch.H:87:9: note:   no known conversion for argument 1 from ‘const Foam::word’ to ‘const Foam::emptyPolyPatch&’
/opt/openfoam220/src/OpenFOAM/lnInclude/emptyPolyPatch.H:83:9: note: Foam::emptyPolyPatch::emptyPolyPatch(const Foam::emptyPolyPatch&, const Foam::polyBoundaryMesh&)
/opt/openfoam220/src/OpenFOAM/lnInclude/emptyPolyPatch.H:83:9: note:   candidate expects 2 arguments, 5 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/emptyPolyPatch.H:73:9: note: Foam::emptyPolyPatch::emptyPolyPatch(const Foam::word&, const Foam::dictionary&, Foam::label, const Foam::polyBoundaryMesh&, const Foam::word&)
/opt/openfoam220/src/OpenFOAM/lnInclude/emptyPolyPatch.H:73:9: note:   no known conversion for argument 4 from ‘Foam::label {aka int}’ to ‘const Foam::polyBoundaryMesh&’
/opt/openfoam220/src/OpenFOAM/lnInclude/emptyPolyPatch.H:62:9: note: Foam::emptyPolyPatch::emptyPolyPatch(const Foam::word&, Foam::label, Foam::label, Foam::label, const Foam::polyBoundaryMesh&, const Foam::word&)
/opt/openfoam220/src/OpenFOAM/lnInclude/emptyPolyPatch.H:62:9: note:   candidate expects 6 arguments, 5 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/emptyPolyPatch.H:49:7: note: Foam::emptyPolyPatch::emptyPolyPatch(const Foam::emptyPolyPatch&)
/opt/openfoam220/src/OpenFOAM/lnInclude/emptyPolyPatch.H:49:7: note:   candidate expects 1 argument, 5 provided
ccm26ToFoam.C:993:17: erreur: no matching function for call to ‘Foam::polyPatch::polyPatch(const Foam::word&, int&, Foam::label&, Foam::label&, const Foam::polyBoundaryMesh&)’
ccm26ToFoam.C:993:17: note: candidates are:
/opt/openfoam220/src/OpenFOAM/lnInclude/polyPatch.H:214:9: note: Foam::polyPatch::polyPatch(const Foam::polyPatch&)
/opt/openfoam220/src/OpenFOAM/lnInclude/polyPatch.H:214:9: note:   candidate expects 1 argument, 5 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/polyPatch.H:204:9: note: Foam::polyPatch::polyPatch(const Foam::polyPatch&, const Foam::polyBoundaryMesh&, Foam::label, const labelUList&, Foam::label)
/opt/openfoam220/src/OpenFOAM/lnInclude/polyPatch.H:204:9: note:   no known conversion for argument 1 from ‘const Foam::word’ to ‘const Foam::polyPatch&’
/opt/openfoam220/src/OpenFOAM/lnInclude/polyPatch.H:194:9: note: Foam::polyPatch::polyPatch(const Foam::polyPatch&, const Foam::polyBoundaryMesh&, Foam::label, Foam::label, Foam::label)
/opt/openfoam220/src/OpenFOAM/lnInclude/polyPatch.H:194:9: note:   no known conversion for argument 1 from ‘const Foam::word’ to ‘const Foam::polyPatch&’
/opt/openfoam220/src/OpenFOAM/lnInclude/polyPatch.H:190:9: note: Foam::polyPatch::polyPatch(const Foam::polyPatch&, const Foam::polyBoundaryMesh&)
/opt/openfoam220/src/OpenFOAM/lnInclude/polyPatch.H:190:9: note:   candidate expects 2 arguments, 5 provided
/opt/openfoam220/src/OpenFOAM/lnInclude/polyPatch.H:180:9: note: Foam::polyPatch::polyPatch(const Foam::word&, const Foam::dictionary&, Foam::label, const Foam::polyBoundaryMesh&, const Foam::word&)
/opt/openfoam220/src/OpenFOAM/lnInclude/polyPatch.H:180:9: note:   no known conversion for argument 4 from ‘Foam::label {aka int}’ to ‘const Foam::polyBoundaryMesh&’
/opt/openfoam220/src/OpenFOAM/lnInclude/polyPatch.H:169:9: note: Foam::polyPatch::polyPatch(const Foam::word&, Foam::label, Foam::label, Foam::label, const Foam::polyBoundaryMesh&, const Foam::word&)
/opt/openfoam220/src/OpenFOAM/lnInclude/polyPatch.H:169:9: note:   candidate expects 6 arguments, 5 provided
make: *** [Make/linux64GccDPOpt/ccm26ToFoam.o] Erreur 1
root@sabre2:/opt/openfoam220/applications/utilities/mesh/conversion/Optional#
root@sabre2:/opt/openfoam220/applications/utilities/mesh/conversion/Optional# wmake ccm26ToFoam
I don't know what do I miss ?
I modified the options file in Make/options as mentionned before but I'm not sure it points to the correct target. What file are supposed to be missing ?
Thanks in advance.
Slamer is offline   Reply With Quote
Old   May 7, 2013, 16:45
Bruno Santos
Greetings Slammer and welcome to the forum!
OpenFOAM 2.2.0 had a bug in the "ccm26ToFoam.C" source code file. The fix is this one: https://github.com/OpenFOAM/OpenFOAM...8af7a51d41fc4b
You can edit the file and manually replace the text in red for the text in green
Best regards,
Bruno
Old   May 13, 2013, 08:23
Slamer
I was not able to remeber where the git repo was.
It helps me more than expected
It compiles and 'work' on an exemple. Now, I just need to check if it does the right things.
Thanks a lot.
Old   May 19, 2013, 15:52
Jack220 is on a distinguished road
I'm using the Ubuntu Deb package version 2.2.0. I already changed the ccm26ToFoam.C as mentioned above. It still doesn't work. Do I need to do something else?
Thanks in advance
Jack220 is offline   Reply With Quote
Old   May 19, 2013, 16:01
Bruno Santos
Greetings Jack220 and welcome to the forum!
OK, after you've adapted the source code, what else did you do?
Did you follow the steps from post #37: http://www.cfd-online.com/Forums/ope...tml#post365682
Best regards,
Bruno
Old   May 21, 2013, 13:46
Hi Bruno,
thank you for your fast answer!
I went in the direction with my .ccm file and executed the command "ccm26ToFoam file.ccm". The following message appeared: "command not found".
But in "/opt/openfoam220/applications/utilities/mesh/conversion/Optional/ccm26ToFoam" I can see my "ccm26ToFoam.C"-file.
I can't do the steps described in post #37:
First of all, I had to create the "ThirdParty-xxx" directory, because I could'nt find it.
And when I execute "AllwmakeLibccmio" the following error occurs:
/opt/openfoam220/ThirdParty-2.2.0/AllwmakeLibccmio: 39: .: Can't open tools/makeThirdPartyFunctions
Best regards,
Jack
Old   May 21, 2013, 17:28
Bruno Santos
Hi Jack,
Attached is a new and improved installation script, specifically created for OpenFOAM 2.2.0 and 2.2.x, based on the one from my old posts, namely #27.
To use it:
  1. Download the attached file.
  2. Unpack it:
    tar -xf ccm26local220.tar.gz
  3. Go into the folder "ccm26local220" and run the script:
    cd ccm26local220
    ./ccm26local
  4. Follow the instructions the script gives you.
Best regards,
Bruno
Artur and wolampire like this.
Old   May 22, 2013, 06:12
Thank you very much, Bruno! That works fine!
Old   June 6, 2013, 02:54
Alexander
WildSinner is on a distinguished road
Hey all!
Can you help me?
I have done all of instructions of the post #51. Instalation have installed correct.
I have little experience in the use of Linux and OpenFoam.
I have mesh from StarCCM+ 8.02. par example ~/Desktop/new/star_CCM.ccm
I want to covert this mesh to Fluent.
I understand that I have to convert this mesh to FOAM and FOAM to Fluent.
Could you write commands or sequencing that need to run these?
thanks in advance!
WildSinner is offline   Reply With Quote
Old   August 2, 2013, 10:21
Vimaldoss Jesudhas
Sniper is on a distinguished road
Hi Alexander,
Any luck with your conversion from StarCCM to Fluent. I want to a similar thing, your inputs will be helpful
Sniper is offline   Reply With Quote
Old   August 17, 2013, 10:04
Bruno Santos
Greetings to all!
It's somewhat simple to perform this conversion, but I would say that it is very likely to result in having a bad mesh on Fluent's side, due to the 2 step conversion process.
Any way, the steps are:
  1. On the command line, first copy a tutorial case from OpenFOAM's tutorials, because you're going to need a case to act as a base structure for having the intermediate mesh. For example:
    cp -r $FOAM_TUTORIALS/incompressible/icoFoam/cavity .
    cd cavity
  2. Then run the CCM converter on your CCM+ mesh:
    ccm26ToFoam yourmesh.ccm
  3. Then export the current mesh to Fluent format:
    foamMeshToFluent
  4. The resulting mesh file is placed automatically inside the folder "fluentInterface".
But as I said, prepare yourself for complaining about the resulting bad mesh
Best regards,
Bruno
Old   March 23, 2014, 21:32
wflo is on a distinguished road
Once you finish the steps in the post #51. Next I tried to do the following:
From here the terminal window gave me an error.
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/wilmer/Downloads/ccm26local220/system/controlDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
I'm new to this. Could anyone tell me if I'm following the directions right? Any steps that I'm missing here?
wflo is offline   Reply With Quote
Old   March 23, 2014, 23:48
Ziad Boutanios
ziad is on a distinguished road
Set up your case properly including the full hierarchy of folders and files. The error means you need to have a system/ folder with a valid controlDict file in it.
ziad is offline   Reply With Quote
Old   March 27, 2014, 03:20
Baris (Heewa)
shipman is on a distinguished road
Hi Bruno,
I am using version 2.1.1 and first i downloaded file at post 29 and followed the procedure as you explained at post 27. However it gives following error:
HTML Code:
baris@BICER:~/OpenFOAM/baris-2.1.1/applications/ccmio$ ./ccm26local
+ ./AllwmakeLibccmio
downloading libccmio-2.6.1.tar.gz from https://wci.llnl.gov/codes/visit/3rd_party/libccmio-2.6.1.tar.gz
--2014-03-27 16:14:11--  https://wci.llnl.gov/codes/visit/3rd_party/libccmio-2.6.1.tar.gz
Resolving wci.llnl.gov (wci.llnl.gov)... 198.128.246.10
Connecting to wci.llnl.gov (wci.llnl.gov)|198.128.246.10|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2014-03-27 16:14:12 ERROR 404: Not Found.
no download/libccmio-2.6.1.tar.gz to unpack
+ cd libccmio-2.6.1
./AllwmakeLibccmio: 61: cd: can't cd to libccmio-2.6.1
+ exit 1
+ [ -e /home/baris/OpenFOAM/baris-2.1.1/platforms/linux64GccDPOpt/lib/libccmio.so ]
could you help to me how can i solve this problem.
Thanks in advance.
B
shipman is offline   Reply With Quote
Old   March 28, 2014, 18:50
Bruno Santos
Quick answer - Try the one from post #51: http://www.cfd-online.com/Forums/ope...tml#post429003
Old   March 30, 2014, 05:23
Baris (Heewa)
Hi Bruno,
Thanks so much. It is working well
.msh, .vrt, mesh conversion, star-ccm
Thread Tools
Trackbacks are On
Mesh Transfer from ICEM to STAR CCM+ Waseem Siddique CD-adapco 4 February 12, 2009 07:02
Problem wih MESh in Star Design Waseem Siddique CD-adapco 3 January 28, 2009 08:19
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
