Home > Forums > OpenFOAM Native Meshers: snappyHexMesh and Others
Helyx-OS (GUI for SnappyHexMesh
Like Tree42Likes
Old   June 26, 2013, 13:06
Rahul
rrr311 is on a distinguished road
Send a message via AIM to rrr311 Send a message via Skype™ to rrr311
Originally Posted by chegdan View Post
Remember, HELYX-OS v1.0.2 is made to work with OpenFOAM-2.2.x.
I see that your error massage made reference to ThirdParty-2.1.x. If you would like to continue to use 2.1.x and HELYX-OS then you should download the previous version with this link.
Oh is that so. Thank you for replying so quickly. I'll try downloading the previous version and will get back to you .
rrr311 is offline   Reply With Quote
Old   June 26, 2013, 13:12
Rahul
java -Xms128m -Xmx1024m -XX:OnError="/home/suse/OpenFOAM/Engys/HelyxOS/v1.0.1/bin/collectInfo.run" -jar /home/suse/OpenFOAM/Engys/HelyxOS/v1.0.1/lib/HelyxOS.jar HelyxOS 2>&1 | tee /home/suse/OpenFOAM/Engys/HelyxOS/v1.0.1/helyxEE.log
vtkHybridJava NOT loaded: /home/suse/OpenFOAM/Engys/HelyxOS/v1.0.1/ext/libvtkHybridJava.so.5.10.0: libmpi.so.1: cannot open shared object file: No such file or directory
java.lang.UnsatisfiedLinkError: /home/suse/OpenFOAM/Engys/HelyxOS/v1.0.1/ext/libvtkHybridJava.so.5.10.0: libmpi.so.1: cannot open shared object file: No such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.jav a:1807)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java :1732)
at java.lang.Runtime.loadLibrary0(Runtime.java:823)
at java.lang.System.loadLibrary(System.java:1028)
at eu.engys.helyx.vtk.VTKUtil.loadLibrary(VTKUtil.jav a:94)
at eu.engys.helyx.vtk.VTKUtil.LoadAllNativeLibraries( VTKUtil.java:70)
at eu.engys.helyx.gui.Launcher.main(Launcher.java:43)
Make sure the search path is correct:
/home/suse/OpenFOAM/Engys/HelyxOS/jre/lib/amd64/server:/home/suse/OpenFOAM/Engys/HelyxOS/jre/lib/amd64:/home/suse/OpenFOAM/Engys/HelyxOS/jre/../lib/amd64:/home/suse/OpenFOAM/Engys/HelyxOS/v1.0.1/ext:/home/suse/OpenFOAM/Engys/HelyxOS/v1.0.1/../jre/lib/amd64/xawt:/home/suse/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc46/paraview-3.12.0/lib/paraview-3.12:/home/suse/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/openmpi-system:/home/suse/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc46DPOpt/lib/openmpi-system:found:not:command:mpicc:/home/suse/OpenFOAM/suse-2.1.x/platforms/linux64Gcc46DPOpt/lib:/home/suse/OpenFOAM/site/2.1.x/platforms/linux64Gcc46DPOpt/lib:/home/suse/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib:/home/suse/OpenFOAM/ThirdParty-2.1.x/platforms/linux64Gcc46DPOpt/lib:/home/suse/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/dummy:found:not:command:mpicc:bash:/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
I installed HelyxOSv1.0.1 and this the error message. Any thoughts on this sir?
Old   June 26, 2013, 14:35
chegdan's Avatar
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
This was noted earlier in this thread I beleive and also located on the HELYX-OS installation page here. Depending on your operting system this error can be fixed by
ln -s $MPI_ARCH_PATH/lib/libmpi.so $MPI_ARCH_PATH/lib/libmpi.so.1
and in some, the 64 bit distribution will require instead
ln -s $MPI_ARCH_PATH/lib64/libmpi.so $MPI_ARCH_PATH/lib64/libmpi.so.1
Dan
Find me on twitter @dancombest and LinkedIn
chegdan is online now   Reply With Quote
Old   June 26, 2013, 14:45
Rahul
Oh. Is the following line supposed to appear in the error:
I got the same error when I ran it with v1.0.2.
Thanks a lot for your help Mr. chegdan
Old   June 26, 2013, 14:54
chegdan's Avatar
Daniel P. Combest
Lets back up a bit. How did you install OpenFOAM and the Thirdparty libs on your machine? I strongly suggest compiling them instead of just installing binaries or packages.
Dan
Old   June 26, 2013, 14:58
Rahul
Well I have no idea how to do that... lol
My company installed OpenFOAM and the Thirdparty Tools for me in VMware... I was just trying to install HelyxOS so that I can start working on it...
Old   July 20, 2013, 08:16
COC
tim
COC is on a distinguished road
Hello, I get the problem that I cannot Import .STL.I don't know how to deal with it. can anyone help me?
Ubutu 12.04-64bit OpenFOAM 2.2.1 HELYX-os 1.0.3
code
asawa@ubuntu:~/OpenFOAM/Engys/HelyxOS/v1.0.3$ ./helyxOS.sh
java -Xms128m -Xmx1024m -XX:OnError="/home/asawa/OpenFOAM/Engys/HelyxOS/v1.0.3/bin/collectInfo.run" -jar /home/asawa/OpenFOAM/Engys/HelyxOS/v1.0.3/lib/HelyxOS.jar HelyxOS 2>&1 | tee /home/asawa/OpenFOAM/Engys/HelyxOS/v1.0.3/helyxEE.log
WRITE: blockMeshDict -> /home/asawa/OpenFOAM/Model/newCase/system/blockMeshDict
WRITE: snappyHexMeshDict -> /home/asawa/OpenFOAM/Model/newCase/system/snappyHexMeshDict
WRITE: controlDict -> /home/asawa/OpenFOAM/Model/newCase/system/controlDict
WRITE: fvSchemes -> /home/asawa/OpenFOAM/Model/newCase/system/fvSchemes
WRITE: fvSolution -> /home/asawa/OpenFOAM/Model/newCase/system/fvSolution
WRITE: fvOptions -> /home/asawa/OpenFOAM/Model/newCase/system/fvOptions
WRITE: decomposeParDict -> /home/asawa/OpenFOAM/Model/newCase/system/decomposeParDict
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007f45329cf761, pid=47522, tid=139934819063552
# JRE version: 7.0_11-b21
# Java VM: Java HotSpot(TM) 64-Bit Server VM (23.6-b04 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C [libvtkFiltering.so.5.10+0x281761] vtkMergePoints::InsertUniquePoint(double const*, long long&)+0xe1
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /home/asawa/OpenFOAM/Engys/HelyxOS/v1.0.3/hs_err_pid47522.log
# -XX:OnError=""/home/asawa/OpenFOAM/Engys/HelyxOS/v1.0.3/bin/collectInfo.run""
# Executing /bin/sh -c ""/home/asawa/OpenFOAM/Engys/HelyxOS/v1.0.3/bin/collectInfo.run"" ...
CollectInfo.main()/home/asawa/OpenFOAM/Engys/HelyxOS/v1.0.3
Exception in thread "main" java.util.FormatFlagsConversionMismatchException: Conversion = s, Flags = #
at java.util.Formatter$FormatSpecifier.failMismatch(F ormatter.java:4041)
at java.util.Formatter$FormatSpecifier.printString(Fo rmatter.java:2834)
at java.util.Formatter$FormatSpecifier.print(Formatte r.java:2718)
at java.util.Formatter.format(Formatter.java:2494)
at java.util.Formatter.format(Formatter.java:2423)
at java.lang.String.format(String.java:2797)
at eu.engys.core.CollectInfo.printFile(CollectInfo.ja va:291)
at eu.engys.core.CollectInfo.listDir(CollectInfo.java :274)
at eu.engys.core.CollectInfo.getLibInfo(CollectInfo.j ava:255)
at eu.engys.core.CollectInfo.main(CollectInfo.java:85 )
COC is offline   Reply With Quote
Old   July 21, 2013, 05:49
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings Tim and welcome to the forum!
In what format is the STL file in? ASCII/Text or binary?
And have you read the following thread at the official discussion forum for Helyx-OS? http://sourceforge.net/p/helyx-os/di...read/4c35e4ec/
Best regards,
Bruno
PS: when posting code/output, please use the "[CODE]" marker as explained in my second signature line
Old   July 21, 2013, 07:59
COC
tim
Best regards,
Bruno
Dear Bruno
I tried ASCII format and it worked finally.thank you very much.
Old   July 31, 2013, 04:44
Default refining the mesh using Helyx-os
  #90
izna O'connor
izna is on a distinguished road
Hi everyone,
I am a new user of Helyx-os.
I have been able to set up case where i import my .stl file.
But i am not able to refine it.
example, i used the tutorial in HELYX-OS, ie the CSTR tutorial, there it contain its .stl file along with an eMesh file.
Can somone please explain how to create an emesh file?
please be patient, i am new user in openfoam and also in HELYX-OS.
Kind regards
izna
izna is offline   Reply With Quote
Old   July 31, 2013, 17:43
chegdan's Avatar
Daniel P. Combest
Izna,
This can be done using the surfaceFeatureExtract utility. Assuming you are using 2.2.x, create a file called surfaceFeatureExtractDict in the case system directory. An example of a surfaceFeatureExtractDict is here but I have made a simple one:
|  \\    /   O peration     | Version:  2.2.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      surfaceFeatureExtractDict;
NameOfStlFile.stl
    // How to obtain raw features (extractFromFile || extractFromSurface)
    extractionMethod    extractFromSurface;
    extractFromSurfaceCoeffs
        // Mark edges whose adjacent surface normals are at an angle less
        // than includedAngle as features
        // - 0  : selects no edges
        // - 180: selects all edges
        includedAngle   180;
    // Write options
        // Write features to obj format for postprocessing
        writeObj                no;
After you have changed the name of the STL file in in your dictionary to match the actual STL file of your geometry, you can execute
in your case directory. The generated eMesh (located in the same directory as your STL files) file can then be used in HELYX-OS. I have given some steps to add the eMesh file to HELYX-OS in a presentation I gave at the last workshop located here. You can also look at other presentations at the conference, including a talk on snappyHexMesh here. I hope this helps and good luck.
atg and izna like this.
Dan
Old   August 5, 2013, 01:45
izna O'connor
Hello Dan,
Thanks a lot for your reply.
if i wish to mesh it finer, or in certain parts finer, can i simply copy this https://github.com/OpenFOAM/OpenFOAM...ureExtractDictand modify?
Old   August 5, 2013, 10:41
chegdan's Avatar
Daniel P. Combest
Izna,
To mesh finer then you would need to change the "levels" near the surface. If you are on the surface regions tab, highlight the surface you wish to modify and change the min and max levels. Higher numbers will create a finer mesh. Also, you can make the base mesh size smaller to make a finer mesh overall. Please see
A Comprehensive Tour of SnappyHexMesh
Advanced Preprocessing and Meshing with SnappyHexMesh
atg, izna and Antech like this.
Dan
Last edited by chegdan; August 6, 2013 at 10:57. Reason: Added some sources to help future readers
Old   August 6, 2013, 06:02
izna O'connor
hi..
after creating a case in Helyx-os, i found an error.
blockMesh: command not found
snappyHexMesh: commad not found.
can anyone please tell me what should i do?
Old   August 14, 2013, 09:27
izna O'connor
SOLVER: simpleFoam
/home/izna/Desktop/Askerveindan/solver.run: line 7: simpleFoam: command not found
I am using HelyxOS , when i run my case, i get this error!! what should i do?
Regards
Izna
Old   August 14, 2013, 09:49
chegdan's Avatar
Daniel P. Combest
Izna,
So this problem tells me that either OpenFOAM isn't sourced correctly or there is an issue with your install of HELYX-OS. This can happen sometimes so its an annoying error Some questions:
  • Does OpenFOAM work correctly outside of HELYX-OS
  • Do the variables created when OpenFOAM is initialized exist? I.e. what does the following produce
    echo $WM_PROJECT_DIR
  • Have you run cases outside of HELYX-OS?
  • If you open a terminal and type
    foamInstallationTest
    does this return an OK?
These are just a few things that come to mind
Dan
Old   August 14, 2013, 09:54
izna O'connor
hi Dan.
Thanks to comee at my aid..
command returns this
/opt/openfoam220
outside of HElyxOS i use openfoam normally without any problems
well when i do this i get this
izna@izna-MS-7592:~$ foamInstallationTest
Executing /opt/openfoam220/bin/foamInstallationTest:
Checking basic setup...
FATAL ERROR: OpenFOAM environment not configured.
Please refer to the installation section of the README file:
<OpenFOAM installation dir>/OpenFOAM-2.2.0/README
to source the OpenFOAM environment.
Old   August 14, 2013, 10:00
chegdan's Avatar
Daniel P. Combest
Ah ok...did you follow the "User Configuration" Section on
http://openfoam.org/download/ubuntu.php
To add some lines to your .bashrc file in your home directory?
Dan
Old   August 14, 2013, 10:08
izna O'connor
yes i did ..
But i am unistall and do it all again.. i will post back.
Old   August 14, 2013, 13:10
izna O'connor
hi Dan
After reinstalling Openfoam following this example http://openfoam.org/download/ubuntu.php
I obtain the same error when executing foamInstallationTest
Executing /opt/openfoam221/bin/foamInstallationTest:
<OpenFOAM installation dir>/OpenFOAM-2.2.1/README
cases setup, preprocessor, snappyhexmesh
Thread Tools
Trackbacks are On
Helyx-OS Open Source GUI for OpenFOAM eugene OpenFOAM Announcements from Other Sources 21 March 14, 2016 19:32
TUI Commands from GUI? Carlos FLUENT 6 May 22, 2013 18:05
User Defined GUI Frederik FLUENT 0 June 23, 2006 16:12
Command Line vs. GUI Menus Go FLUENT 0 June 8, 2005 16:05
GUI window settings cmv CD-adapco 0 February 7, 2005 07:22
