Home > Forums > OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ...
Help needed for HRSG Simulation
Old   June 13, 2011, 16:15
Question Help needed for HRSG Simulation
Hassaan Rafi
hassaan is on a distinguished road
I have made the geometry and have meshed it in Gambit (in 2D ).
I applied the boundary zones in the following way.
1. Water Pipes -- Wall BC.
2. One Edge as --Mass Flow Inlet
3. another edge as --Pressure Outlet
When i export it to Fluent, it loads properly but when i go to specify the boundary conditions at these zones. The 'mass flow inlet' and 'pressure outlet' zones are not listed there.
May i add i am new to CFD. So, your help will be greatly appreciated. Its my final year project.
Thanks in advance.
hassaan is offline   Reply With Quote
Old   June 14, 2011, 03:26
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
OpenFOAM isn't supposed to recognize the kind of BC you set up, but it will recognize the patch name you gave in Gambit.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   June 16, 2011, 17:27
Hassaan Rafi
I see but for some reason it was not even recognizing all the patch names.
However, i am now using ANSYS 12.0 to solve the case and i am facing another difficulty. I am new to CFD analysis and i cant seem to figure out how to use wall BC to simulate heat transfer between two fluids.
I am analyzing the heat transfer between two fluids separated by a metal pipe. I am using the wall boundary condition to separate the fluids. However, i am unable to understand how to use the wall BC.
Can anyone help me with this? any examples or tutorials than can be of help? Thanks in advance!
boundary condition, fluent 12.0, gambit 2.4.6, hrsg
Thread Tools
Trackbacks are On
GUI crash and simulation engine still running RPJones FLOW-3D 2 November 9, 2010 09:18
velocity profile export from a simulation onto another sudhirlv STAR-CCM+ 1 September 12, 2010 18:57
Needed Help on Welding Simulation Process darshankapadia FLUENT 0 August 7, 2010 08:37
Blunt body aerodynamics simulation cases needed David FLUENT 0 June 1, 2003 11:40
Stirling engine simulation advice needed Geoffrey Main CFD Forum 2 December 18, 2001 03:26
