Home > Forums > OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ...
How to convert a .msh file to open Foam?
Like Tree22Likes
Old   October 23, 2012, 06:18
hadi abdollahzadeh
dark lancer is on a distinguished road
thank -mAx-
its work
dark lancer is offline   Reply With Quote
Old   October 27, 2012, 07:14
hadi abdollahzadeh
hi
I can convert my .msh file and create some files that includes boundry,faces,points,zonepoints and ...
now how can I create the blockMesh file?
Old   October 27, 2012, 12:01
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
no blockMesh is just another way for meshing.
In your case you can go and define your boundary conditions
Don't forget to scale your problem with transformPoints
Also checkMesh and renumberMesh
archeoptyrx likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   October 28, 2012, 14:36
Nima Samkhaniani
nimasam is on a distinguished road
Originally Posted by dark lancer View Post
hi
blockMeshDict is for once that you want to create your mesh in OpenFOAM,
when you import your file from gambit or some where else it is not necessary any more,
now the main file you maybe want to change is "boundary" file in constant/polyMesh
there, you can define your boundary name or type!
also as Max told, another tools are checkMesh and transportPoints
checkMesh is an utility which shows whether your mesh is suitable for OpenFOAM or not and return some essential results of your mesh.
Telegram channel (https://telegram.me/openfoam4Iranian)
My Weblog (http://openfoam.blogfa.com/)
Training Course on OpenFOAM at (http://www.isme.ir/)
nimasam is offline   Reply With Quote
Old   November 13, 2012, 10:51
hadi abdollahzadeh
thanks for reply
now I have a file .msh and when convert it I see this error
Creating patch 0 for zone: 3 name: wall type: wall
Creating patch 1 for zone: 4 name: body type: wall
Creating patch 2 for zone: 5 name: outlet type: outflow
Creating patch 3 for zone: 6 name: inlet type: inlet-vent
Creating cellZone 0 name: fluid type: fluid
Creating faceZone 0 name: default-interior type: interior
faceZone from Fluent indices: 217967 to: 26546254 type: interior
new cannot satisfy memory request.
This does not necessarily mean you have run out of virtual memory.
It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library
Aborted (core dumped)
[hadi@hadi bluntbody]$
Old   November 13, 2012, 10:57
-mAx-'s Avatar
Maxime Perelli
... cannot satisfy memory request.
How big is your mesh, and how many ram-memory do you have?
Old   November 13, 2012, 11:59
hadi abdollahzadeh
my size of file 1.8gig and my ram is 8gig
Old   November 14, 2012, 01:41
-mAx-'s Avatar
Maxime Perelli
how many cells?
Old   November 28, 2012, 02:52
hadi abdollahzadeh
hi
I excute the checkMesh , All of them its Ok but at the end line :
moosaie@:~/OpenFOAM/OpenFOAM-2.1.1/tutorials/discreteMethods/dsmcFoam/hemispherical> checkMesh
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.1.1-221db2718bbb
Exec : checkMesh
Date : Nov 17 2012
Time : 12:53:01
Host : ".site"
PID : 6467
Case : /home/moosaie/OpenFOAM/OpenFOAM-2.1.1/tutorials/discreteMethods/dsmcFoam/hemispherical
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 4387940
internal faces: 4308820
cells: 1449460
boundary patches: 5
point zones: 0
face zones: 1
cell zones: 1
Overall number of cells of each type:
hexahedra: 1449460
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
body 17480 17694 ok (non-closed singly connected)
symmetry 34040 34576 ok (non-closed singly connected)
outlet_from_side 13524 13764 ok (non-closed singly connected)
outlet 10902 11079 ok (non-closed singly connected)
inlet 3174 3267 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-262.5 -262.5 -0.4142099593) (1375 262.5 262.5)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (1.756589626e-16 1.121895293e-15 5.86943899e-15) OK.
Max cell openness = 1.916326799e-15 OK.
Max aspect ratio = 61.10879384 OK.
Minumum face area = 0.01039895189. Maximum face area = 280.93608. Face area magnitudes OK.
Min volume = 0.001605026005. Max volume = 2372.742765. Total volume = 167688127. Cell volumes OK.
Mesh non-orthogonality Max: 86.44406365 average: 27.94667529
*Number of severely non-orthogonal faces: 20108.
Non-orthogonality check OK.
<<Writing 20108 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
***Max skewness = 4.752768679, 879 highly skew faces detected which may impair the quality of the results
<<Writing 879 skew faces to set skewFaces
Coupled point location match (average 0) OK.
Failed 1 mesh checks.
End
Old   November 28, 2012, 09:05
Nima Samkhaniani
you can see high skewness mesh in paraview, but what exactly do you want to know?
Old   November 28, 2012, 11:10
hadi abdollahzadeh
salam
I want to know what is this?and what should I do for this error?
where can I see high skewness mesh in paraview?
I see my geometry in paraFoam and its look like gambit file.
Old   November 29, 2012, 06:21
Nima Samkhaniani
salam
search mesh skewness, you will find alot
but if you want to see the high skewness cells
in paraview, activate include sets , then choose skew cells
dark lancer likes this.
Old   December 9, 2012, 07:02
hadi abdollahzadeh
hi
I solved my skew error with divided the volumes in to the small parts.but now I face this error:
non positive volumes exists.
I check the volumes in the Examine mesh/volume and I put the the upper limit in to the 0 then show a face.I remesh and after check I don't see that faces and any thing but when I converted I see this error again:
Old   December 9, 2012, 11:54
Nima Samkhaniani
maybe it returns for the direction of block definition
Old   January 31, 2013, 07:30
Question
  #55
Ali Khalifesoltani
asoltoon is on a distinguished road
Hello All,
I have a *.msh file and I'm trying to convert it to OpenFoam format. when I use fluentMeshToFoam or fluent3DMeshToFoam functions, the mesh is apparently converted. Even when I check the mesh with checkMesh function it says that the mesh is O.K. but when I make the mesh by blockMesh it makes an error:
Cannot open mesh description file
"/home/ali/OpenFOAM/ali-2.1.1/run/tutorials/multiphase/LTSInterFoam/wigleyHull2/constant/polyMesh/blockMeshDict"
my question is how the blockMeshDict should be created for my mesh?
When I put another tutorials blockMeshDict file beside my mesh, the blockMesh works but the mesh shown in Paraview is just a cube, that is my outer boundary not all of it.
What should I do to fix the problem?
Thanks in advance,
Ali
asoltoon is offline   Reply With Quote
Old   January 31, 2013, 07:34
-mAx-'s Avatar
Maxime Perelli
Once your mesh is converted with fluentMeshToFoam or fluent3DMeshToFoam, then your geometry is ready.
What do you want to do with blockMesh?
Old   February 1, 2013, 16:34
hadi abdollahzadeh
salam
dear Ali
when you create your mesh and covert it ,It's not nessary use blockMesh
because blockMesh is utility that create mesh
after convert your mesh ,set your B.Cs and run your case
asoltoon likes this.
Old   February 2, 2013, 06:12
Ali Khalifesoltani
Hi MAX,
My Problem is solved. thanks for the reply.
Regards, Ali
Old   February 2, 2013, 06:14
Ali Khalifesoltani
Dear Hadi,
Thanks for the reply,
my problem is solved,
Regards,
Ali
Old   May 2, 2013, 15:29
Unhappy Fluent mesh conversion
  #60
sud
archeoptyrx is on a distinguished road
Hi danath ,
I tried converting in the same way u did . but it shows errors for me ..
my msh file is flat.msh.
I created a folder named Flat plate (/OpenFOAM/OpenFOAM-2.2.0/tutorials/incompressible/simpleFoam/Flat Plate$)
I then copied the flat.msh into this .
I also copied the O , constant , system in any one of the tutorials folder into it .
now the Flat plate folder consists of the following things
1.0 folder
2.constant folder
3.system folder
4.flat.msh
when i pointed to the Flat plate folder and in the terminal , i gave
fluentMeshToFoam flat.msh ..
It shows error .. . I am struggling a lot to do this simple conversion . Can you help me with this ..
archeoptyrx is offline   Reply With Quote
Thread Tools
Trackbacks are On
OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 electrosin OpenFOAM Installation 40 May 31, 2016 05:11
GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM 300 October 29, 2014 19:00
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 09:33
Version 15 on Mac OS X gschaider OpenFOAM Installation 120 December 2, 2009 11:23
Import gmsh msh to Foam adorean Open Source Meshers: Gmsh, Netgen, CGNS, ... 24 April 27, 2005 08:19
