[CAD formats] Stl not recognized by decomposePar
Old   December 3, 2011, 20:24
Default Stl not recognized by decomposePar
Kalyan
kalyangoparaju is on a distinguished road
Guys,
I have an stl file in the trisurface directory and used snappy in parallel to mesh the geometry. The meshing happens flawlessly but surprisingly, when i do the decomposePar (before meshing) command to generate the files for all the processors, the boundary conditions folder ( 0) which is transfered into all the processor directories doesn't contain the stl patch !!!
In order to check if the problem is with my problem setup, i ran snappy in series and then decomposed the mesh. In this case, I didn't have the problem and the solver runs perfectly.
Did any one else face the problem? Is there a solution for this problem?
Thanks,
Kalyan Goparaju
kalyangoparaju is offline   Reply With Quote
Old   May 23, 2012, 01:33
Default How to run SnappyhexMesh in parallel
Shailesh Kumar Gupta
shailesh.nitk is on a distinguished road
I can run SnappyHexMesh in serial. I would like to know how to run snappyHexMesh in parallel.
I have gone through the docs http://www.openfoam.org/docs/user/ru...s-parallel.php. If I have mesh that can be broken broken into pieces and allocated to separate processors for solution using with decomposePar then we can run mpi to solve the solution.
If I want to generate SnappyHexMesh in parallel. Could you please tell me What steps I need to follow.
Best regards,
Shailesh
shailesh.nitk is offline   Reply With Quote
Old   July 23, 2012, 07:57
Kalyan
Shailesh,
I am sorry for the late reply.
Running snappy in parallel is exactly the same as running any other solver in parallel. You need to have the decomposeParDict which has the information regarding the number of processors and then run the snappyHexMesh cnommand in parallel using mpirun or foamJob, which ever you prefer.
But, in order to stitch the mesh back, you need to use reconujtructParMesh and not just reconstructPar.
Hope this helps.
Kalyan
decomposepar, snappyhexmesh, stl
[snappyHexMesh] What CAD software do you use to define STL surfaces? Awak OpenFOAM Meshing & Mesh Conversion 11 November 12, 2020 11:00
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
[ICEM] STL file! How is it useful? bidi ANSYS Meshing & Geometry 0 December 26, 2016 21:33
[snappyHexMesh] Experimentally obtained STL file for internal Flow SnappyHexMesh Irish09 OpenFOAM Meshing & Mesh Conversion 9 April 7, 2012 08:50
decomposePar gives errors of_user_ OpenFOAM 1 July 4, 2011 05:27
