Home > Forums > OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ...
star-ccm mesh to O\/F
Like Tree10Likes
Old   March 31, 2014, 06:41
wflo is on a distinguished road
Thanks ziad you were right. I just needed to add the necessary folders for an openfoam project. I then placed the ccm file into the project folder and ran the ccmtofoam command to populate the polymesh folder for the conversion to work. I appreciate the help.
wflo is offline   Reply With Quote
Old   April 1, 2014, 21:13
Pengchuan Wang
pechwang is on a distinguished road
Originally Posted by wyldckat View Post
Quick answer - Try the one from post #51: http://www.cfd-online.com/Forums/ope...tml#post429003
Hi Bruno,
Thank you for your detailed instruction. I'm new to OpenFOAM and I use OpenFOAM-2-1-1. I followed #51 step by step, after I ran the ccm26local, I got an error, so I didn't get instructions the script gives. The error is kind of complex for me and I don't know how to show it to you. So can you help me with this?
Thanks,
Pengchuan
pechwang is offline   Reply With Quote
Old   April 1, 2014, 21:25
Baris (Heewa)
shipman is on a distinguished road
Hi wang,
Post your error here then may i can help to you...
B
shipman is offline   Reply With Quote
Old   April 1, 2014, 21:36
Pengchuan Wang
Hi Baris,
Thank you for you help.
The error is in the attachment. I couldn't post it here. It says that I have more than 10 images, which makes me confused.
Thank you again.
Pengchuan
Old   April 2, 2014, 00:29
Baris (Heewa)
Hi wang,
just let me know that when you run the ./ccm26local and saw the following line
Have you contacted CD-Adapco and received the libccmio package? (yes/no): Did you write here yes or only y..you should write directly yes then it will work well.
And also check again whether you are in the correct folder (cd ccm26local220)or not in terminal.
Hope this helps..
B
Old   April 2, 2014, 00:39
Pengchuan Wang
Hi Baris,
I did answer "yes" in the terminal.
Thanks,
Pengchuan
Old   April 2, 2014, 00:41
Baris (Heewa)
So it works fine or still gives same error?
Old   April 2, 2014, 00:50
Pengchuan Wang
Hi Baris,
It still gives the same error
make: *** [Make/linuxGccDPOpt/ccm26ToFoam.o] Error 1
after that the compile stops.
Thanks,
Pengchuan
Old   April 2, 2014, 00:58
Baris (Heewa)
ohh Wang ok i got it...your version 2.1.x but if you follow from post #51 which is for v.2.2.x
so please follow in post 27, with the file in post 29 work for OpenFoam 2.1.1
I think that it will work fine.
Best regards.
B.
Old   April 2, 2014, 01:05
Pengchuan Wang
Hi Baris,
Thank you for your quick reply. I followed your advice, I downloaded the file in #29 and follow the instruction in #27. However, I still get some errors.
+ ./AllwmakeLibccmio
downloading libccmio-2.6.1.tar.gz from https://wci.llnl.gov/codes/visit/3rd...o-2.6.1.tar.gz
--2014-04-02 01:01:55-- https://wci.llnl.gov/codes/visit/3rd...o-2.6.1.tar.gz
Resolving wci.llnl.gov (wci.llnl.gov)... 198.128.246.10
Connecting to wci.llnl.gov (wci.llnl.gov)|198.128.246.10|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2014-04-02 01:01:56 ERROR 404: Not Found.
no download/libccmio-2.6.1.tar.gz to unpack
+ cd libccmio-2.6.1
./AllwmakeLibccmio: 61: cd: can't cd to libccmio-2.6.1
+ exit 1
+ [ -e /home/pechwang/OpenFOAM/pechwang-2.1.1/platforms/linuxGccDPOpt/lib/libccmio.so ]
+ wmake ccm26ToFoam
Making dependency list for source file ccm26ToFoam.C
SOURCE=ccm26ToFoam.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam211/src/finiteVolume/lnInclude -I/opt/openfoam211/src/meshTools/lnInclude -I/home/pechwang/OpenFOAM/pechwang-2.1.1/Optional/libccmio-2.6.1 -I/home/pechwang/OpenFOAM/pechwang-2.1.1/Optional/libccmio-2.6.1/lnInclude -IlnInclude -I. -I/opt/openfoam211/src/OpenFOAM/lnInclude -I/opt/openfoam211/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/ccm26ToFoam.o
ccm26ToFoam.C:46:19: fatal error: ccmio.h: No such file or directory
compilation terminated.
So which file do I need to use, from #27 or from #29
Thanks,
Pengchuan
Old   April 2, 2014, 01:20
Baris (Heewa)
you should use file from #29 and follow the instruction from #27. It should work, bcs i tried and works fine. By the way, if you ask my opinion, you just wanna convert the mesh then easily download last version of OP 2.3.0
and change by running: gedit ~/.bashrc
as source /opt/openfoam230/etc/bashrc
then follow post #51.
after you convert your mesh then you can reset .bashrc file as
opt/openfoam211/etc/bashrc
B
Old   November 25, 2014, 12:05
brandius is on a distinguished road
Hiya,
thanks for writing this script! Unfortunately, it doesn't work for me. Maybe the reason is that I'm trying with OF230? I do not really want to install OF2.2.x (using Ubuntu 14.04 it takes some time to compile the source code), but maybe I will have to give it a try.
last error is:
If you have any remark, please find attached the error file.
brandius is offline   Reply With Quote
Old   November 26, 2014, 07:36
Okay, thanks, it works with OpenFOAM-2.2.2!
However, I now have the problem that I am not sure whether the conversion process is doing the right job. When I open the converted mesh in paraView, under Information/Statistics/Number_of_cells a far higher amount of cells is displayed than in the original StarCCM mesh. Paraview suggests that the topology has changed.
However, if I run checkMesh it tells me the right statistics and the right number of cells. Now I don't have an idea how to check whether the problem is on the paraFoam displaying side or on the side of the mesh conversion. Any ideas?
I have attached both grids. You can see, that some of the rectangles of the surface mesh are divided into several triangles.
Old   November 30, 2014, 07:37
Bruno Santos
wyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of light
Quick answer: http://openfoamwiki.net/index.php/FA...is_in_ParaView
Old   March 28, 2016, 10:55
Bruno Santos
Greetings to all!
I've finished creating a git repository that has the instructions and part of the needed code for building and installing the ccm26ToFoam utility.
The installation instructions are available in the main page of the new repository: localCCM26ToFOAM
Best regards,
Bruno
panda, PanPeter and Elliptic CFD like this.
Old   September 15, 2016, 06:12
Francesco
phemt84 is on a distinguished road
Hi guys,
is there anyone who has installed ccm226tofoam in OF v1606??
Best regards
Francesco
phemt84 is offline   Reply With Quote
Old   September 17, 2016, 08:10
Bruno Santos
Originally Posted by phemt84 View Post
Hi guys,
Best regards
Francesco
Quick answer: I've added support for it just now on the repository that I'm maintaining: https://github.com/wyldckat/localCCM...tree/of+v1606+
Old   September 19, 2016, 09:25
Francesco
Thanks!!!
.msh, .vrt, mesh conversion, star-ccm
Thread Tools
Trackbacks are On
Mesh Transfer from ICEM to STAR CCM+ Waseem Siddique CD-adapco 4 February 12, 2009 07:02
Problem wih MESh in Star Design Waseem Siddique CD-adapco 3 January 28, 2009 08:19
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
