-   OpenFOAM Native Meshers: snappyHexMesh and Others (http://www.cfd-online.com/Forums/openfoam-meshing-snappyhexmesh/)
-   -   defining boundary condition in SHM (http://www.cfd-online.com/Forums/openfoam-meshing-snappyhexmesh/100348-defining-boundary-condition-shm.html)
mihaipruna April 24, 2012 10:02
I tried this, but, after meshing, looking in the boundary file it generated, all the STL patches are walls!
SHM:
sduct.stl
type triSurfaceMesh;
name sduct;
regions
Sductface1
name Sductface1;
type wall;
Sductface2
name Sductface2;
type wall;
SDuctInlet
name SDuctInlet;
type patch;
SDuctOutlet
name SDuctOutlet;
type patch;
Boundaries:
Sductface1
type wall;
nFaces 139535;
startFace 2352772;
Sductface2
type wall;
nFaces 13938;
startFace 2492307;
SDuctInlet
type wall;
nFaces 13938;
startFace 2506245;
SDuctOutlet
type wall;
nFaces 136863;
startFace 2520183;
mihaipruna April 24, 2012 12:06
assuming my time 0 BCs are defined properly, does this even matter for simpleFoam to define the inlet as an inlet and the outlet as an outrlet,etc?
kid April 25, 2012 04:39
Yes it does.
But you can overcome this "wall" by editing 0/u p adn all ... for -type "wall" to the one you want them to be like patch,empty,fixedValue; etc.
Also you will be required to edit /constant/polyMesh/ boundary file for same i.e for stl walls where ever you need different type , name it accordingly. Remember few will still be type wall.
Also point to be noted here is , this editing has to be done after meshing.
Note: It is just nature of problem one is solving. In your case some internal flow might be taking place . Generally for outer flow less or no editing is required. ( only my guess)
mihaipruna April 25, 2012 13:33
hmm so far from the tests I did it seems inlets and outlets are overridden by setting the BCs.
