checkmesh => Open cells found, max cell openness
I wonder what is the meaning of the following message: ***Open cells found, max cell openness: 0.0218725, number of open cells 1830 <<Writing 1830 non closed cells to set nonClosedCells I am getting this message on a polyhedral mesh, which btw works fine on fluent. What can I do to fix this error? Regards, Joel |
Hi Joel,
I got the same problem as well. Have you solved yours? If so, could you give me some directions? Thank you very much. Best, Hang |
Well, so far I haven't figure out what is the problem. For simple polyhedral meshes it works fine, but when I use complex geometries it always gives me this problem. So I decided not to use polyhedral meshes on complex geometries, and honestly speaking I don't use polyhedral meshes I just was testing OpenFOAM ability to handle them. jg |
