-   OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... (http://www.cfd-online.com/Forums/openfoam-meshing-other/)
-   -   problems with .msh mesh (http://www.cfd-online.com/Forums/openfoam-meshing-other/92050-problems-msh-mesh.html)
paulovss August 31, 2011 13:45
I'm having trouble converting a mesh. msh . In the terminal window of my case, when I type the command gmshToFoam, it appears:
-> FOAM FATAL IO ERROR:
wrong token type - expected word found on line 0 the punctuation token '('
file: IStringStream.sourceFile at line 0.
From function operator>> (istream &, & word)
in file primitives / strings / word / wordIO.C at line 76.
FOAM exiting
what it means and how can I solve this problem? I am new to OpenFoam. Thank you.
-mAx- September 1, 2011 02:15
Are you sure that your mesh file comes from Gmesh?
Because Gambit can also generate *.msh files, and in this case you need
paulovss September 29, 2011 08:05
I made this mesh on Gambit. Do I need do something diferent to export it to OpenFoam ?
Thanks.
-mAx- September 29, 2011 08:08
fluentMeshToFoam instead of gmshToFoam
http://www.cfd-online.com/Forums/ope...open-foam.html
paulovss September 29, 2011 21:42
it works! Thanks! ;D
