[Commercial meshers] converting Fluent mesh to openfoam standard mesh |
February 17, 2012, 15:18 |
deepesh
Rep Power: 15 |
Dear All
I tried to convert the Fluent and Gambit mesh to the openfoam mesh using the standard command gambitToFoam mesh.msh fluentMeshToFoam mesh.msh in both the cases, I got the following error .................................................. ............ /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-0bc225064152 Exec : gambitToFoam car.msh Date : Feb 17 2012 Time : 19:08:08 Host : "ubuntu" PID : 16704 Case : /root/OpenFOAM/FOAM_RUN/Derby_calc/car_calc/constant/polymesh nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL IO ERROR: cannot find file file: /root/OpenFOAM/FOAM_RUN/Derby_calc/car_calc/constant/polymesh/system/controlDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting .................................................. ...... Any idea please? Thanks in advance -Deepesh |
February 17, 2012, 15:25 |
deepesh
Rep Power: 15 |
Do we ideally need to have controlDict to convert?
February 17, 2012, 15:48 |
Marco A. Turcios
Rep Power: 28 |
You should run the command from the case root, i.e., the folder where the constant, and system directories are. You'll still need to specify the filenames of your source meshes. You may run into other problems later, but the error you are experiencing is related to where the command should be executed. In general, all OF commands are run from the root of the case directory.
Its always a good idea to run a command with --help if you are having trouble figuring out all the options and arguments. |
February 17, 2012, 17:02 |
Indeed! Great advice.
Also, when converting .msh files I have good experiences with fluent3DMeshToFoam. I don't think gambitToFoam will do the trick. |
February 18, 2012, 03:26 |
Florian
Rep Power: 15 |
hi deepesh,
like mturcios777 wrote, you have to run the command in the case folder. For example for a grid "pipe.msh" go to the folder "/Pipe" and give the commands: fluentMeshToFoam pipe.msh -writeSets -writeZones // this command convert the msh-file into OF transformPoints "(0.001 0.001 0.001)" //with this command you convert your mesh from meter into mm then you have to adapt the boundarys to the new mesh. For example if you signify the inlet boundary in Gambit with the name inflow1. Then you have to change all the files in the folder /0 (U,p ...). for example for U: ... boundaryField { wall { type fixedValue; value uniform (0 0 0); } inflow1 { type fixedValue; value uniform (1 0 0); } outlet { type zeroGradient; } Then it should work. kind regards Florian |
February 18, 2012, 04:25 |
Again some great advice!
One last comment: if the scaling from m to mm is uniform in all directions, you can also add: "- scale 0.001" to the fluentMeshToFoam command.
Dr. Ries Bouwman Business Development ESI Group 004369917171525 @riesbouwman |
February 18, 2012, 05:14 |
Be it that Ries is your last name and mine is my first... :-)
February 18, 2012, 07:15 |
#9 |
deepesh
Rep Power: 15 |
Dear all,
Thanks a lot for your help. Valuable suggestions indeed.. the presence of the file 'controlDict' is inevitable to have the mesh conversion command worked and as you pointed out, it does matter where u run the command from. The -help option while executing a command is really worthwhile. |
February 19, 2012, 14:22 |
#10 |
So you got to solve the issue?
February 19, 2012, 14:37 |
#11 |
deepesh
Rep Power: 15 |
Indeed! thankyou
March 13, 2012, 06:38 |
Problem converting Fluent mesh generated by AnsysWorkbenchV14 to OpenFoam
#12 |
Zinedine
Rep Power: 15 |
I have been reading with great interest the various issues regarding converting Fuent mesh to OpenFoam. It seems that I am encountering a problem while attempting converting a mesh generated by Anasys Workbench V14 to OpenFoam. I have been trying the various tools with no success. Here is an output from: Code:
fluentMeshToFoam Pipe.msh -writeSets -writeZones -scale 0.001 /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.1-03e7e056c215 Exec : fluentMeshToFoam Pipe.msh -writeSets -writeZones -scale 0.001 Date : Mar 12 2012 Time : 11:02:09 Host : abax2.leeds.ac.uk PID : 28809 Case : /home/abax2_a/menzk/OpenFOAM/menzk-1.7.1/run/GT_valve nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Found unknown block4 Embedded blocks in comment or unknown: ( Found end of section in unknown Found end of section in unknown Embedded blocks in comment or unknown: ( Embedded blocks in comment or unknown Found end of section in unknown Embedded blocks in comment or unknown Found end of section in unknown Found end of section in unknown Embedded blocks in comment or unknown: ( Embedded blocks in comment or unknown Found end of section in unknown Embedded blocks in comment or unknown: ( Found end of section in unknown Found end of section in unknown Embedded blocks in comment or unknown: ( Embedded blocks in comment or unknown Found end of section in unknown Found end of section in unknown Embedded blocks in comment or unknown: ( Embedded blocks in comment or unknown Found end of section in unknown Embedded blocks in comment or unknown Found end of section in unknown Found end of section in unknown Dimension of grid: 3 Number of points: 521922 number of faces: 5820580 Number of cells: 2867149 Found unknown block3010 Embedded blocks in comment or unknown: ( Found end of section in unknown (Embedded blocks in comment or unknown:¿ Embedded blocks in comment or unknown:à |'Embedded blocks in comment or unknown:¿ ÛFound end of section in unknown:? Found end of section in unknown:? Embedded blocks in comment or unknown:¦ Found end of section in unknown:? Found end of section in unknown:? Embedded blocks in comment or unknown: % Embedded blocks in comment or unknown:à Found end of section in unknown:¿ Found end of section in unknown:? Embedded blocks in comment or unknown:½ Found end of section in unknown:¿ Embedded blocks in comment or unknown:× ü§ÛEmbedded blocks in comment or unknown:ë Found end of section in unknown:¦ Embedded blocks in comment or unknown:ª Found end of section in unknown:© `ÝEmbedded blocks in comment or unknown:Î Embedded blocks in comment or unknown:ª Embedded blocks in comment or unknownã Embedded blocks in comment or unknown:ª ÝEmbedded blocks in comment or unknown:¿ Found end of section in unknown:nÏO¢?_ Embedded blocks in comment or unknown:Ñ àFound end of section in unknown:? Embedded blocks in comment or unknown:Ò Embedded blocks in comment or unknown:Ä Found end of section in unknown:? Found end of section in unknown:? ýEmbedded blocks in comment or unknown:¿ Found end of section in unknown:îë¹²?J_ Found end of section in unknown:¡ Embedded blocks in comment or unknown:Ç Found end of section in unknown:? Embedded blocks in comment or unknown:\¿ ©©Embedded blocks in comment or unknown:Ð ©Found end of section in unknown:¿ Found end of section in unknown:! Embedded blocks in comment or unknown:Á ,Found end of section in unknown:> \Found end of section in unknown:? Embedded blocks in comment or unknown:[¯ Embedded blocks in comment or unknown:¿ Embedded blocks in comment or unknown:¢ Embedded blocks in comment or unknown:ñ Found end of section in unknown:¾ Embedded blocks in comment or unknown:ò Embedded blocks in comment or unknown:ä ;Found end of section in unknown:! Embedded blocks in comment or unknown:{Á Found end of section in unknown:) Found end of section in unknown:) ÝFound end of section in unknown:? ýFound end of section in unknown:< Embedded blocks in comment or unknown:»¿ ]Embedded blocks in comment or unknown:{ª Found end of section in unknown:¿ Found end of section in unknown:¼ Found end of section in unknown:© ,Embedded blocks in comment or unknown:( Embedded blocks in comment or unknown:]¡ Found end of section in unknown:¿ Found end of section in unknown:© Embedded blocks in comment or unknown:¾ ÜFound end of section in unknown:? ÀEmbedded blocks in comment or unknown:¤ Found end of section in unknown:¿ Embedded blocks in comment or unknown:Å Embedded blocks in comment or unknown:Ê Found end of section in unknown:¿ Embedded blocks in comment or unknown:Xø Embedded blocks in comment or unknown:¿ Embedded blocks in comment or unknown:Ç Embedded blocks in comment or unknown:¦ ©Found end of section in unknown:¿ Embedded blocks in comment or unknown:Ö Found end of section in unknown:) Found end of section in unknown:* @;Embedded blocks in comment or unknown:`Ä Found end of section in unknown:© Embedded blocks in comment or unknown:¿ ){)Found end of section in unknown:¦ Embedded blocks in comment or unknown:¬¿ ÀEmbedded blocks in comment or unknown:ÜÆ Embedded blocks in comment or unknown:¬¿ Embedded blocks in comment or unknown:á Embedded blocks in comment or unknown:¬Ó Found end of section in unknown:¿ Found end of section in unknown:¼ Embedded blocks in comment or unknown:»¦ ÿFound end of section in unknown:% Found end of section in unknown:ª Found end of section in unknown:¥ àEmbedded blocks in comment or unknown:¨ Found end of section in unknown:? Found end of section in unknown:? |Found end of section in unknown:= Û·û&Embedded blocks in comment or unknown:¿ Found end of section in unknown:¡ øG* ? imension of grid: 2 Embedded blocks in comment or unknown:¿ §{Embedded blocks in comment or unknown:¬¿ Embedded blocks in comment or unknown:Å Embedded blocks in comment or unknown: ¯ Embedded blocks in comment or unknown:( Embedded blocks in comment or unknown:¿ Embedded blocks in comment or unknown:üÓ Embedded blocks in comment or unknown:¨ ÿFound end of section in unknown:? »\¬ÿ`Found end of section in unknown:" Found end of section in unknown:¤ Embedded blocks in comment or unknown:Ô Found end of section in unknown:? »ÝàEmbedded blocks in comment or unknown:ܺ Embedded blocks in comment or unknown:¨ Found end of section in unknown:¡ Embedded blocks in comment or unknown:@è Embedded blocks in comment or unknown:¿ Found end of section in unknown:? +Found end of section in unknown:< 'Embedded blocks in comment or unknown:|ò Found end of section in unknown:? {{`Found end of section in unknown:n÷ì½?±:_ ÝFound end of section in unknown:> Found end of section in unknown:# Found end of section in unknown:? Found end of section in unknown:© TP Embedded blocks in comment or unknown:Í Embedded blocks in comment or unknown:¿ \Embedded blocks in comment or unknown:Ó Embedded blocks in comment or unknown:¨ Found end of section in unknown:? ©Embedded blocks in comment or unknown:Ñ Found end of section in unknown:) Embedded blocks in comment or unknown:Ö Embedded blocks in comment or unknown:Ï Found end of section in unknown:? Found end of section in unknown:¾ ¬ Embedded blocks in comment or unknown:ª {Embedded blocks in comment or unknown:Ù Found end of section in unknown:¿ Embedded blocks in comment or unknown:|ù «Embedded blocks in comment or unknown:¿ Embedded blocks in comment or unknown:ÿã ÀFound end of section in unknown:© Found end of section in unknown:? Found end of section in unknown:) \Found end of section in unknown:! Embedded blocks in comment or unknown:; Embedded blocks in comment or unknown:Ì Found end of section in unknown:s?ß Embedded blocks in comment or unknown:,ë Found end of section in unknown:¼ Found end of section in unknown:¢ \Embedded blocks in comment or unknown:|Þ §Found end of section in unknown:? Embedded blocks in comment or unknown:¨ Embedded blocks in comment or unknown:ç Found end of section in unknown:¥ Embedded blocks in comment or unknown:ö Found end of section in unknown:? Embedded blocks in comment or unknown:@Ì Found end of section in unknown:¿ Embedded blocks in comment or unknown:üë Embedded blocks in comment or unknown:¿ )Embedded blocks in comment or unknownö ÿ§Found end of section in unknown:/ Found end of section in unknown:^ Found end of section in unknown:> Embedded blocks in comment or unknown:¢ Found end of section in unknown:¿ Embedded blocks in comment or unknown:¬¿ Found end of section in unknown:* Embedded blocks in comment or unknown:È àEmbedded blocks in comment or unknown:¨ Found end of section in unknown:? Found end of section in unknown:¿ »{Embedded blocks in comment or unknown:Æ Embedded blocks in comment or unknown:¿ §Found end of section in unknown:? ÀFound end of section in unknown:? Found end of section in unknown:? Û;Embedded blocks in comment or unknown:Ì Found end of section in unknown:? ®=w*Embedded blocks in comment or unknown:'½ Embedded blocks in comment or unknown:[ø Found end of section in unknown:Þ --> FOAM FATAL IO ERROR: wrong token type - expected int found on line 0 the word '±' file: IStringStream.sourceFile at line 0. From function operator>>(Istream&, int&) in file primitives/ints/int/intIO.C at line 68. FOAM exiting Regards Z. Last edited by wyldckat; August 16, 2013 at 12:45. Reason: Added [CODE][/CODE] |
October 23, 2013, 10:17 |
#13 |
Ivy
Rep Power: 12 |
Hi, I used "fluentMeshToFoam" to convert .msh file to OpenFoam on Mac System. I ran the .msh file and the command under the root directory, where system and constant exit. I created my own constant, system, 0, polyMesh,controlDict, fvSchemes, fvSolution too.
However, I still get this Error /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.1-57f3c3617a2d Exec : fluentMeshToFoam Test11a.msh Date : Oct 23 2013 Time : 21:15:25 Host : "Precision-T7600" PID : 30325 Case : /home/yinghan/case/constant/polyMesh nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL IO ERROR: cannot find file file: /home/yinghan/case/constant/polyMesh/system/controlDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting Can anyone help me ? Thanks very much Ivy |
October 23, 2013, 10:32 |
#14 |
Bernhard
Rep Power: 21 |
Did you even read the topic?
October 23, 2013, 10:36 |
#15 |
Ivy
Rep Power: 12 |
Hmmm I read about how to convert fluent msh to openfoam. Or I still didn't get what it is really about? U have any recommended reading? Thanks. Ivy |
October 23, 2013, 10:39 |
#16 |
Bernhard
Rep Power: 21 |
I would advise you to read this topic
You have literally the very same error message as in the first post above. Please, read carefully the post by mturcios777 |
October 23, 2013, 10:48 |
#17 |
Ivy
Rep Power: 12 |
Hi, I did read the post by mturcios777. I typed the command "fluentMeshToFoam" under the root of case directory as I stated ealier That's why I got confused why I still get this error
I followed instruction from this here: http://openfoamwiki.net/index.php/Fluent3DMeshToFoam ivy@Precision-T7600:~/Beispiel$ ls 0 Allclean Allrun case0.cas constant system ivy@Precision-T7600:~/Beispiel$ fluentMeshToFoam case0.msh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.1-57f3c3617a2d Exec : fluentMeshToFoam case0.msh Date : Oct 23 2013 Time : 21:42:56 Host : "Precision-T7600" PID : 31729 Case : /home/yinghan/Beispiel nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From function IOobject::readHeader(Istream&) in file db/IOobject/IOobjectReadHeader.C at line 89 Reading "/home/yinghan/Beispiel/system/controlDict" at line 1 First token could not be read or is not the keyword 'FoamFile' Check header is of the form: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // --> FOAM FATAL IO ERROR: problem while reading header for object controlDict file: /home/yinghan/Beispiel/system/controlDict at line 1. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 95. FOAM exiting Regards, Ivy |
October 25, 2013, 04:59 |
#18 |
Samuele Z
Rep Power: 18 |
Dear All,
pardon the interruption, but I have a question for you. I have a 2D Ansys mesh (.msh). And it is an axi-symmetric geometry. What I wanna do is to convert it in OpenFOAM. As soon as I did this, I get a 2D mesh (in the sense of OpenFOAM, which means a slice with a single cell in 3rd direction). How can I tell OpenFOAM that it is an axi-symmetric case? Any idea? Thanks a lot, Samuele. |
May 23, 2016, 12:50 |
#19 |
Rep Power: 10 |
Hey,
I have a question regarding the fluentMeshToFoam command. My geometry is in mm and I've created the mesh in ICEM. Now after doing fluentMeshToFoam pipe.msh I do checkMesh. Now, checkMesh gives the dimensions of the overall bounding box without the units. Are these units in mm since my geometry is in mm? or if I want to convert it into mm should I do transformPoints -scale '(0.001 0.001 0.00)'? Thanks!! Ram |
May 23, 2016, 13:01 |
#20 |
Zinedine
Rep Power: 15 |
Hi Ram
What is the output of checkMesh? Depending in this you might have to us the transformation transformPoint - scale etc ... Hope this helps. Zinedine |
Display Modes | |
[Other] OpenFoam Mesh to Fluent Mesh, 2D | lordvon | ANSYS Meshing & Geometry | 1 | January 14, 2022 13:20 |
Fluent converting 'wall' to 'interior' BC for hybrid mesh | DarrenC | FLUENT | 8 | January 3, 2019 07:24 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[CAD formats] Converting .gtm mesh for use in OpenFOAM | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 0 | December 20, 2012 18:17 |
