[snappyHexMesh] Mesh around ship with appropriate free surface refinement |
June 4, 2012, 15:43 |
Hannes
Rep Power: 17 |
I'm looking for a way to generate a mesh around a ship with the "typical" refinement of the free surface region to capture the waves. Basically, what I intend to do is following: - start with a base grid (from BlockMesh) with identical cells of aspect ratio approx. 1 - in SHM: - refine near hull and appendages as usual by isotropic splitting of cells (1 -> 8) - refine the free surface further away from ship mostly normal to the initial waterplane (anisotropically) as the waves are expected to be significantly longer than high (I don't want to waste cells, isotropic refinement of larger regions significantly pushes cell count) - snap to hull and appendages - create inflation layers for boundary layer The difficulty is the anisotropic refinement of the free surface region. In Hexpress or Star-CCM+ mesher I can define either isotropic or anisotropic refinement for a region. In SHM, as far as I understand it, only isotropic refinement is possible in the Dict and the hex8 class referenced by SHM (although the refineMesh utility has anisotropic refinement). Does anyone have a solution to this problem, either by a modification to SHM or a specific workflow? Thanks Hannes |
June 7, 2012, 15:27 |
Vieri Abolaffio
Rep Power: 16 |
Hi Hannes.
what i do is to mesh everything isotropically in sHM, snap, add the layers and than refine the freesurface using the setSet to select the freesurface area and refineMesh to refine anisotropiacally (just in the z direction). good results so far... |
June 8, 2012, 02:41 |
Hannes
Rep Power: 17 |
Hi Vieri,
thank You for the explanation. I'll try that way as well as one described in a paper I just found: http://www.tfd.chalmers.se/~hani/kurser/OS_CFD/ChristofferJarpner/ReportInOpenFOAMbyChristofferJarpner.pdf Nice website, by the way. Cheers, Hannes |
June 25, 2012, 17:14 |
Rafael Coelho
Rep Power: 13 |
Hi Hannes,
It seems that the link is not working anymore. Could you please forward me the file? Thank you! |
June 26, 2012, 02:47 |
Hannes
Rep Power: 17 |
PM me your Email.
Hannes |
June 26, 2012, 02:51 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
For the sake of future reference, the link was sent back to the historic side (2011) of the course : http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2011/ChristofferJarpner/ReportInOpenFOAMbyChristofferJarpner.pdf Best regards, Bruno
June 27, 2012, 02:28 |
pdf
Rafael Coelho
Rep Power: 13 |
Thank you very much Bruno.
Obrigado! |
November 19, 2012, 19:47 |
laurentL
Rep Power: 14 |
hi all,
i am dealing with same problem, if i refineMesh (in dirZ) before SHM, shm doesn t do layers to good, and split a lot of cells at the junction of free surface and hull. but if i do shm them refineMesh it create files in the case directory a lot of cells, loops, anchors .obj ... and the solver fail because of negative alpha1... any subjection ? |
April 25, 2013, 01:38 |
#9 |
laurentL
Rep Power: 14 |
dear Foamers,
i have made some little progress, i refine the free surface with toposet and refineMesh but when i run snappyhexmesh it's refine to much the cells around the hull selected with toposet... do i need to make my own mysnappyHexmeh to obtain a good mesh.? should i make two mesh and stich them? going trought the paper of Christoffer Jarpner look very interesting but a bit hard isn't it??? thanks for helping LL |
April 25, 2013, 02:31 |
#10 |
Rep Power: 18 |
Hi laurent98,
I'm not sure how much you are familiar with sHM, but from what you wrote two options come to my mind that could help you * you switch the order of your process: first run sHM and then run topoSet and refineMesh * limit the number of cells with the keyword maxGlobalCells in the sHMD I hope I got your question right if not let me know. regards |
April 25, 2013, 06:34 |
#11 |
laurentL
Rep Power: 14 |
Hi Colin,
thank you for reply. To answer your question, I play with openfoam during my free time, and use finemarine of numeca at work since a year... so I still have a lot to learn... I did as you suggest shm then refinemesh, the domain set in toposetDict is like a U around a refining box. as you can see I ve got a gap between hull and the limit of the box. Of course I will have to adjust the shmD to have the same size in Z between box and freesurface, but because of diffusion, refineMesh will always refine more cells around the box... also refinemesh in z direction only make some strange cells around, like cube inside cube.. see the slice image cut.jpg so, I am thinking of making two different mesh one for the freesurface, and one for a small box around the hull, is there something better ? I will be happy with a mesh like the one http://www.youtube.com/watch?v=_j-zT...eature=related best regards LL |
April 25, 2013, 08:28 |
#12 |
Rep Power: 18 |
Hi LL
from the video I think I could see what kind of mesh you want but let me summarize in my own words to see whether I grasp what you want: You want to have the mesh refined around the ship hull, rather dense in order to resolve e.g the boundary layer, which you basically want to achieve with sHM However in the area of the free surface you want to refine the mesh as well especially in z direction to better capture the wave elevation. If this is so my suggestion would be: - create a coarse background mesh with blockMesh - use snappyHexMesh only to mesh the surface and use refinementMode distance and add layers - then use topoSet with a box refinement in order to refine the free surface I hope I got your idea right. However the above mentioned way provides good results for me. If I didn't get your idea you might want to provide some sketches which illustrate your problem and a sHMD as well. regards Colin |
April 26, 2013, 02:06 |
#13 |
laurentL
Rep Power: 14 |
hi Colin,
you've got exactly right my ideas i did as you said, and trying my best to match the box limit bettewen the hull refinement and the FreeSurface Z refinement. good idea to use distance, i never used that option before... but because i have a cell (nCellsBetweenLevels 1) in the FS refinement place, it make undesired splits cells as you see on the picture. is there a equivalent of nCellsBetweenLevels 0 .?? thanks you again for helping LL |
April 26, 2013, 02:22 |
#14 |
Rep Power: 18 |
So you are trying to adjust the blocks directly to the refinement
which you are getting from snappyHexMesh? Well the solution to this is simply defining a box which also includes the ship even if there is no more mesh (inside of the ship) If you want to have more refinement in certain areas you have to define several boxes which are overlapping. Did you get my idea? So don't worry about boundaries but simply use overlapping refinement areas. |
April 26, 2013, 02:59 |
#15 |
laurentL
Rep Power: 14 |
i think it is what i am doing with the 'box1' i attach some of my files if you have time to look at it, i think you will better understand , of course all advice will be very welcome!
regards LL |
April 28, 2013, 08:54 |
#16 |
laurentL
Rep Power: 14 |
hello
after a week-end playing with blockmesh, createpatch, mergemesh stitchmeshes, i am nearly there... still some inside patch to get rid off . mergeOrSplitBaffles ..??? |
April 28, 2013, 10:03 |
#17 |
Hannes
Rep Power: 17 |
I'm getting quite good meshes using blockMesh, sHM, topoSet and refineMesh by now (in OF2.2.x). I start with an isotropic grid for the entire domain with a split exactly on the designated waterline (approx. 10e4 cells). Then I refine isotropically around the ship and at the waterline, especially in the Kelvin angle region (sHM), followed by snapping and layer insertion. Last I split normal to the waterplane only in the region of the expected wave height.
FluidEngineeringSolutions |
May 29, 2013, 03:11 |
#18 |
Rep Power: 15 |
Dear all,
I'm keenly interested in the described use of SHM and refineMesh and I've read your previous posts. I still have trouble in refining the free surface region. My procedure is: 1. run blockMesh 2. run SHM (setting castellated, snap, layers as true) 3. run topoSet to select a box to be refined 4. run refineMesh over the selected box and refining just in normal direction It's not clear to me if I have to run repeatedly topoSet and refineMesh, adapting every step the box to be refined in topoSet, because the refineMesh can split just one initial cell into two (in normal direction). Is this the only way or a smarter procedure exist? Any suggestions (also about my workflow) is really appreciated! Thanks for youe support, Best regards. Andrea |
May 29, 2013, 06:36 |
#19 | |
Vieri Abolaffio
Rep Power: 16 |
1. run blockMesh 2. run SHM (setting castellated as true and snap, layers false) 3. run topoSet to select a box to be refined 4. run refineMesh over the selected box and refining just in normal direction 2. run SHM (setting castellated as false and snap, layers true) if you need more than one anisotropic refinement you will need to rerun toposet and refinemesh more than one time. best Regards, V. |
May 29, 2013, 12:14 |
#20 |
Rep Power: 15 |
Hi Vieri,
thanks for your reply. I've tried the procedure you suggested, but still troubles remain. Using the following procedure: 1. blockMesh 2. SHM (setting castellated as true, snap false, layers false) 3. topoSet 4. refineMesh ( till now checkMesh is very good !! ) 5. SHM (setting castellated as false, snap true, layers true) I was hoping this would work fine, but the following error was reported: --> FOAM FATAL ERROR: Number of cells in mesh:1948200 does not equal size of cellLevel:918205 This might be because of a restart with inconsistent cellLevel. It seems that the 0/cellLevel file has not be updated after the refineMesh phase. How did you manage this problem, if it happened to you in the past? Thanks in advance, best regards. Andrea |
refinement, ship wave, shm, snappyhexmesh |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] Snappy Hex Mesh - issue with smoothness of the model edges | olek.warc | OpenFOAM Meshing & Mesh Conversion | 1 | August 31, 2018 11:31 |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 11:27 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
