[Sponsors] | |||||
prem
Rep Power: 3 ![]() |
Hi
How can meshing done in Gambit to one surface inside the other separately? If I have a circle inside a rectangle, how can I remove the mesh of rectangle inside circle and create separate mesh for the circle. Thanks |
Maxime Perelli
Rep Power: 24 ![]() |
you need to split the rectangle surface with the circle.
In memory of my friend Hervé: CFD engineer & freerider ![]() |
prem
thanks max..but how could I split the surface? Did you mean the modify/split mesh command?
prem
now I got it..by Boolean operations..
MA Lorin
Rep Power: 4 ![]() |
Hi Foamers,
Do you know how can I get a .obj file to run a case similarly to the wingMotion tutorial ? I'm working on GAMBIT and .msh files but I'd like to use snappyHexMesh function ... Thanks in advance M.A. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [ICEM] Meshing a blade inside air volume | LittleBart | ANSYS Meshing & Geometry | 19 | October 10, 2012 09:20 |
| meshing a spherical surface | Mansureh | ANSYS Meshing & Geometry | 1 | October 19, 2010 13:54 |
| pump meshing inside the sump | ashwin | FLUENT | 0 | March 16, 2007 07:57 |
| Normal - Helical Surface | m. malik | Main CFD Forum | 3 | February 3, 2006 12:56 |
| meshing when surface vertex are known | ml | CD-adapco | 1 | March 10, 2002 17:51 |
