Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
Problem with cell removal in SHM
Old   June 21, 2012, 08:16
Default Problem with cell removal in SHM
Bercht is on a distinguished road
Iam trying to create a mesh for an internal flow with SHM. Everything i tried ended up with the refined background mesh but with no removed cells. I tried different stl's because i wasnt sure if they might have holes.
After that i found this tutorial:
http://www.hydroniumion.de/general/s...mesh-tutorial/
I took his .stl file and tried to run SHM again with the same result:
Removing mesh beyond surface intersections
Found point (0.3 0.3 -0.08) in cell 58028 in global region 0 out of 1 regions.
Keeping all cells in region 0 containing point (0.3 0.3 -0.08)
Selected for keeping : 127807 cells.
Edge intersection testing:
    Number of edges             : 392133
    Number of edges to retest   : 0
    Number of intersected edges : 1063
My snappyHexMeshDict looks like that:
| \\      /  F ield        | OpenFOAM: The Open Source CFD Toolbox          |
|  \\    /  O peration    | Version:  1.6                                  |
|  \\  /    A nd          | Web:      http://www.openfoam.org                |
|    \\/    M anipulation  |                                                |
FoamFile
    version        2.0;
    format          ascii;
    root            "/home/penfold/mattijs/foam/mattijs2.1/run/icoFoam";
    case            "cavity";
    instance        "system";
    local          "";
    class          dictionary;
    object          autoHexMeshDict;
castellatedMesh true;
snap            true;
addLayers      true;
mergeTolerance 1e-06;
geometry
    wigley.stl
        type triSurfaceMesh;
        name Ofen;
    refinementBox
        type searchableBox;
        min (-10000 -1000 -10000);
        max (10000 11000 10000);
castellatedMeshControls
    maxLocalCells 1000000;
    maxGlobalCells 5000000;
    minRefinementCells 1;
    nCellsBetweenLevels 2;
    features
    allowFreeStandingZoneFaces true;
    curvature       0.9925;
    maxLoadUnbalance 0.01;
    resolveFeatureAngle 30;
    refinementSurfaces
        "Ofen_*"
            level (1 2);
    faceZone Ofen;
            cellZone Ofen;
            zoneInside true;
    refinementRegions
    locationInMesh (0.3 0.3 -0.08);
snapControls
    nSmoothPatch 3;
    tolerance 4.0;
    nSolveIter 30;
    nRelaxIter 5;
addLayersControls
    relativeSizes true;
    layers
//flowAirDuctReagent_flowAirDuctReagent
        //    nSurfaceLayers 1;
//flowAirDuctReagent_inlet1
//flowAirDuctReagent_inlet2
    expansionRatio 1.0;
    finalLayerThickness 0.3;
    minThickness 0.1;
    nGrow 0;
    featureAngle 30;
    nRelaxIter 3;
    nLayerIter 50;
    nSmoothSurfaceNormals 1;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    minMedianAxisAngle 130;
    nBufferCellsNoExtrude 0;
meshQualityControls
    maxNonOrtho 65;
    maxBoundarySkewness 20;
    maxInternalSkewness 4;
    maxConcave 80;
    minFlatness 0.5;
    minVol 0;
    minArea -1;
    minTwist 0.02;
    minDeterminant 0.001;
    minFaceWeight 0.02;
    minVolRatio 0.01;
    minTriangleTwist -1;
    nSmoothScale 4;
    errorReduction 0.75;
    minTetQuality 1;
What is wrong with my Dict file? Iam wondering because the defined locationInMesh Vector points to an existing cell (58028) but doesnt remove any cells.
Hope you can help me.
Bercht is offline   Reply With Quote
Old   June 21, 2012, 20:05
Doug68 is on a distinguished road
A silly question but I made this mistake myself...
Is "Ofen" the name of the solid in the STL file?
Assuming its an ascii STL file this should be in the top line of the file.
Doug68 is offline   Reply With Quote
Old   June 21, 2012, 22:31
Also... by looking at:
refinementBox
type searchableBox;
I'm guess you think that this is in mm? I found out the hard way the units quoted are m, if the STL file is in mm then it may be way bigger than the blockmesh volume hence no cells are removed.
An easy test for this is to open the mesh in parafoam then open the stl file at the same time and see if it is inside the mesh or not.
Old   June 22, 2012, 04:30
Thank you so much... it works now. Yes, I thought that it is in mm. But i created my stl with Gmsh entering "mm" aswell so this is ok
Old   June 22, 2012, 06:20
Now i have another problem. I created the stl with gmsh in which i can define physical groups which i can use as boundaries in OF. But am I right that i cant export those groups with an stl file made by Gmsh? Is it possible with another freeware software like Gmsh?
Old   June 22, 2012, 08:34
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
You could just export every region to a different ASCII stl file then open them with a text editor and append them all in an empty file which you'll then save as a .stl
lovecraft22 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Problem / Misunderstanding with mesh.C() : get the cell centers Edy OpenFOAM Programming & Development 18 June 23, 2016 06:13
Cell Reynolds Number laliong Main CFD Forum 11 March 19, 2015 12:42
Ejector for hydrogen fuel cell problem goami FLUENT 0 December 29, 2011 14:23
CHT cell layer thickness problem Arnab CD-adapco 1 March 13, 2005 09:36
Baffle cell problem in shock tube AB CD-adapco 4 November 15, 2004 09:44
