Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
Mesh around ship with appropriate free surface refinement
Like Tree14Likes
Old   November 22, 2013, 12:44
Hannes
Hannes_Kiel is on a distinguished road
Hi Vince,
from the description in the paper, there is actually quite a bit of in-house code involved.
- MHRIC: Basically, this is a variant of the HRIC scheme by Muzaferija (sp.?) & Peric, designed to have compressive properties within the convective transport of the VoF-scalar. The formulae can be found in another paper from the workshop: "Numerical simulation of wave induced
motion of a floating body". From my experience it is supposed to omit the Courant-no. dependency of the HRIC scheme, albeit at the cost of robustness. I'm actually pretty happy with the standard HRIC. For the implementation of those more complex div-schemes take a look at the naval-foam package in the extend repository.
- DFBI: The way it looks to me it is not Dynamic Fluid Body Interaction the way it is meant in Star-CCM (implicit or strong coupling of flow and body motion, see PhD-Thesis by Yan Xing-Kaeding, TUHH) but a quasi-static update of the position every 200 iterations. In the standart implementation of LTSInterFoam, to the best of my knowledge, body motion is not intended.
Hope this helps.
Hannes
FluidEngineeringSolutions
Hannes_Kiel is offline   Reply With Quote
Old   August 21, 2014, 04:16
Albrecht vBoetticher
vonboett is on a distinguished road
I would like to add something with respect to multiple refinement steps by calling snappyHexMesh (with castellatedMesh true) and refineMesh several times: To my experience, one runs into trouble if the cells you want to refine do not lie inside or outside of the cellSets or regions that were refined in prior steps. If the actual cellSet (or refinementRegions etc.) includes those cells that form the transition between a coarser and a finer grid resolution, one ends up with mesh errors. Mayby this can help someone to understand success and failure of repeting refineMesh or snappyHexMesh steps.
Hannes_Kiel and Gio Baila like this.
vonboett is offline   Reply With Quote
Old   August 22, 2014, 03:17
Hannes
I totally agree. As a remedy, the cells to be refined can not only be defined by region, but by cell level (or volume) as well.
Old   March 31, 2015, 06:33
Default Trim to the hull (Positioning the geometry in the Mesh)
  #44
Sachin
Sachin m is on a distinguished road
Has anyone tried simulation of a vessel with a trim.??
I would like to simulate a ship with a trim of 7 degrees. Is there anyone who can help me out with this?
Sachin m is offline   Reply With Quote
Old   March 31, 2015, 06:35
Hannes
Hi Sachin,
I'd suggest you transform the geometry prior to meshing, e.g. by using surfaceTransformPoints.
Best Regards,
Hannes
Old   April 2, 2015, 02:29
Sachin
Thanks for the reply hannes
refinement, ship wave, shm, snappyhexmesh
Thread Tools
Trackbacks are On
snappyHexMesh not refining surfaces Hydro1004 OpenFOAM 3 August 29, 2012 11:56
free surface around a ship hull Stephy OpenFOAM Running, Solving & CFD 12 April 24, 2012 01:12
Boundary layer in a pipe Clementhuon OpenFOAM Native Meshers: snappyHexMesh and Others 6 March 12, 2012 13:41
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
