Home > Forums > OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ...
How to convert a .msh file to open Foam?
Like Tree22Likes
Old   May 3, 2013, 08:44
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
try fluent3DMeshToFoam flat.msh
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 3, 2013, 11:57
Evangelos
Danath is on a distinguished road
what kind of erros?
if the geometry is 3D try fluent3DMeshToFoam flat.msh
Danath is offline   Reply With Quote
Old   May 3, 2013, 15:21
sandy
archeoptyrx is on a distinguished road
Its 2D mesh guys .
the flat plate is at the base of the domain . I created using meshing tool in Ansys workbench . And i saved it as fluent readable one using export option .
(flat.msh)
As i later on found that the .msh file should be in ASCII format but the meshing tool in ansys workbench saves .msh file in binary form.
So i found in one of the threads using dos2unix command to convert to ASCII in my linux system terminal ..
$ dos2unix flat.msh
It shows the following errors .
"binary at line 15
dos2unix is quitting "
What should i do now ?
thanks
sud
archeoptyrx is offline   Reply With Quote
Old   May 3, 2013, 16:41
Evangelos
try
http://searchitchannel.techtarget.co...ment-variables
Old   May 4, 2013, 00:37
sandy
Hi Danath & Maxime Perelli ,
I finally got it converted to open foam readable format .
Now here comes the problem .
I tried running blockMesh after that . IT shows some errors .
I checked the Run/try/constant/polymesh folder for blockmeshdict file .
it has all files like
1.boundary
2.owner
3.faces
4.cellzones
5.facezones
6.pointzones
7.points
but it did not have blockmeshDict .
thanks
sud
Old   May 4, 2013, 00:59
Unhappy BlockMeshDict
  #66
sandy
Hi nimasam ,
ok . Now i should not type blockMesh in the terminal right ? .. I typ
ed checkMesh . It shows the following errors .
sudharsan@ubuntu:~/OpenFOAM/OpenFOAM-2.2.0/tutorials/incompressible/icoFoam/Cylinder ansysimport$ checkMesh
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.2.0
Exec : checkMesh
Date : May 03 2013
Time : 23:58:44
Host : "ubuntu"
PID : 4001
fileName::stripInvalid() called for invalid fileName /home/sudharsan/OpenFOAM/OpenFOAM-2.2.0/tutorials/incompressible/icoFoam/Cylinderansysimport
For debug level (= 2) > 1 this is considered fatal
Aborted (core dumped)
Originally Posted by nimasam View Post
blockMeshDict is for once that you want to create your mesh in OpenFOAM,
when you import your file from gambit or some where else it is not necessary any more,
now the main file you maybe want to change is "boundary" file in constant/polyMesh
there, you can define your boundary name or type!
also as Max told, another tools are checkMesh and transportPoints
checkMesh is an utility which shows whether your mesh is suitable for OpenFOAM or not and return some essential results of your mesh.
Old   May 4, 2013, 12:18
Bruno Santos
wyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of lightwyldckat is a glorious beacon of light
Greetings to all!
@archeoptyrx: Rename the folder "Cylinder ansysimport" to "Cylinder_ansysimport", because OpenFOAM doesn't like spaces in folder/file names.
Best regards,
Bruno
Old   May 6, 2013, 02:17
sandy
Bruno Santos , Yea that worked.... Thanks
Old   May 8, 2013, 06:59
Matteo Colli
supercolli is on a distinguished road
Hi, may I ask you how did you get the problem solved? I'm in the same situation, I can't convert my msh file using dos2unix because it is recognized as binary.
Matteo
supercolli is offline   Reply With Quote
Old   August 24, 2013, 04:22
胡长旭
hcx552362 is on a distinguished road
Originally Posted by -mAx- View Post
it depends on what you want to solve
Choose and copy a tutorial from OF folder (tutorials are sorted with solver).
Then if your mesh is full hexa, you can use following command to import your mesh
>fluentMeshToFoam your_mesh.msh
If your mesh constains any hanging nodes (typical with tetra-hexcore), you need to use the tpoly conversion within fluent, and then in OF use following command:
>fluent3DMeshToFoam your_mesh.msh
Once your mesh is well imported (use checkMesh to be sure everything is ok), you can modify the boundary files in /0 folder
hi Max:
I have the same question. When I run fluentMeshToFoam /...../..msh. it will appear
Form FATAL IO ERROR
cannot find file
file:/home/hu/system/controldict at line 0
from.....and so on
what is the matter? I think you can help me.
Have a nice day
hcx552362 is offline   Reply With Quote
Old   August 24, 2013, 04:43
payal
payal05 is on a distinguished road
helo ,
can you tell me hw you are converting means which command are you using and where you had kept your mesh files .???
payal05 is offline   Reply With Quote
Old   August 24, 2013, 19:55
Bruno Santos
Greetings to all!
@hcx552362:
Form FATAL IO ERROR
cannot find file
from.....and so on
Although you quoted Max's post, you did not follow all of the instructions, more specifically this one:
If you do not know what tutorials Max was talking about, I suggest you start reading the OpenFOAM User Guide from the beginning of chapter 2: http://www.openfoam.org/docs/user/tutorials.php
Best regards,
Bruno
Old   August 24, 2013, 19:58
胡长旭
Originally Posted by payal05 View Post
helo ,
Hi payal05:
firstly, I copy a msh file and put it in the .../tutorials/incompressible/icoFoam/cavity.
secondly, run the code: fluentMeshToFoam/OpenFOAM/hu2.1.x/run/tutorials/incompressible/icoFoam/cavity/hu.msh
above error will appear.
Old   August 24, 2013, 20:59
Bruno Santos
From your description, it looks like you did not run the fluentMeshToFoam from within the "cavity" folder. For example:
cd $FOAM_RUN/tutorials/incompressible/icoFoam/cavity
fluentMeshToFoam hu.msh
Old   August 25, 2013, 01:47
胡长旭
hi, Thanks for your reply!
I think my .msh from my gambit has some questions. When I use other .msh from other gambit. fluentMeshToFoam works. but I do not know the reason with my gambit?
Have a nice day
Old   August 25, 2013, 05:49
Bruno Santos
Have you tried fluent3DMeshToFoam? Here's a thread on this topic: fluent3DMeshToFoam
Old   August 25, 2013, 21:44
Post
  #77
胡长旭
Hi
yes, I also use fluent3DToFoam, and the same errpr appears. by the way, my mesh is 2D. I think my mesh has some questions. Can you tell me, what should i do when writing my mesh with gambit tool.
Thank you very much. Have a nice day.
Old   August 26, 2013, 00:50
-mAx-'s Avatar
Maxime Perelli
you cannot work with 2d in OF.
In Gambit extrude your 2d geometry, and export the 3d mesh in OF with fluent3DMeshToFoam
For the BC, check for instance airFoil2D (incompressible/simpleFoam)
Old   August 26, 2013, 03:47
胡长旭
Hi Max.Thanks for your reply.
firstly, I creat a 2D mesh in the gambit.(choose the solver:Fluent 5/6)
secondly, use the fluent3DMeshToFoam to transfer my mesh.
Is it right?
or
firstly, I must creat 3D mesh in the gambit.(choose the solver :Fluent 5/6)
Which step is right? Thank you!
Have a nice day!
Old   August 26, 2013, 03:52
sonu
yash.aesi is on a distinguished road
helo ,
your case is 2D or 3D ?? if it is 2D then why you are giving command fluent3DMeshToFoam when you have created 2D mesh in gambit ...? try with fluentMeshToFoam
hope it will work
yash.aesi is offline   Reply With Quote
Thread Tools
Trackbacks are On
OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 electrosin OpenFOAM Installation 40 May 31, 2016 05:11
GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM 300 October 29, 2014 19:00
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 09:33
Version 15 on Mac OS X gschaider OpenFOAM Installation 120 December 2, 2009 11:23
Import gmsh msh to Foam adorean Open Source Meshers: Gmsh, Netgen, CGNS, ... 24 April 27, 2005 08:19
