June 13, 2011, 16:15 |
HRSG Simulation
Hassaan Rafi
I have made the geometry and have meshed it in Gambit (in 2D ).
I applied the boundary zones in the following way. 1. Water Pipes -- Wall BC. 2. One Edge as --Mass Flow Inlet 3. another edge as --Pressure Outlet When i export it to Fluent, it loads properly but when i go to specify the boundary conditions at these zones. The 'mass flow inlet' and 'pressure outlet' zones are not listed there. May i add i am new to CFD. So, your help will be greatly appreciated. Its my final year project. Thanks in advance. Last edited by hassaan; June 14, 2011 at 02:28. |
June 14, 2011, 03:26 |
Maxime Perelli
Rep Power: 41 |
OpenFOAM isn't supposed to recognize the kind of BC you set up, but it will recognize the patch name you gave in Gambit.
In memory of my friend Hervé: CFD engineer & freerider |
June 16, 2011, 17:27 |
#3 | |
Hassaan Rafi
However, i am now using ANSYS 12.0 to solve the case and i am facing another difficulty. I am new to CFD analysis and i cant seem to figure out how to use wall BC to simulate heat transfer between two fluids. I am analyzing the heat transfer between two fluids separated by a metal pipe. I am using the wall boundary condition to separate the fluids. However, i am unable to understand how to use the wall BC. Can anyone help me with this? any examples or tutorials than can be of help? Thanks in advance! |
boundary condition, fluent 12.0, gambit 2.4.6, hrsg |
Convergence Problem - Transient Simulation | gemxx | Main CFD Forum | 0 | July 15, 2018 09:36 |
Mapping Field Data for Mesh Regions from Another Simulation | veterator | OpenFOAM Pre-Processing | 1 | July 10, 2018 05:28 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 02:28 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 15:06 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 03:16 |
